Slion 1,201 Posted March 28, 2020 Author Share Posted March 28, 2020 On 3/28/2020 at 12:16 AM, ahunter said: The Fx count down timer does not display properly sometimes. When shutting screen. No cancel button displayed and the dialogue window seems to be stretched and attached to the right hand frame of the screen. Expand Can you find a way to reproduce it? I never ran into that issue myself. Quote Link to post Share on other sites
ahunter 108 Posted March 28, 2020 Share Posted March 28, 2020 On 3/28/2020 at 6:42 AM, Slion said: Can you find a way to reproduce it? I never ran into that issue myself. Expand strangely no at this moment. I have been playing full screen you tube for my son a fair bit. I will try take note of what is open when it happens. 1 Quote Link to post Share on other sites
Slion 1,201 Posted March 31, 2020 Author Share Posted March 31, 2020 Just released v0.9.0 adding Auto-sync scheduler feature which is primarily intended to workaround the following issue and should slightly improve battery life for anyone. Auto-sync scheduler is still brand new and needs more testing so keep an eye open for bugs. Quote Link to post Share on other sites
ahunter 108 Posted April 1, 2020 Share Posted April 1, 2020 Seems to be happening when entering text, from chrome browser, even as I am typing in here. Also happens from messenger. Not all the time though. On 3/28/2020 at 6:42 AM, Slion said: Can you find a way to reproduce it? I never ran into that issue myself. Expand 1 Quote Link to post Share on other sites
ahunter 108 Posted April 4, 2020 Share Posted April 4, 2020 If the screen is scrolling while shutting the keyboard, this seems to be factor as well 1 Quote Link to post Share on other sites
Jordi 72 Posted April 4, 2020 Share Posted April 4, 2020 Would it be possible to use the proximity sensor instead of the magnetic one? I made a flip case and I would like to avoid to insert a magnet. Quote Link to post Share on other sites
Slion 1,201 Posted April 4, 2020 Author Share Posted April 4, 2020 On 4/4/2020 at 7:56 AM, Jordi said: Would it be possible to use the proximity sensor instead of the magnetic one? Expand Yes it should but some development is needed. I guess you would notably need to check if you are in a phone call to avoid locking the phone while calling for instance. On 4/4/2020 at 7:56 AM, Jordi said: I made a flip case and I would like to avoid to insert a magnet. Expand It's usually straight forward and more reliable that the proximity sensor. 2 1 Quote Link to post Share on other sites
Slion 1,201 Posted April 4, 2020 Author Share Posted April 4, 2020 On 4/4/2020 at 7:56 AM, Jordi said: Would it be possible to use the proximity sensor instead of the magnetic one? Expand Maybe WaveUp could do that for you. 1 Quote Link to post Share on other sites
Jordi 72 Posted April 4, 2020 Share Posted April 4, 2020 On 4/4/2020 at 9:53 AM, Slion said: Maybe WaveUp could do that for you. Expand Thanks, this app is suitable for now. 1 Quote Link to post Share on other sites
Slion 1,201 Posted April 13, 2020 Author Share Posted April 13, 2020 I'm considering adding a feature to disable the fingerprint reader temporarily while the proximity sensor is triggered for instance, or when the case is closed. That should eliminate the very few remaining instances of "too many attempts". However, I wonder if it could be too slow to react making the unlocking experience unbearably slower. See: https://stackoverflow.com/questions/45525658/temporarily-disabling-fingerprint Quote Link to post Share on other sites
Slion 1,201 Posted June 27, 2020 Author Share Posted June 27, 2020 (edited) Just published release v0.9.2 adding an option to disable the touch screen for those of us experiencing ghost touch inputs. Just be careful with it as I don't know what happens if you reboot your device while this is on for instance. Please don't blame me if you need to reset your phone because of it 😁 I've updated the certificate so you will need to uninstall the previous version first. Edited June 27, 2020 by Slion 1 Quote Link to post Share on other sites
Slion 1,201 Posted July 1, 2020 Author Share Posted July 1, 2020 I'm thinking of adding an option to vibrate on key press, that should be fun and help compensate for my left Ctrl key that's not giving any tactile feedback anymore. Quote Link to post Share on other sites
Slion 1,201 Posted July 2, 2020 Author Share Posted July 2, 2020 On 7/1/2020 at 9:34 PM, Slion said: I'm thinking of adding an option to vibrate on key press, that should be fun and help compensate for my left Ctrl key that's not giving any tactile feedback anymore. Expand Vibration feedback upon key press is now available in the latest version, go fetch it you know where. It's fairly basic and weird at first but I quite like it. It would be nice to be able to customise the feedback for every single key or even to use system settings for audio and vibration feedback but that should do for now. Quote Link to post Share on other sites
FlyingAntero 871 Posted July 3, 2020 Share Posted July 3, 2020 On 7/2/2020 at 5:23 PM, Slion said: Vibration feedback upon key press is now available in the latest version, go fetch it you know where. It's fairly basic and weird at first but I quite like it. It would be nice to be able to customise the feedback for every single key or even to use system settings for audio and vibration feedback but that should do for now. Expand I can't install the latest on update on Pro1. When I press the APK file nothing happens. However, I am able to to install older version just fine. Is it just me? Suggestion: It would be great if there would be an option to schedule only the screen filter. Mostly I use screen filter when I am going to sleep. Now I just manually toggle filter on at bedtime since the adaptive brightness is not working for me very well. (I don't know if I should disable stock adaptive brightness from Android settings when I am using Fx Service). Other than that Fx Service is very good app with flip cover. 1 Quote Link to post Share on other sites
Slion 1,201 Posted July 3, 2020 Author Share Posted July 3, 2020 On 7/3/2020 at 7:19 AM, FlyingAntero said: can't install the latest on update on Pro1. When I press the APK file nothing happens. However, I am able to to install older version just fine. Is it just me Expand Uninstall the older version. Certificate was change. 2 Quote Link to post Share on other sites
Slion 1,201 Posted July 3, 2020 Author Share Posted July 3, 2020 (edited) On 7/3/2020 at 7:19 AM, FlyingAntero said: adaptive brightness (From Fx Service) Expand It's indeed pretty useless cause the light sensor lacks precision in low light conditions. I used to use it only to disable screen filter until I just gave up on it. It is easier to just turn the screen filter on and off yourself. There is a quick settings tile to do that or Ctrl+Fn+O. Long press the quick settings tile will take you to Fx Service app where you can easily adjust the brightness or with Fx Qwerty Alt + Up or Down. Edited July 3, 2020 by Slion 1 Quote Link to post Share on other sites
Slion 1,201 Posted July 3, 2020 Author Share Posted July 3, 2020 On 7/3/2020 at 7:19 AM, FlyingAntero said: don't know if I should disable stock adaptive brightness from Android settings when I am using Fx Service Expand Leave it on, here again Fx Service provides a quick settings tile to toggle it. 1 Quote Link to post Share on other sites
Slion 1,201 Posted July 3, 2020 Author Share Posted July 3, 2020 On 7/3/2020 at 10:54 AM, Slion said: Ctrl+Fn+O Expand Maybe it's Ctrl+Alt+O on your layout. I'm using Fx Qwerty with swapped Fn and Alt key for easier Alt+Tab access so I get confused sometimes 😁 Quote Link to post Share on other sites
Slion 1,201 Posted July 3, 2020 Author Share Posted July 3, 2020 Just published release v0.9.4. It adds support for screen rotation override. Basically it implements its own screen rotation logic from accelerometer and magnetometer. It comes with its own Quick Settings tile too. Just disable system auto-rotate and use the one provided by Fx Service instead. It's an attempt at fixing our issue where screen rotation get stuck until you launch the camera app. Time will tell if it works, your feedback is most welcome. Quote Link to post Share on other sites
FlyingAntero 871 Posted July 4, 2020 Share Posted July 4, 2020 On 7/3/2020 at 11:21 AM, Slion said: Maybe it's Ctrl+Alt+O on your layout. I'm using Fx Qwerty with swapped Fn and Alt key for easier Alt+Tab access so I get confused sometimes 😁 Expand Interestingly both Ctrl+Alt+O and Ctrl+Fn+O are working. I am using FinQwerty with "QWERTZ to Finnish" layout. Thanks for the tips. Those tiles are very handy. 1 Quote Link to post Share on other sites
Slion 1,201 Posted July 4, 2020 Author Share Posted July 4, 2020 (edited) On 7/4/2020 at 5:54 AM, FlyingAntero said: Interestingly both Ctrl+Alt+O and Ctrl+Fn+O Expand Ho, that's what it was, I probably put both shortcuts so that it would work the same as far as user is concerned on all layouts. The original intent was indeed to have it work as Ctrl+Fn+O as you can do it with two thumbs. Edited July 4, 2020 by Slion 1 Quote Link to post Share on other sites
MickH 212 Posted July 4, 2020 Share Posted July 4, 2020 A bit late to the party 😁 But how does this fare up against WaveUp? I've been using that for a while now and although it's been generally good, it does have its moments, like every so often I feel the Pro1 buzzing like crazy in my hand (probably the proximity sensor picking up the case moving.) 1 Quote Link to post Share on other sites
Slion 1,201 Posted July 4, 2020 Author Share Posted July 4, 2020 On 7/4/2020 at 1:26 PM, MickH said: But how does this fare up against WaveUp? Expand Fx Service relies on hall sensor to detect closing of the case and proximity sensor only for opening of the case. It's therefore more reliable than WaveUp to detect case closure. All you need to do is install a thin magnet opposite the hall sensor in your case. Then Fx Service does also a bunch of other things specific to Pro1. 1 1 Quote Link to post Share on other sites
Slion 1,201 Posted July 5, 2020 Author Share Posted July 5, 2020 (edited) On 7/3/2020 at 9:28 PM, Slion said: It adds support for screen rotation override. Basically it implements its own screen rotation logic from accelerometer and magnetometer. It comes with its own Quick Settings tile too. Just disable system auto-rotate and use the one provided by Fx Service instead. It's an attempt at fixing our issue where screen rotation get stuck until you launch the camera app. Time will tell if it works, your feedback is most welcome. Expand So far I'm really happy with Fx Service auto-rotate. It does appear to fix our stuck rotation issues. It does not appear to negatively impact battery usage. However it looks like it could be optimized a bit. Maybe by adding some hysteresis and disabling it when the display is off. Mine tends to always be in portrait when I unlock my phone. Nevertheless it's already totally usable. Edited July 5, 2020 by Slion Quote Link to post Share on other sites
Slion 1,201 Posted July 6, 2020 Author Share Posted July 6, 2020 Just published release v0.9.6. Quote Link to post Share on other sites
