shymega 1 Posted March 28, 2020 Share Posted March 28, 2020 On a similar note to a car mount, I've been looking at desk mounts, but I'm not sure how to find one that would allow me to use the slider, or if one exists. Haven't actually got my Pro1 yet, just waiting.. but I'm preparing at this moment in time. Does anyone have any suggestions? The reason I'm looking at a desk mount is so I can use my Pro1 at a reasonable height, and also to protect it from the dog 🙂 Thanks!   Quote Link to post Share on other sites
EskeRahn 5,598 Posted March 28, 2020 Share Posted March 28, 2020 I'm not quite sure what you mean be a "desktop stand", do you mean like a charging cradle? or just a mount like a dashboard car-mount? if the last, many car mounts have a common size ball head, and you can take the holding part and attach to a dashboard-part rather than an air-vent part. The cheap gravity landscape holder I mentioned a few time in the car mount thread allows to use the Pro1 either opened or closed and comes with a dashboard mount, that you could adhere to a plate, or directly to the desk for a fixed position. 1 Quote Link to post Share on other sites
altwouss 22 Posted March 31, 2020 Share Posted March 31, 2020 I am using:Â https://www.trust.com/nl/product/18440-aluminium-stand-for-smartphone-and-tablet But they are not producing it anymore. I've used it for phones and tablets (also bigger than 7"). I think there might be similar products available. Quote Link to post Share on other sites
PC_ 61 Posted March 31, 2020 Share Posted March 31, 2020 I generally have it sitting open on top of my laptop which is closed (external peripherals for laptop) and primarily interact with it via a bluetooth mouse. I don't use it much for phone calls (Skype for Business on my laptop when working) and only need to type for messaging apps. Quote Link to post Share on other sites
shymega 1 Posted April 1, 2020 Author Share Posted April 1, 2020 On 3/28/2020 at 10:13 PM, EskeRahn said: I'm not quite sure what you mean be a "desktop stand", do you mean like a charging cradle? or just a mount like a dashboard car-mount? if the last, many car mounts have a common size ball head, and you can take the holding part and attach to a dashboard-part rather than an air-vent part. The cheap gravity landscape holder I mentioned a few time in the car mount thread allows to use the Pro1 either opened or closed and comes with a dashboard mount, that you could adhere to a plate, or directly to the desk for a fixed position. Sorry for the late reply - yeah, I'll give the gravity holder a go. Just a mount really, charging cradle isn't a huge issue for me. Thanks! Quote Link to post Share on other sites
shymega 1 Posted April 1, 2020 Author Share Posted April 1, 2020 On 3/31/2020 at 3:32 PM, altwouss said: I am using: https://www.trust.com/nl/product/18440-aluminium-stand-for-smartphone-and-tablet But they are not producing it anymore. I've used it for phones and tablets (also bigger than 7"). I think there might be similar products available. Sorry for late reply - thanks for your suggestion 🙂 Quote Link to post Share on other sites
shymega 1 Posted April 1, 2020 Author Share Posted April 1, 2020 On 3/31/2020 at 5:01 PM, PC_ said: I generally have it sitting open on top of my laptop which is closed (external peripherals for laptop) and primarily interact with it via a bluetooth mouse. I don't use it much for phone calls (Skype for Business on my laptop when working) and only need to type for messaging apps. Sorry for late reply, but thanks for the idea! 1 Quote Link to post Share on other sites
epninety 87 Posted December 18, 2020 Share Posted December 18, 2020 (edited) Just to dig up an old thread... I've been working at my desk more than usual for the last few weeks, and I found that I kept losing the Pro1 under the various piles of paper, and that because the back isn't flat, I always have to pick it up to do anything so it doesn't rock around the desktop... So I drew up a quick desk stand design for the 3D printer. I'm up to about iteration 5 over the last 2 days, and I think this works pretty well. Â Happy to send the STL file if anyone else wants to print one. Equally would like to see whatever others have come up with. Â Edited December 18, 2020 by epninety Grammar 6 1 Quote Link to post Share on other sites
Rud 123 Posted December 26, 2020 Share Posted December 26, 2020 (edited) I've been using a decorative plate stand for about 10 years now. :))) The photo is right side up on my phone, I don't know why the forum keeps flipping it on upload. Usually it sits on its pouch on the desk since opened it's already at an angle. Edited December 26, 2020 by Rud 3 Quote Link to post Share on other sites
Asanti898 7 Posted December 30, 2020 Share Posted December 30, 2020 On 12/18/2020 at 10:03 AM, epninety said: Just to dig up an old thread... I've been working at my desk more than usual for the last few weeks, and I found that I kept losing the Pro1 under the various piles of paper, and that because the back isn't flat, I always have to pick it up to do anything so it doesn't rock around the desktop... So I drew up a quick desk stand design for the 3D printer. I'm up to about iteration 5 over the last 2 days, and I think this works pretty well. Â Happy to send the STL file if anyone else wants to print one. Equally would like to see whatever others have come up with. Â I like this solution. I've been using the Motorla stock desk dock (has micro USB and mini HDMI, because ports are on the side) and going to miss it. Quote Link to post Share on other sites
xenon 3 Posted June 6, 2021 Share Posted June 6, 2021 On 12/18/2020 at 7:03 PM, epninety said: Just to dig up an old thread... I've been working at my desk more than usual for the last few weeks, and I found that I kept losing the Pro1 under the various piles of paper, and that because the back isn't flat, I always have to pick it up to do anything so it doesn't rock around the desktop... So I drew up a quick desk stand design for the 3D printer. I'm up to about iteration 5 over the last 2 days, and I think this works pretty well. Â Happy to send the STL file if anyone else wants to print one. Equally would like to see whatever others have come up with. Â Would love a copy of the STL, can you make it publicly available, i.e. GitHub or elsewhere for download ? Quote Link to post Share on other sites
ddark-il 100 Posted June 7, 2021 Share Posted June 7, 2021 https://www.amazon.com/gp/product/B07K7G2JY7 Â There is a little bit of difficulty with opening/closing slider due to high "tooth"Â at the lower part, but it's not unmanageable. Big pro is that it's adjustable and sturdy enough that you can type on it. Â Quote Link to post Share on other sites
epninety 87 Posted June 7, 2021 Share Posted June 7, 2021 15 hours ago, xenon said: Would love a copy of the STL, can you make it publicly available, i.e. GitHub or elsewhere for download ? Sent you a PM with link for download. Feel free to pass it on if it's useful. You're the only one to ask for it in 5 months, I doubt my server is going to be flattened by download requests 😀 1 Quote Link to post Share on other sites
