Not sure if I just missed it but my pro1x is running LOS 21. I don't know if it worked with stock android because I immediately installed UT then found that without VoLTE there is no point and installed LOS. My phone will receive text messages but will not send one. It always just says that the message failed to send tap to retry. Phone call connections are never very good either, though it sounds like that is normal for this phone.
  • Replies 330
Yes, not really a LOS problem, so I moved your post here.  If the phone has poor connectivity, LOS won't change that.  It would be good to know more information such as where you live and what carriers you are using/have available.
It's hit and miss.  Some Pro1xs work okay, other don't.  QA? Some networks work some don't? We don't know.  I'm lucky to have one that mostly works, although I still use it as a PDA.
I am on Verizon in central Colorado. I did solder two of the spring connectors back on that I found were broken off at the same time that I replaced my battery. I did all that before/in order to get my phone to turn on for the first time. Just seems weird that I can take calls, make calls, and receive text but can not send a text.
That may very well be a Verizon thing. I had Verizon working for a while on my Pro 1 and I hit a point where, a little different, I could send texts but couldn't receive them.  My Pro1 on T-Mobile and my Pro1x on Ting work fine both in VA where I live and in CO Springs when I am visiting my son.
Sweet thanks for the info!
  • 2 weeks later...
