rlpowell 6 Posted May 25, 2023 Share Posted May 25, 2023 Just got mine a little while ago, still getting used to it. Installed SwiftKey to fix the lack of auto-complete with the keyboard, which was my first major complaint. Now my biggest problem, by far, is the fingerprint sensor, because it keeps "detecting" any part of my hand coming anywhere near it, and ... I'm honestly not sure exactly what's happening at the software level, but unless I keep my *entire hand* *very* far away from it, anything involving input is basically unusable. This is with the physical keyboard closed, just using it in portrait mode like a normal phone. The soft keyboard will disappear every time it registers me touching the sensor, no matter what app I'm in. If I'm in Chrome, it will *reload the page* every time I brush the sensor even a tiny bit. Stuff like that. It's like it's responding to a brush on the sensor in a similar way to me sleeping and re-awakening the phone. I actually *want* to use the fingerprint sensor, even though I really don't like the location (years of BB KeyOne/Key2), but if I can't *grip my phone* and still use it because of this thing, I'm going to have to put tape over it or something. 2 Quote Link to post Share on other sites
PoongZY 15 Posted May 25, 2023 Share Posted May 25, 2023 They should just do it under screen or at the back. Side finger print reader always at problem for me. Quote Link to post Share on other sites
Name_not_avail 75 Posted May 26, 2023 Share Posted May 26, 2023 Notorious problem in stock 2.1.2, then fixed in GMS-less 2.1.5, and for some reason LOS developers are not using that updated vendor blob for the current versions of LOS. Does anyone have a way to communicate this issue to the LOS devs? Seems like it should be a relatively easy fix, to just use the 2.1.5 stuff for LOS. 1 Quote Link to post Share on other sites
rlpowell 6 Posted May 26, 2023 Author Share Posted May 26, 2023 What's LOS? 1 1 Quote Link to post Share on other sites
--- 129 Posted May 26, 2023 Share Posted May 26, 2023 LineageOS 2 Quote Link to post Share on other sites
rlpowell 6 Posted May 27, 2023 Author Share Posted May 27, 2023 I'm on Android, though; shouldn't I have the firmware update? 1 Quote Link to post Share on other sites
rlpowell 6 Posted May 27, 2023 Author Share Posted May 27, 2023 Also sometimes, for hours at a time, the fingerprint sensor just ... does nothing. ;_; 2 Quote Link to post Share on other sites
Rob. S. 1,667 Posted May 27, 2023 Share Posted May 27, 2023 3 hours ago, rlpowell said: I'm on Android, though; shouldn't I have the firmware update? It's not official yet. I'm still on on the original Android, too. I don´t use one of the browsers which are affected from the bug, though, so that aspect doesn't bother me personally. Now I never found the original Pro1's fingerprint reader too reliable, but the one in the Pro1X indeed is even worse. The Pro1 had a tendency to fail with moist fingers, the Pro1X has a tendency to fail with dry fingers, which affects me more. Also, somehow it behaves as if the stored fingerprint data would somehow deteriorate, and the success rate of fingerprint recognition becomes lower and lower, until I re-train it. Also, some security-centered apps like for banking are unusable with the fingerprint reader because they either refuse the fingerprint method completely or, after a few usages, report a change in the fingerprint data (that never happened, at least not actively through me) and switch off fingerprint authentication. I'm still using the fingerprint reader, but I'm thinking about disabling fingerprints. 1 Quote Link to post Share on other sites
EskeRahn 5,598 Posted May 28, 2023 Share Posted May 28, 2023 8 hours ago, Rob. S. said: The Pro1 had a tendency to fail with moist fingers, the Pro1X has a tendency to fail with dry fingers, which affects me more. Also, somehow it behaves as if the stored fingerprint data would somehow deteriorate, and the success rate of fingerprint recognition becomes lower and lower, until I re-train it. These are interesting observations. I have never seen this with neither the Pro1 nor the Pro1X. But at 60 I guess that my fingers are quite 'fixed' as-is. I have not 'retrained' the Pro1 since experiments in 2019. (I have the bug that the fingerprint reader sort of stops working on the Pro1, and needs a restart to work - it could be anywhere between a month and the same day, and I struggle to see any pattern in triggering it. MAYBE it is picking it up and attempting unlocking while it still is vibrating with incoming sms. And initially I tried retraining and al kinds of tricks, but for years I just accepted it) Quote Link to post Share on other sites
DieBruine 397 Posted May 28, 2023 Share Posted May 28, 2023 (edited) Inotice no difference in behaviour. Wet fingers or really dried ot fingers indeed do not register correctly. Mine stopped working once, reboot fixed that. Banking apps hangs sometimes and disables fingerprint reader. Apart from those 'common' (to a Pro1 user) no other issues. I do have a bumper around the phone and that helps a lot with preventing unnecessary registration. Any skin is detected as a registraion, so I do understand your frustration. I'm having less issues because of the bumper around the edges. Running latest LoS btw. Edited May 28, 2023 by DieBruine 1 1 Quote Link to post Share on other sites
guss 13 Posted June 6, 2023 Share Posted June 6, 2023 hi, After few reaserch on internet i ve found somes things but i'm not good at linux or android. I have lineageOS and root enabled Connect the phone to a PC with ADB and android USB driver installed in a linux terminal or windows Shell use "adb shell" and "getevent" and next, press the fingerprint sensor for me it's look like that : > adb shell QX1050:/ $ getevent add device 1: /dev/input/event6 name: "bengal-idp-snd-card Button Jack" add device 2: /dev/input/event5 name: "bengal-idp-snd-card Headset Jack" add device 3: /dev/input/event1 name: "goodix-ts" add device 4: /dev/input/event0 name: "qpnp_pon" add device 5: /dev/input/event4 name: "madev" add device 6: /dev/input/event3 name: "Builtin Keyboard" add device 7: /dev/input/event2 name: "gpio-keys" /dev/input/event4: 0001 01d6 00000001 /dev/input/event4: 0000 0000 00000000 the last two lines is the result when pressing the fingerprint sensor so if i understand, device 5, ,named madev is the fingerprint sensor. I' m right ? But what to do exactly with this ? i havent found anything in system/usr/\keylayout/ that can help Quote Link to post Share on other sites
guss 13 Posted June 26, 2023 Share Posted June 26, 2023 The fingerprint sensor bug is fixed since the 5 june LOS update https://forum.xda-developers.com/t/official-lineageos-20-for-pro1-x.4543997/page-7#post-88614419 1 Quote Link to post Share on other sites
xhajt03 29 Posted July 13, 2023 Share Posted July 13, 2023 I decided to post my fingerprint sensor related issues / findings (Pro1x with standard Android, not rooted): At the beginning, I observed the same behaviour as described above for Pro1 - the fingerprint sensor stopped working after some time and only phone restart helped. After some time it happened to me that restarting didn't help any longer. To my surprise, I found out that my previously registered fingerprints disappeared from the system settings as if I'd never initialized them. After teaching my Pro1x to recognize them again, it continued to work more or less the same way as previously (i.e. with necessity to restart the phone after certain amount of time in order to get the fingerprint sensor working again. After some more months, the restarting workaround ceased to work again. I wanted to check whether the fingerprints weren't forgotten again, but to my surprise, I cannot find / enable fingerprints for unlocking the phone any longer - the setting is simply not there (I can allow unlocking using a PIN or a password, but not using the fingerprint sensor any longer at all). :-((( Now - I can imagine multiple potential reasons of this behaviour, but I don't know whether one of these is the real culprit, nor how to check it (and even better solve it afterwards). 😞 My candidates: Some software installed by me (or an update thereof) might have resulted in this issue in theory. Please, don't suggest trying to remove all applications one by another to check this hypothesis... 😞 Partly related to the previous - in particular, the so-called Microsoft Intune Portal (mobile device management software used in corporate environment for enforcing certain security policies for devices accessing the corporate infrastructure, e.g. company e-mails) might disable it in theory with some company policy update (and/or update of this application or its default settings from Microsoft 😕 ). Unfortunately, I cannot contact people responsible for administering the security policies easily to check whether there's such a configuration in place (I work for a company employing several tens of thousands people worldwide and this policy setting is certainly global rather than local). 😞 Unfortunately, I can imagine that a hardware problem of the fingerprint sensor might lead to the situation that Android believes that there's no fingerprint sensor available on the device and thus this configuration is not made available. I can image that sorting out this situation (_if_ it is the real reason) would be next to impossible with the current situation regarding phone deliveries, etc.... 😞 Any suggestions, additional ideas, etc.? 1 Quote Link to post Share on other sites
guss 13 Posted July 21, 2023 Share Posted July 21, 2023 (edited) hi, I m' not a specialist on android, perhaps you can : Activate "devloppoment tools" on the phone Activate "USB debuging" install ADB tools on a computer navigate to the folder where is adb Open a commande line windows to this folder Connect the phone to a computer type "adb shell" type getevent press the figerprint sensor you have to see something like that if the sensor is there: add device 1: /dev/input/event6 name: "bengal-idp-snd-card Button Jack" add device 2: /dev/input/event5 name: "bengal-idp-snd-card Headset Jack" add device 3: /dev/input/event1 name: "goodix-ts" add device 4: /dev/input/event0 name: "qpnp_pon" add device 5: /dev/input/event4 name: "madev" add device 6: /dev/input/event3 name: "Builtin Keyboard" add device 7: /dev/input/event2 name: "gpio-keys" /dev/input/event4: 0001 01d6 00000001 /dev/input/event4: 0000 0000 00000000 (event4 is the fingerprint sensor on my phone and i get "0001 01d6 00000001" when pressed and 0000 0000 00000000 when released ) Edited July 21, 2023 by guss 3 Quote Link to post Share on other sites
EskeRahn 5,598 Posted July 21, 2023 Share Posted July 21, 2023 9 hours ago, guss said: (event4 is the fingerprint sensor on my phone and i get "0001 01d6 00000001" when pressed and 0000 0000 00000000 when released ) Just out of curiosity, do you see a different code for an 'enrolled finger' and any other rejected finger? Quote Link to post Share on other sites
xhajt03 29 Posted July 31, 2023 Share Posted July 31, 2023 (edited) On 7/21/2023 at 10:55 AM, guss said: hi, I m' not a specialist on android, perhaps you can : Activate "devloppoment tools" on the phone Activate "USB debuging" install ADB tools on a computer navigate to the folder where is adb Open a commande line windows to this folder Connect the phone to a computer type "adb shell" type getevent press the figerprint sensor you have to see something like that if the sensor is there: add device 1: /dev/input/event6 name: "bengal-idp-snd-card Button Jack" add device 2: /dev/input/event5 name: "bengal-idp-snd-card Headset Jack" add device 3: /dev/input/event1 name: "goodix-ts" add device 4: /dev/input/event0 name: "qpnp_pon" add device 5: /dev/input/event4 name: "madev" add device 6: /dev/input/event3 name: "Builtin Keyboard" add device 7: /dev/input/event2 name: "gpio-keys" /dev/input/event4: 0001 01d6 00000001 /dev/input/event4: 0000 0000 00000000 (event4 is the fingerprint sensor on my phone and i get "0001 01d6 00000001" when pressed and 0000 0000 00000000 when released ) Unfortunately, I don't get any events generated when touching the sensor. 😞 The list of input devices is more or less the same: QX1050:/ $ getevent add device 1: /dev/input/event6 name: "bengal-idp-snd-card Button Jack" add device 2: /dev/input/event5 name: "bengal-idp-snd-card Headset Jack" add device 3: /dev/input/event0 name: "qpnp_pon" add device 4: /dev/input/event1 name: "goodix-ts" add device 5: /dev/input/event4 name: "madev" add device 6: /dev/input/event2 name: "gpio-keys" add device 7: /dev/input/event3 name: "Fxtec Pro1" Edited July 31, 2023 by xhajt03 1 Quote Link to post Share on other sites
guss 13 Posted August 31, 2023 Share Posted August 31, 2023 On 7/21/2023 at 8:38 PM, EskeRahn said: Just out of curiosity, do you see a different code for an 'enrolled finger' and any other rejected finger? I will try. There is another command to see what are the different possible code, like "move up" "move down" but i never received that code during my tries adb shell su -- getevent -lp /dev/input/event4 sources : https://source.android.com/docs/core/interaction/input/getevent 1 Quote Link to post Share on other sites
guss 13 Posted September 1, 2023 Share Posted September 1, 2023 On 7/21/2023 at 8:38 PM, EskeRahn said: Just out of curiosity, do you see a different code for an 'enrolled finger' and any other rejected finger? No there is nothing related to the finger on my test on stock android connect the phone (whit debug USB on) on computer (with adb on it) run (on powershell) .\adb.exe shell -- getevent -l /dev/input/event4 result should be is like that when touching the sensor (i ve added comment between <> ) EV_KEY KEY_FN_F5 DOWN < strat double tap> EV_SYN SYN_REPORT 00000000 EV_KEY KEY_FN_F5 UP EV_SYN SYN_REPORT 00000000 EV_KEY KEY_FN_F5 DOWN EV_SYN SYN_REPORT 00000000 EV_KEY KEY_FN_F6 DOWN EV_SYN SYN_REPORT 00000000 EV_KEY KEY_FN_F6 UP EV_SYN SYN_REPORT 00000000 < end double tap> EV_KEY KEY_FN_F5 UP < strat simple tap> EV_SYN SYN_REPORT 00000000 EV_KEY KEY_FN_F5 DOWN EV_SYN SYN_REPORT 00000000 < end double tap> EV_KEY KEY_FN_F5 UP < start long press> EV_SYN SYN_REPORT 00000000 EV_KEY KEY_FN_F5 DOWN EV_SYN SYN_REPORT 00000000 EV_KEY KEY_FN_F7 DOWN EV_SYN SYN_REPORT 00000000 EV_KEY KEY_FN_F7 UP EV_SYN SYN_REPORT 00000000 EV_KEY KEY_FN_F5 UP EV_SYN SYN_REPORT 00000000 < end long press> 2 Quote Link to post Share on other sites
