Juanjeste 4 Posted December 22, 2023 Share Posted December 22, 2023 I have a universal book-type case but I'm not entirely sure because the Pro1-X is thicker and doesn't close well. Until I get used to it. Does anyone have the model that Amazon sells? Aroepurt? it is valid? Thanks for the help Quote Link to post Share on other sites
Hook 3,315 Posted December 22, 2023 Share Posted December 22, 2023 I found this, but I would be cautious about any case claiming to be for the Pro1 or Pro1x that doesn't show complete pictures. The case may fit, but does it allow the keyboard to open properly? Luckily Amazon allows returns... https://www.amazon.com/Compatible-Qx1050-backplane-Silicone-KA-HEI16/dp/B0B8S3TXGM My skepticism comes from seeing manufacturers in China relabel a case as for the Por1 or Pro1x just because it fits in one way or is a universal case they think might work, but these cases tend not to be actually created for the Pro1x. 2 Quote Link to post Share on other sites
sequestris 710 Posted December 30, 2023 Share Posted December 30, 2023 On 12/22/2023 at 9:30 AM, Hook said: I found this, but I would be cautious about any case claiming to be for the Pro1 or Pro1x that doesn't show complete pictures. The case may fit, but does it allow the keyboard to open properly? Luckily Amazon allows returns... https://www.amazon.com/Compatible-Qx1050-backplane-Silicone-KA-HEI16/dp/B0B8S3TXGM My skepticism comes from seeing manufacturers in China relabel a case as for the Por1 or Pro1x just because it fits in one way or is a universal case they think might work, but these cases tend not to be actually created for the Pro1x. Been there. Done this. I didn't post about it because it was an epic fail. Also I had to fight for the return credit because it's some stupid a$$ 3rd Party Chinesium dude. Quote Link to post Share on other sites
sequestris 710 Posted April 24, 2024 Share Posted April 24, 2024 I have no clue where the original thread ended up. I posted a couple of cases I got a while back that are perfect, but y'all didn't want the funky designs and colors. I finally found a black one on Amazon https://www.amazon.com/gp/product/B085B37D84 All you have to do is GENTLY remove the rubber phone holder, use a few pieces of double sided carpet tape (lemme know if you want a link) and mount the phone. Camera hole is perfect, no button interference, and great protection. 1 4 Quote Link to post Share on other sites
sequestris 710 Posted April 24, 2024 Share Posted April 24, 2024 Sticker not included 2 Quote Link to post Share on other sites
