david 929 Posted December 19, 2019 Share Posted December 19, 2019 3 minutes ago, netman said: Also funny the setting is in system instead of accessibility where you'd feel it'd belong... And named "swipe up on home button"?!? I grabbed the Pixel and took a look. It is in Settings->System->Gestures->System navigation There are 3 options: Gesture navigation, 2-button navigation, and 3-button navigation. In Gesture, there are no soft buttons at all. In 2-button, there is a virtual home button and an arrow button to the side of it. I don't see a mode that is like what the Pro1 has, with only the home button, but maybe that is a Pie vs Android 10 difference. 3-button is, of course, the normal 3 virtual buttons (which used to be physical!!!). 1 Quote Link to post Share on other sites
kashif 350 Posted December 20, 2019 Share Posted December 20, 2019 how to wakeup the screen by tapping on it? ATM I have to click the power button to wake it up Quote Link to post Share on other sites
Craig 1,435 Posted December 20, 2019 Share Posted December 20, 2019 1 minute ago, kashif said: how to wakeup the screen by tapping on it? ATM I have to click the power button to wake it up Press Esc Quote Link to post Share on other sites
kashif 350 Posted December 20, 2019 Share Posted December 20, 2019 @Craig thanks But I was asking about if its not in slideout mode, can we tap on the screen? Quote Link to post Share on other sites
silversolver 849 Posted December 20, 2019 Share Posted December 20, 2019 2 minutes ago, kashif said: @Craig thanks But I was asking about if its not in slideout mode, can we tap on the screen? They disabled that because it was causing a serious problem, with I don't remember what. They said it will be restored once they can figure out how to stop the associated problem. 1 2 Quote Link to post Share on other sites
david 929 Posted December 20, 2019 Share Posted December 20, 2019 2 minutes ago, silversolver said: They disabled that because it was causing a serious problem, with I don't remember what. They said it will be restored once they can figure out how to stop the associated problem. It was because it was related to the screen refusing to accept input until you reboot, I believe. 2 Quote Link to post Share on other sites
anonim001 105 Posted December 20, 2019 Author Share Posted December 20, 2019 Thanks everyone for the answers. The main problem I have now is that the phone is thinking the hwkb is open 99% of the time, no matter how many times I open and close 😞 the backlight stopped working too. In this state it's unusable for me. You guys (and girls) are much smarter than me, can You think of any solution for that? Can it be a software bug or rather hardware related problem? Quote Link to post Share on other sites
david 929 Posted December 20, 2019 Share Posted December 20, 2019 20 minutes ago, anonim001 said: Thanks everyone for the answers. The main problem I have now is that the phone is thinking the hwkb is open 99% of the time, no matter how many times I open and close 😞 the backlight stopped working too. In this state it's unusable for me. You guys (and girls) are much smarter than me, can You think of any solution for that? Can it be a software bug or rather hardware related problem? Did you try rebooting it? Have you done all the software updates? Have you tried factory reset? If none of those do it, then I'd guess the cable that connects the screen to the keyboard isn't getting signals through for some reason. Quote Link to post Share on other sites
anonim001 105 Posted December 20, 2019 Author Share Posted December 20, 2019 (edited) 1 hour ago, david said: Did you try rebooting it? Have you done all the software updates? Have you tried factory reset? If none of those do it, then I'd guess the cable that connects the screen to the keyboard isn't getting signals through for some reason. Rebooting does not help at all. Factory reset only for a short time. All updates installed. edit: strange thing just happened. Everything was fine (phone in portrait mode), phone was in stand-by lying on the desk and suddenly it has turned itself on in landscape mode. edit2: now it was just fipping back and forth for a couple of seconds, like some contact from the sensor was loose. edit3: pushed the housing harder in a couple of places and it's back to normal at the moment. The situation is dynamic with this issue... Edited December 20, 2019 by anonim001 Quote Link to post Share on other sites
divstar 164 Posted December 20, 2019 Share Posted December 20, 2019 13 hours ago, PanicBrothers said: good Idea...but on QWERTZ if you choose no layout all buttons are one step postponed. An "E" is an "R" and "h" is a "j" and so on. If you choose a LAyout all fine but no questionmark possible. I will try your Thread with Keymapper. THX for this No need to do that. Just update Gboard and make sure to add the proper languages in the settings. Had the same problem yesterday and solved it. Quote Link to post Share on other sites
PanicBrothers 66 Posted December 20, 2019 Share Posted December 20, 2019 38 minutes ago, divstar said: No need to do that. Just update Gboard and make sure to add the proper languages in the settings. Had the same problem yesterday and solved it. Sure...but try now to type a questionmark or a ~ 😉 Quote Link to post Share on other sites
Craig 1,435 Posted December 20, 2019 Share Posted December 20, 2019 9 hours ago, anonim001 said: edit: strange thing just happened. Everything was fine (phone in portrait mode), phone was in stand-by lying on the desk and suddenly it has turned itself on in landscape mode. edit2: now it was just fipping back and forth for a couple of seconds, like some contact from the sensor was loose. edit3: pushed the housing harder in a couple of places and it's back to normal at the moment. The situation is dynamic with this issue... I hate to say it, but it seems like you have a hardware issue, and are going to have to contact fxtec for warranty repair/replacement.... Quote Link to post Share on other sites
anonim001 105 Posted December 20, 2019 Author Share Posted December 20, 2019 2 hours ago, Craig said: I hate to say it, but it seems like you have a hardware issue, and are going to have to contact fxtec for warranty repair/replacement.... I think so too, now it's stuck for good, nothing helps 😞 guess I'll be the first one to try their repair service. 2 Quote Link to post Share on other sites
Thunderhaake 8 Posted December 20, 2019 Share Posted December 20, 2019 Did you guys find a solution for the question mark? I still can not write a "?" with the hardware-keyboard at QWERTZ.... GBoard is up-to-date. (No Update found) Quote Link to post Share on other sites
CornholioGSM 370 Posted December 21, 2019 Share Posted December 21, 2019 On 12/19/2019 at 8:01 PM, anonim001 said: 5. The LCD quality is poor... I can tell where the glue is just by looking it under direct light. (yeah, that was more of a remark than question) ....i have question about ∆∆∆...you say that is visible how is display glued. Can you post some photos how it looks? ...i am little scared if it really looks too cheap 😞 1 Quote Link to post Share on other sites
netman 1,424 Posted December 21, 2019 Share Posted December 21, 2019 5 minutes ago, CornholioGSM said: ....i have question about ∆∆∆...you say that is visible how is display glued. Can you post some photos how it looks? ...i am little scared if it really looks too cheap 😞 I don't see any glue or so with the screen, it looks pretty nice to me... Not a huge fan of the curved edges yet but I really wouldn't say the device looks cheap in any way. 3 Quote Link to post Share on other sites
CornholioGSM 370 Posted December 21, 2019 Share Posted December 21, 2019 BTW...about softkeys (navkeys) on bottom...what i want is classic layout as on all droid phones - menu-home(recent)-back-search...this is the best layout for me 2 Quote Link to post Share on other sites
netman 1,424 Posted December 21, 2019 Share Posted December 21, 2019 1 hour ago, CornholioGSM said: BTW...about softkeys (navkeys) on bottom...what i want is classic layout as on all droid phones - menu-home(recent)-back-search...this is the best layout for me Here is a possibly confusing screenshot of how it looks like after turning the gesture nonsense off: Quote Link to post Share on other sites
CornholioGSM 370 Posted December 21, 2019 Share Posted December 21, 2019 1 minute ago, netman said: Here is a possibly confusing screenshot of how it looks like after turning the gesture nonsense off: Quote Link to post Share on other sites
CornholioGSM 370 Posted December 21, 2019 Share Posted December 21, 2019 ...it is base settings like as on from first gen moto g 1 Quote Link to post Share on other sites
netman 1,424 Posted December 21, 2019 Share Posted December 21, 2019 i do wish in android pie a longpress on recents button would open split screen, like it was in nougat... lineage still does so and im probably gonna move to that eventually Quote Link to post Share on other sites
CornholioGSM 370 Posted December 21, 2019 Share Posted December 21, 2019 yesss...i mean that this "layout" is still settable on los 🙂 Quote Link to post Share on other sites
netman 1,424 Posted December 21, 2019 Share Posted December 21, 2019 30 minutes ago, CornholioGSM said: yesss...i mean that this "layout" is still settable on los 🙂 i checked out LOS briefly for the first time on pro1 and it seemed very nice 🙂 stock turns out to be more practical for testing something i'm poking at though, so i'm stuck with that for a while 2 Quote Link to post Share on other sites
Craig 1,435 Posted December 21, 2019 Share Posted December 21, 2019 This device definitely does not look cheap. Its sleek and smooth and clean, open and closed. I haven't tried looking for leaking glue tho, and don't plan to. 3 Quote Link to post Share on other sites
netman 1,424 Posted December 21, 2019 Share Posted December 21, 2019 5 minutes ago, Craig said: I haven't tried looking for leaking glue tho, and don't plan to. I have stared at it plenty, nothing says "cheap"... It's beatifully made 🙂. 1 Quote Link to post Share on other sites
