_DW_ 628 Posted February 26, 2020 Share Posted February 26, 2020 Charging works fine Red/Green. Emails/WhatsApp/Messages all work fine don't really use notifications on other apps turn them off. 1 Quote Link to post Share on other sites
Polaris 423 Posted February 26, 2020 Share Posted February 26, 2020 4 hours ago, Craig said: Does the LED work when charging? For me it's always on when I'm plugged in, even when unlocked (which is annoying in dim light cuz its so bright). I haven't paid attention to it for notifications, as I'm pretty much always plugged in unless its in my pocket. Yes, works perfectly when charging (changes colors appropriately, etc.) Also works perfectly with the factory test, all three RGB colors are perfect. Just doesn't work with notifications. With the stock ROM it would work after a factory reset, then stop at random times afterward. With Lineage I don't have any notification LED activity (even with a 3rd party app, nothing at all), and I also lost the vibration notifications as well (which worked fine with the stock ROM). Quote Link to post Share on other sites
Slion 1,201 Posted October 7, 2020 Share Posted October 7, 2020 I noticed the notification LED colour differs depending of the kind of notifications or from which app they are coming from. For instance: Usually from SMS and FB Messenger: green LiveScore: blue Microsoft Teams: white Can we influence the notification LED colour somehow? Quote Link to post Share on other sites
VaZso 1,999 Posted October 7, 2020 Share Posted October 7, 2020 11 minutes ago, Slion said: Can we influence the notification LED colour somehow? You may try Light Manager for example. 1 Quote Link to post Share on other sites
Slion 1,201 Posted October 7, 2020 Share Posted October 7, 2020 2 minutes ago, VaZso said: You may try Light Manager for example. Reviews are abysmal. You tried it? Quote Link to post Share on other sites
EskeRahn 5,596 Posted October 7, 2020 Share Posted October 7, 2020 There have been other threads mentioning this subject I will try and find those rather than repeat the story. ADD: I have been whining on the search in here before, but as you can not search for anything less than four characters, it is really hard to guess how to find a thread on the LED... Anyway "LED Colour Tester" works on Lineage, but has not worked on Stock since very early on. Long story on the whys, but the short story is the lack of a diffuser.... 1 Quote Link to post Share on other sites
VaZso 1,999 Posted October 7, 2020 Share Posted October 7, 2020 22 minutes ago, Slion said: Reviews are abysmal. You tried it? Yes, I read about it here and installed the application, I had no problems using it. However, it keeps in the notification bar list. 1 Quote Link to post Share on other sites
Zamasu 258 Posted October 7, 2020 Share Posted October 7, 2020 On Lineage this seems to be build in. Under Settings -> Apps & notifications -> Notifications -> Notification light. Then you can apps you want to control the light for with the plus on the upper right if you enable "Use custom values". 2 2 Quote Link to post Share on other sites
