Slion 1,201 Posted August 1, 2020 Author Share Posted August 1, 2020 As I'm investigating how to implement qwertz support I thought it could be nice to have support for gamepads too. Any gamer out there wishing for a such a feature? Maybe it just does not make sense if you do not have analog stick support anyway. Quote Link to post Share on other sites
Laska 41 Posted August 2, 2020 Share Posted August 2, 2020 10 hours ago, Slion said: As I'm investigating how to implement qwertz support I thought it could be nice to have support for gamepads too. Any gamer out there wishing for a such a feature? Maybe it just does not make sense if you do not have analog stick support anyway. On Droid 4 I was using app GameKeyboard and it was perfect for gaming. On Pro1 service for this app just can't start... 1 Quote Link to post Share on other sites
Slion 1,201 Posted August 3, 2020 Author Share Posted August 3, 2020 I ought to add combining diacritical for tilde accent to ALT+T. ('\u0303') Quote Link to post Share on other sites
Slion 1,201 Posted August 3, 2020 Author Share Posted August 3, 2020 On 3/4/2020 at 12:56 PM, FlyingAntero said: https://twitter.com/chenliangchen/status/1141016306801676290 Can I get a picture of a production QWERTZ to make sure this was not changed since? Currently busy doing the mapping and I would hate to have to do it twice. Quote Link to post Share on other sites
EskeRahn 5,595 Posted August 3, 2020 Share Posted August 3, 2020 15 minutes ago, Slion said: Can I get a picture of a production QWERTZ to make sure this was not changed since? Currently busy doing the mapping and I would hate to have to do it twice. https://eskerahn.dk/?p=3651 1 Quote Link to post Share on other sites
Slion 1,201 Posted August 3, 2020 Author Share Posted August 3, 2020 (edited) @FlyingAntero Here is a first draft for QWERTZ layout. The ALT layer is still missing, the Fx layer may need to be adapted for QWERTZ as it should currently be the same as on QWERTY. hwkbd-v0.4.0-fxTecPro1-qwertz-release.apk Known issues: First row shift not acting as fn. Fn characters on standard letter keys missing or wrong. Edited August 3, 2020 by Slion 1 Quote Link to post Share on other sites
Slion 1,201 Posted August 3, 2020 Author Share Posted August 3, 2020 Known issues from above should be fixed now. hwkbd-v0.4.1-fxTecPro1-qwertz-release.apk 1 Quote Link to post Share on other sites
FlyingAntero 871 Posted August 3, 2020 Share Posted August 3, 2020 2 hours ago, Slion said: Known issues from above should be fixed now. hwkbd-v0.4.1-fxTecPro1-qwertz-release.apk 116.39 kB · 3 downloads Great job! I installed the latest version successfully. First row shift is acting like a FN (except that shift + ß gives ẞ but that is probably like it should). 1 1 Quote Link to post Share on other sites
Slion 1,201 Posted August 3, 2020 Author Share Posted August 3, 2020 4 minutes ago, FlyingAntero said: except that shift + ß gives ẞ but that is probably like it should Yes that's how it was done in FinQwerty I'm not sure if it makes sense though, I can't think of any instance of upper case ß in german. 1 Quote Link to post Share on other sites
FlyingAntero 871 Posted August 3, 2020 Share Posted August 3, 2020 2 minutes ago, Slion said: Yes that's how it was done in FinQwerty I'm not sure if it makes sense though, I can't think of any instance of upper case ß in german. I am not familiar with German letters so I don't know either. I see that you implemented FX combinations also (like FX + c gives calculator). Nice! So far I haven't seen any issues with the keymap. 1 Quote Link to post Share on other sites
Slion 1,201 Posted August 3, 2020 Author Share Posted August 3, 2020 2 minutes ago, FlyingAntero said: FX combinations Yes those ones were taken over from the qwerty variant and may need reviewing for qwertz DE. 4 minutes ago, FlyingAntero said: am not familiar with German letters so I don't know either Which is your native language? Why did you get a qwertz then? Quote Link to post Share on other sites
FlyingAntero 871 Posted August 3, 2020 Share Posted August 3, 2020 11 minutes ago, Slion said: Which is your native language? Why did you get a qwertz then? I am from Finland. QWERTZ suits quite well for us since we have Ä and Ö letters also and instead of Ü we are using Å. Then Y and Z needs to be swapped. So, only minor remapping is needed from QWERTZ to Scandic. 1 Quote Link to post Share on other sites
Slion 1,201 Posted August 3, 2020 Author Share Posted August 3, 2020 24 minutes ago, FlyingAntero said: am from Finland. So what's wrong with the layouts provided by FinQwerty? Is it the missing Fx and Alt layers? 27 minutes ago, FlyingAntero said: instead of Ü we are using Å. Then Y and Z needs to be swapped. So, only minor remapping is needed from QWERTZ to Scandic. I could do a QWERTZ - FI layout if you want. Should I take a look at the FinQwerty variant? LATER: I see you actually already provided what you are looking for: Quote Link to post Share on other sites
EskeRahn 5,595 Posted August 3, 2020 Share Posted August 3, 2020 1 hour ago, Slion said: Yes that's how it was done in FinQwerty I'm not sure if it makes sense though, I can't think of any instance of upper case ß in german. It was added as a character to official German rather recently (June 2017), for the case of writing an existing text in all caps (as an example the Corbusier WP theme I use for my blog has this odd behaviour for some headers). I guess It is not that likely to actually type it though. But that is now possible. 1 Quote Link to post Share on other sites
fxtec11 9 Posted December 24, 2020 Share Posted December 24, 2020 On 8/3/2020 at 2:14 PM, Slion said: Yes that's how it was done in FinQwerty I'm not sure if it makes sense though, I can't think of any instance of upper case ß in german. Instead of capital ß it should give the question mark. Or how am is supposed to type question mark insteadẞ 3 Quote Link to post Share on other sites
pebert 98 Posted August 8, 2021 Share Posted August 8, 2021 Hi I´m still struggling a bit with this, How do I find the scan codes for the "F" and "arrow up" buttons? the Key-loggers or dmesg don´t show anything. Running LinageOS18.1 also when I look at the original keychars file I don´t find symbols related to the "arrow up" button, (for example I don´t see anything about "/" being associated to "P" //Per Quote Link to post Share on other sites
Slion 1,201 Posted August 15, 2021 Author Share Posted August 15, 2021 On 8/8/2021 at 2:55 PM, pebert said: Hi I´m still struggling a bit with this, How do I find the scan codes for the "F" and "arrow up" buttons? the Key-loggers or dmesg don´t show anything. Running LinageOS18.1 also when I look at the original keychars file I don´t find symbols related to the "arrow up" button, (for example I don´t see anything about "/" being associated to "P" //Per My understanding is that neither Fx Qwerty nor FinQwerty are working on LOS cause the keyboard driver has been significantly changed, notably modifying scan codes. Quote Link to post Share on other sites
Slion 1,201 Posted August 15, 2021 Author Share Posted August 15, 2021 On 8/8/2021 at 2:55 PM, pebert said: Running LinageOS18.1 also when I look at the original keychars file I don´t find symbols related to the "arrow up" button, (for example I don´t see anything about "/" being associated to "P" That's to be expected if you are looking at the LOS source code cause that's hard coded in the driver. Quote Link to post Share on other sites
