tdm 2,322 Posted November 13, 2020 Author Share Posted November 13, 2020 (edited) Figured out the issue with the keyboard backlight. Lineage decided they wanted to add the keyboard backlight logic into the Android core (frameworks/base) and delete the keyboard backlight logic from the lights HAL. This is Lineage specific -- neither AOSP nor AICP have it. I made a brief attempt to add the Lineage code into AICP's frameworks/base but it didn't go smoothly. So I'm just going to revert the change and move on. I hope to have a new build within a few hours. Edited November 13, 2020 by tdm 4 Quote Link to post Share on other sites
tdm 2,322 Posted November 13, 2020 Author Share Posted November 13, 2020 New build is up, the link in the OP is updated. Changes: * Fixed keyboard backlight. * Fixed incremental file update. New MD5: 8d557ea563667d1332dd99729fa5e4ca This is a full update because the existing incremental updater is broken. Future updates should be incremental and automatic, if all goes well. 6 Quote Link to post Share on other sites
Hook 3,315 Posted November 13, 2020 Share Posted November 13, 2020 (edited) 48 minutes ago, tdm said: New build is up, the link in the OP is updated. Changes: * Fixed keyboard backlight. * Fixed incremental file update. New MD5: 8d557ea563667d1332dd99729fa5e4ca This is a full update because the existing incremental updater is broken. Future updates should be incremental and automatic, if all goes well. Downloaded. Installed smoothly and the keyboard backlight works! 🥇 Oh, and has the November security patch! Edited November 13, 2020 by Hook 2 Quote Link to post Share on other sites
EskeRahn 5,598 Posted November 14, 2020 Share Posted November 14, 2020 (Installed smoothly here too, and yes Backlight and November, thanks 😎 ) 1 1 Quote Link to post Share on other sites
hxkafg 2 Posted November 15, 2020 Share Posted November 15, 2020 Does AICP include Lineage's SBC improvements? Quote Link to post Share on other sites
tdm 2,322 Posted November 15, 2020 Author Share Posted November 15, 2020 2 hours ago, hxkafg said: Does AICP include Lineage's SBC improvements? I don't know, but my guess would be probably not. Quote Link to post Share on other sites
EskeRahn 5,598 Posted November 15, 2020 Share Posted November 15, 2020 1 hour ago, tdm said: I don't know, but my guess would be probably not. Well, SBC is listed in AICP-Q Settings,developer options, Bluetooth Audio Codec. I have- no idea if it works though Quote Link to post Share on other sites
benoitjeffrey 66 Posted November 16, 2020 Share Posted November 16, 2020 I know that option was under the devices settings in bluetooth connection and since AICP it isn't there anymore. I don't really feel any difference since the update, IMO it all sounds the same . Quote Link to post Share on other sites
shubell 39 Posted November 16, 2020 Share Posted November 16, 2020 I tried it and had the same IMS issue like with lineage 17.1, has anyone volte working? Quote Link to post Share on other sites
benoitjeffrey 66 Posted November 17, 2020 Share Posted November 17, 2020 I'm on volte and everything works well on this side 3 Quote Link to post Share on other sites
D1ggs 141 Posted November 17, 2020 Share Posted November 17, 2020 @tdm i'm using this as my daily. I'll report back any bugs. 1 1 Quote Link to post Share on other sites
tdm 2,322 Posted November 17, 2020 Author Share Posted November 17, 2020 1 hour ago, benoitjeffrey said: I'm on volte and everything works well on this side Oh reeeeeally. That's very pleasantly surprising. Especially when it's broken on Lineage. Thanks for letting us know. 🙂 2 Quote Link to post Share on other sites
shubell 39 Posted November 17, 2020 Share Posted November 17, 2020 not really sure if i am gonna risk it 😉 and rollback if it is not working. Quote Link to post Share on other sites
benoitjeffrey 66 Posted November 18, 2020 Share Posted November 18, 2020 I was on lineage 1 month ago and it worked fine too... Or I'm missing something, I'm used to see the LTE asside everything else even while in call. is there an other way to make sure it use it and not the old 3g? Quote Link to post Share on other sites
EskeRahn 5,598 Posted November 18, 2020 Share Posted November 18, 2020 1 hour ago, benoitjeffrey said: is there an other way to make sure it use it and not the old 3g? Yes, under network, you can select LTE as the only allowed band for the sim Quote Link to post Share on other sites
shubell 39 Posted November 18, 2020 Share Posted November 18, 2020 well in the lineage gerrit you can see that a IMS fix is beeing worked on. Can't be working on aicp as it is lieage based, or can it 😉 Quote Link to post Share on other sites
tdm 2,322 Posted November 18, 2020 Author Share Posted November 18, 2020 2 hours ago, shubell said: well in the lineage gerrit you can see that a IMS fix is beeing worked on. Can't be working on aicp as it is lieage based, or can it 😉 AICP is not Lineage based. It does incorporate a lot of the QCOM hardware support and a few other things. But it specifically does not use the Lineage SDK. And I think the telephony stack is more similar to AOSP than Lineage. So it is quite possible that VoLTE/IMS is working on AICP. Though I haven't tested it myself, as my carrier still won't work with this device. 😕 2 Quote Link to post Share on other sites
internationaltraitor 84 Posted November 19, 2020 Share Posted November 19, 2020 so does this have google spyware and playstore and needs a gmail account to set up the phone?? or is this a better de-googled software than lineage? Quote Link to post Share on other sites
tdm 2,322 Posted November 19, 2020 Author Share Posted November 19, 2020 54 minutes ago, internationaltraitor said: so does this have google spyware and playstore and needs a gmail account to set up the phone?? or is this a better de-googled software than lineage? Both run just fine without gapps. 2 Quote Link to post Share on other sites
internationaltraitor 84 Posted November 19, 2020 Share Posted November 19, 2020 6 minutes ago, tdm said: Both run just fine without gapps. so basically,, its more de-googled.. or just as much. Sounds great! read the whole thread, will give this software a try. Quote Link to post Share on other sites
shubell 39 Posted November 19, 2020 Share Posted November 19, 2020 (edited) tried it again, volte not working at least for me as ims is not registred. Edited November 19, 2020 by shubell Quote Link to post Share on other sites
pebert 98 Posted November 21, 2020 Share Posted November 21, 2020 will it be possible to have a swedish keymap on this ROM? Preferably the same one as finQWERTY if that works, this will be my new daily ROM //Per Quote Link to post Share on other sites
EskeRahn 5,598 Posted November 21, 2020 Share Posted November 21, 2020 1 hour ago, pebert said: will it be possible to have a swedish keymap on this ROM? Preferably the same one as finQWERTY if that works, this will be my new daily ROM //Per With Swedish selected you do get @ on Sym+2 on AICP-Q 🙂 (Goes for both qwertZ and qwertY layout) 1 Quote Link to post Share on other sites
pebert 98 Posted November 22, 2020 Share Posted November 22, 2020 12 hours ago, EskeRahn said: With Swedish selected you do get @ on Sym+2 on AICP-Q 🙂 Thanks, we should have kept Norway and Denmark, would have been much easier with the "scandinavian" key maps 😆 Anyway, this is just great! Just when I managed to get my phone working on stock software I back for one more round, but this will be really interesting actually. Holding my thumbs now 1 Quote Link to post Share on other sites
EskeRahn 5,598 Posted November 22, 2020 Share Posted November 22, 2020 5 hours ago, pebert said: Thanks, we should have kept Norway and Denmark, would have been much easier with the "scandinavian" key maps 😆 Too bad Marethe did not manage to leave the legacy with the three united kingdoms. It certainly is silly with the tiny differences in orthography. My guess is that it was a silly attempt from the danes to distance themselves from German orthography ... 1 Quote Link to post Share on other sites
