EskeRahn 5,598 Posted May 21, 2024 Share Posted May 21, 2024 (lineage-21.0-20240518-nightly-pro1-signed.zip on May 5 security patch installed smoothly (*) using adb sideload and MindTheGapps-14.0.0-arm64-20231025_234300) And we still can only select one keyboard layout, so no easy layout switching, for multilingual usage. 2 Quote Link to post Share on other sites
TeZtdevice 368 Posted May 25, 2024 Author Share Posted May 25, 2024 Lineage-21.0-202405025nightly-pro1-signed.zip on May 5 (2024) security patch, installed smoothly using OTA 2 Quote Link to post Share on other sites
shubell 39 Posted May 30, 2024 Share Posted May 30, 2024 Can anyone tell me if this version has PPTP enabled. I am considering to upgrade from my old lineage 18.1 build as it is signed with a test key and have some play device integrity issue... Quote Link to post Share on other sites
TeZtdevice 368 Posted June 1, 2024 Author Share Posted June 1, 2024 Lineage-21.0-20240601nightly-pro1-signed.zip on May 5 (2024) security patch, installed smoothly using OTA 2 Quote Link to post Share on other sites
TeZtdevice 368 Posted June 8, 2024 Author Share Posted June 8, 2024 Lineage-21.0-20240608nightly-pro1-signed.zip on May 5 (2024) security patch, installed smoothly using OTA 3 Quote Link to post Share on other sites
EskeRahn 5,598 Posted June 15, 2024 Share Posted June 15, 2024 (lineage-21.0-20240615-nightly-pro1-signed.zip on May 5 security patch installed smoothly (*) using adb sideload and MindTheGapps-14.0.0-arm64-20231025_234300) And we still can only select one keyboard layout, so no easy layout switching, for multilingual usage. 2 Quote Link to post Share on other sites
TeZtdevice 368 Posted June 16, 2024 Author Share Posted June 16, 2024 Lineage-21.0-20240615nightly-pro1-signed.zip on May 5 (2024) security patch, installed smoothly using OTA 2 Quote Link to post Share on other sites
Kzin 33 Posted June 24, 2024 Share Posted June 24, 2024 Just had an update come through, dated 23 June. Now there is something up with the camera. Torch wont work, says camera in use. Open camera says another app is using the camera. Disabling the Camera app made no difference. 2 Quote Link to post Share on other sites
Hook 3,315 Posted June 24, 2024 Share Posted June 24, 2024 4 hours ago, Kzin said: Just had an update come through, dated 23 June. Now there is something up with the camera. Torch wont work, says camera in use. Open camera says another app is using the camera. Disabling the Camera app made no difference. Interestingly, when I check for an OTA update on my Pro1, which currently is on the June 15th update, it says no updates found. And when I check their download page, June 15th is the latest. Maybe they pulled it? Quote Link to post Share on other sites
Kzin 33 Posted June 24, 2024 Share Posted June 24, 2024 Yeah its the Odd Solutions build with Google Apps/Pixel goodies included. guess it's my bad luck then. Quote Link to post Share on other sites
Kzin 33 Posted June 24, 2024 Share Posted June 24, 2024 According to "npjohnson" on XDA "working on it, th official has the same issue". Quote Link to post Share on other sites
Hook 3,315 Posted June 24, 2024 Share Posted June 24, 2024 3 hours ago, Kzin said: According to "npjohnson" on XDA "working on it, th official has the same issue". Have you been using Npj's build all along or did you somehow install Npj's build over the official build, because the later might create problems of it's own. Quote Link to post Share on other sites
Kzin 33 Posted June 24, 2024 Share Posted June 24, 2024 always had the Odd Solutions one Quote Link to post Share on other sites
Hook 3,315 Posted June 29, 2024 Share Posted June 29, 2024 Lineage-21-20240629-NIGHTLY-pro1 with June 5th security patch installed smoothly via OTA. MindTheGapps14, and root was maintained. However: The camera problem reported above for the Oddsoulutions version showed up here as well. Neither the AOSP default camera, nor Open Camera work. Open Camera reports "Failed to open camera. Camera may be in use by another application?" For now I will wait and see if this gets fixed in a future update since I don't really use the camera on my Pro1, but this would be mighty inconvenient otherwise. I have even tried a "battery pull" restart which often fixes wonky things, but didn't make a difference. 1 1 Quote Link to post Share on other sites
TeZtdevice 368 Posted June 30, 2024 Author Share Posted June 30, 2024 (edited) Lineage-21.0-20240629nightly-pro1-signed.zip on May 5 (2024) security patch, installed smoothly using OTA BUT with these following issues: no camera no accelerometer sensor no flashlight function Edited June 30, 2024 by TeZtdevice Quote Link to post Share on other sites
Rob. S. 1,667 Posted June 30, 2024 Share Posted June 30, 2024 (edited) 16 hours ago, Hook said: The camera problem reported above for the Oddsoulutions version showed up here as well. Neither the AOSP default camera, nor Open Camera work. Open Camera reports "Failed to open camera. Camera may be in use by another application?" FWIW, I remember when I was still using the Pro1 that was what LOS 18.1 told me when the internal camera cable had come loose after the phone had taken a hit or drop. (Which could always be fixed by applying sufficient pressure to the phone's back in the right place to reattach the cable.) Edited June 30, 2024 by Rob. S. Quote Link to post Share on other sites
EskeRahn 5,598 Posted June 30, 2024 Share Posted June 30, 2024 Just to chime in here, the camera seems to still work fine with both the build in Camera app and the Open Camera app with the older build in lineage-21.0-20240615-nightly-pro1-signed.zip So I would recommend to make sure to get a copy from here of that version until the bug (hopefully) gets fixed. As not all bugs got high priority, the working build might disappear by age, as only the last five builds are available for download. (On the priority, e.g. the keyboard is still almost useless for bilingual usage and has been so in all the 21.0 releases this far, so I am considering reverting to 20.0, and see 21.0 as as dead as the AICP releases) Remember that going to a previous build (almost) always will require you to wipe the user data. PS: Do not get me wrong, Not criticising here! I know this is all done voluntarily by some awesome people. 1 Quote Link to post Share on other sites
claude0001 1,424 Posted June 30, 2024 Share Posted June 30, 2024 There has been a lot of restructuring of build-targets in the last three weeks: https://review.lineageos.org/q/project:LineageOS/android_device_fxtec_pro1 I guess with the QPR scheme regressions breaking functionality within one major release have become more likely ... 1 Quote Link to post Share on other sites
Kzin 33 Posted July 2, 2024 Share Posted July 2, 2024 On 6/30/2024 at 9:31 PM, EskeRahn said: Just to chime in here, the camera seems to still work fine with both the build in Camera app and the Open Camera app with the older build in lineage-21.0-20240615-nightly-pro1-signed.zip Remember that going to a previous build (almost) always will require you to wipe the user data. So reverting to a previous nightly, will probably require a wipe? Quote Link to post Share on other sites
EskeRahn 5,598 Posted July 2, 2024 Share Posted July 2, 2024 10 hours ago, Kzin said: So reverting to a previous nightly, will probably require a wipe? Most likely. You could try without, but I would certainly be sure to back up stuff first, since I think the risk of having to wipe is high. (My point was more to download and save the file, and if the issue is not fixed shortly, you have a return path) 1 Quote Link to post Share on other sites
Hook 3,315 Posted July 2, 2024 Share Posted July 2, 2024 10 hours ago, Kzin said: So reverting to a previous nightly, will probably require a wipe? I agree with @EskeRahn. I would wait for the next update and see if that fixes it. The Pro1x seems to have updated without that problem-- I don't know if that means they solved it, or that it was somehow exclusively a Pro1 problem, but they will get it fixed and most everything else still works. Quote Link to post Share on other sites
Breeze 26 Posted July 7, 2024 Share Posted July 7, 2024 No camera fix yet 😡 3 1 Quote Link to post Share on other sites
TeZtdevice 368 Posted July 7, 2024 Author Share Posted July 7, 2024 (edited) Lineage-21.0-20240707nightly-pro1-signed.zip on July 5 (2024) security patch, installed smoothly using OTA BUT with these following issues: no camera no accelerometer + proximity sensors no flashlight function Edited July 8, 2024 by TeZtdevice 2 2 Quote Link to post Share on other sites
CornholioGSM 370 Posted July 13, 2024 Share Posted July 13, 2024 (edited) ...July 13 update installed without problem via OTA. Problems persist *no camera *no flashlight etc + still problems (maybe only by me) *slow/lagging screen rotating *sometime no dialing tuut tuut sound QUESTION...can i switch slot B->A for boot my previous installed build? Edited July 13, 2024 by CornholioGSM 1 Quote Link to post Share on other sites
Wheeljack 212 Posted July 14, 2024 Share Posted July 14, 2024 8 hours ago, CornholioGSM said: QUESTION...can i switch slot B->A for boot my previous installed build? I tried switching from 6-22 back to 6-15 that way (using magisk's "install to inactive boot slot"). My phone wouldn't get past bootloader afterwards and I had to flash 6-22 via ADB to get it working again (data was still there). Going from 7-13 back to 7-6 might work better again though. I know I had switched the boot partition successfully at least once. That time I used fastboot fwiw. Quote Link to post Share on other sites
