FlyingAntero 871 Posted November 22, 2020 Share Posted November 22, 2020 @tdm Would it be possible to make AICP build with SafetyNet hack to pass the check? I know that there are some ROMs (like ParanoidAndroid) which passes SafetyNet check but I don't know how it is implemented. If you don't need root then you would not need to try any Magisk Hide things to pass SafetyNet. Currently I am running Havoc OS on my Xperia XZ1 Compact and it passes SafetyNet checks by default. [ROM] Havoc OS v3.11 [OFFICIAL] [STOCK-BASED] Quote July:- Links : GApps | No GApps- July patch and ROM patch- Increased thermal tolerance for charging- Safetynet is back ! It passes out of the box. No need of magisk to pass safetynet- Uniform thermals for charging- Upgrade display.config to 1.9 (thanks to Shujath)- Fix overlay Reducing the notification led blinking speed- Kernel updated to 4.4.230 2 Quote Link to post Share on other sites
tdm 2,322 Posted November 23, 2020 Author Share Posted November 23, 2020 13 hours ago, FlyingAntero said: @tdm Would it be possible to make AICP build with SafetyNet hack to pass the check? I know that there are some ROMs (like ParanoidAndroid) which passes SafetyNet check but I don't know how it is implemented. If you don't need root then you would not need to try any Magisk Hide things to pass SafetyNet. Currently I am running Havoc OS on my Xperia XZ1 Compact and it passes SafetyNet checks by default. [ROM] Havoc OS v3.11 [OFFICIAL] [STOCK-BASED] I could check into it. Shouldn't be hard. 2 2 Quote Link to post Share on other sites
pebert 98 Posted November 26, 2020 Share Posted November 26, 2020 I have used this for some days now, seems to work nicely. I did experience some odd behavior during flashing, see attached pictures Anyway, when I rebooted the phone worked fine. Another thing,bin the meny somewhere you have the option "custom keymap", what is this? 1 Quote Link to post Share on other sites
Hook 3,315 Posted November 27, 2020 Share Posted November 27, 2020 @tdm and anyone else using AICP, I am having some trouble waking it up with out the lower button and am wondering if it is just me (always a good theory). If the lock screen shows, pressing space bar always unlocks and takes me home (I have swipe unlock, no security). If the screen is off, pressing the spacebar once does nothing. Pressing it multiplebtimes sometimes wakes the phone up and unlockes it, but not always. Is there a keybord shortcut I'm supposed to be using to wake the Pro1 or has that not been added yet. I love AICP so far, by the way. It was supposed to be an experiment befor moving on to Lineage 17.1, but I'm thinking I'm not going to move on. Thanks! Quote Link to post Share on other sites
tdm 2,322 Posted November 27, 2020 Author Share Posted November 27, 2020 A brief update... I've been working on a backup/restore solution for Linux (plus an Android app to drive it) that will be able to do full backup/restore, similar to TWRP. This is a bit of an involved project, but it will be well worth it in the end. It will be cosmetically similar to tar on the command line to make it familiar to use, but it is an entirely new code base. Some of the features include: A client/server mode for use in Android and other privilege sensitive environments. Built-in compression and encryption support. The Android app will most likely support remote backup/restore via an HTTP streaming API. Built-in xattr support (including selinux labels). Incremental backup and restore support. Will backup and restore block devices. And probably more that I am forgetting... So once I get a test version I'll include it in my AICP builds. I'll also make it available on github for those that want to give it a try on other Linux systems. In the meantime, the Lineage folks have been busy improving stuff in 17.1, especially support for the hardware keyboard options. I'll be making a new AICP build soon and hopefully the OTA will work this time. 11 Quote Link to post Share on other sites
VaZso 1,999 Posted November 27, 2020 Share Posted November 27, 2020 7 minutes ago, tdm said: I've been working on a backup/restore solution for Linux (plus an Android app to drive it) that will be able to do full backup/restore, similar to TWRP. What is the chance it will work using an Android other than AICP? Is there any chance LineageOS team will also import required code base? Quote Link to post Share on other sites
tdm 2,322 Posted November 28, 2020 Author Share Posted November 28, 2020 14 minutes ago, VaZso said: What is the chance it will work using an Android other than AICP? Is there any chance LineageOS team will also import required code base? It will work on any custom Android version including Lineage. I plan to package it as an add-on, like the su package. 7 Quote Link to post Share on other sites
VaZso 1,999 Posted November 28, 2020 Share Posted November 28, 2020 3 minutes ago, tdm said: It will work on any custom Android version including Lineage. I plan to package it as an add-on, like the su package. Does it mean it will also work on stock LineageOS or it should be a customer compiled code base? Quote Link to post Share on other sites
tdm 2,322 Posted November 28, 2020 Author Share Posted November 28, 2020 Just now, VaZso said: Does it mean it will also work on stock LineageOS or it should be a customer compiled code base? "Stock LineageOS" is a bit of an oxymoron. It will install on LineageOS via the add-on mechanism, just like gapps and su. I will provide that add-on, you will not need to compile it yourself. But it will be open source, of course, so you can compile it yourself if you want. If you are asking if Lineage will incorporate this into their builds ... I cannot answer that. They are currently planning to use SeedVault. But SeedVault uses the built-in Android backup API which allows apps to opt-out of backup and restore. This is a fatal flaw for me and many others. So perhaps they will change their mind after my project is running... who knows. 5 Quote Link to post Share on other sites
VaZso 1,999 Posted November 28, 2020 Share Posted November 28, 2020 1 minute ago, tdm said: "Stock LineageOS" is a bit of an oxymoron. It will install on LineageOS via the add-on mechanism, just like gapps and su. Does it mean users will be able to install it on the official LineageOS build for Pro1? So the solution may not be included when one installs LineageOS but can be added by this add-on mechanism and still receive security/other updates for the base OS? If it may work like this, then it will be a very good solution. I hate I can not save / restore my phone correctly. Quote Link to post Share on other sites
tdm 2,322 Posted November 28, 2020 Author Share Posted November 28, 2020 1 minute ago, VaZso said: Does it mean users will be able to install it on the official LineageOS build for Pro1? So the solution may not be included when one installs LineageOS but can be added by this add-on mechanism and still receive security/other updates for the base OS? If it may work like this, then it will be a very good solution. I hate I can not save / restore my phone correctly. Yes, it should work just as well as gapps and su for any LineageOS version. This includes "stock" on the Pro1-X... which, as far as I know, is just going to be a normal LineageOS weekly build installed at the factory. 1 Quote Link to post Share on other sites
VaZso 1,999 Posted November 28, 2020 Share Posted November 28, 2020 4 minutes ago, tdm said: Yes, it should work just as well as gapps and su for any LineageOS version. This includes "stock" on the Pro1-X... which, as far as I know, is just going to be a normal LineageOS weekly build installed at the factory. Thanks, it sounds very good. Quote Link to post Share on other sites
Laska 41 Posted November 28, 2020 Share Posted November 28, 2020 8 hours ago, tdm said: "Stock LineageOS" is a bit of an oxymoron. It will install on LineageOS via the add-on mechanism, just like gapps and su. I will provide that add-on, you will not need to compile it yourself. But it will be open source, of course, so you can compile it yourself if you want. If you are asking if Lineage will incorporate this into their builds ... I cannot answer that. They are currently planning to use SeedVault. But SeedVault uses the built-in Android backup API which allows apps to opt-out of backup and restore. This is a fatal flaw for me and many others. So perhaps they will change their mind after my project is running... who knows. And what about stock Android? Will it be possible to fully backup? Quote Link to post Share on other sites
pebert 98 Posted November 28, 2020 Share Posted November 28, 2020 10 hours ago, tdm said: Some of the features include: A client/server mode for use in Android and other privilege sensitive environments. Built-in compression and encryption support. The Android app will most likely support remote backup/restore via an HTTP streaming API. Built-in xattr support (including selinux labels). Incremental backup and restore support. Will backup and restore block devices. And probably more that I am forgetting... This sounds very nice! will there be any good way to schedule it? A wish would be the possibility to backup remotely via SSH or eq. to a private linux server. next question: What does this setting do? And how to use it? otherwise the ROM is working great! it's my new daily now so big thanks @tdm 1 Quote Link to post Share on other sites
tdm 2,322 Posted November 28, 2020 Author Share Posted November 28, 2020 6 hours ago, Laska said: And what about stock Android? Will it be possible to fully backup? Maybe. Stock imposes some restrictions: you cannot modify /system or /vendor. This makes things more challenging. 1 Quote Link to post Share on other sites
tdm 2,322 Posted November 28, 2020 Author Share Posted November 28, 2020 5 hours ago, pebert said: This sounds very nice! will there be any good way to schedule it? A wish would be the possibility to backup remotely via SSH or eq. to a private linux server. Yes, you will be able to schedule it. The app will allow you to schedule a daily backup. The backup will be able to stream to a private server. Though it will not use ssh -- it will likely use https and a CGI script. 5 hours ago, pebert said: next question: What does this [Custom keymap] setting do? And how to use it? You may place a custom keymap file at "/data/system/keyboard/keymap". At boot, this file will be read and used to modify the physical keymap. This setting allows you to enable/disable reading the file at boot. 2 Quote Link to post Share on other sites
Laska 41 Posted November 28, 2020 Share Posted November 28, 2020 37 minutes ago, tdm said: Maybe. Stock imposes some restrictions: you cannot modify /system or /vendor. This makes things more challenging. I would love to have an ability to backup just /system and /data partitions. Quote Link to post Share on other sites
pebert 98 Posted November 28, 2020 Share Posted November 28, 2020 3 hours ago, tdm said: The backup will be able to stream to a private server. Though it will not use ssh -- it will likely use https and a CGI script You may place a custom keymap file at "/data/system/keyboard/keymap". At boot, this file will be read and used to modify the physical keymap. This setting allows you to enable/disable reading the file at boot. Sounds great, hoping for some good guide how to set up the server, neither HTTPS, nor CGI script is my cup of tea. The keymap sounds great! Does it need to have any specific filename? Quote Link to post Share on other sites
Hook 3,315 Posted November 28, 2020 Share Posted November 28, 2020 On 11/27/2020 at 10:57 AM, Hook said: @tdm and anyone else using AICP, I am having some trouble waking it up with out the lower button and am wondering if it is just me (always a good theory). If the lock screen shows, pressing space bar always unlocks and takes me home (I have swipe unlock, no security). If the screen is off, pressing the spacebar once does nothing. Pressing it multiple times sometimes wakes the phone up and unlocks it, but not always. Is there a keyboard shortcut I'm supposed to be using to wake the Pro1 or has that not been added yet. I love AICP so far, by the way. It was supposed to be an experiment before moving on to Lineage 17.1, but I'm thinking I'm not going to move on. Thanks! Bump. This may be just me. My Pro1 is currently almost useless because of ghost touches-- I can only get an hour or two after leaving it off a while before it returns to demon possession level (awaiting new display). But I would like to know if there is a keyboard shortcut that is supposed to wake up Pro1? Thanks. Quote Link to post Share on other sites
tdm 2,322 Posted November 28, 2020 Author Share Posted November 28, 2020 2 hours ago, Hook said: Bump. This may be just me. My Pro1 is currently almost useless because of ghost touches-- I can only get an hour or two after leaving it off a while before it returns to demon possession level (awaiting new display). But I would like to know if there is a keyboard shortcut that is supposed to wake up Pro1? Thanks. Any key should wake the display, I think. Quote Link to post Share on other sites
internationaltraitor 84 Posted December 2, 2020 Share Posted December 2, 2020 since we were on the topic of backing up.... how can one backup a non root lineageos 17, so i can install this aicp os, and i can restore everything onto the new os? file transfer on sd card? or is there another method...? Quote Link to post Share on other sites
John Veness 57 Posted December 3, 2020 Share Posted December 3, 2020 (edited) @tdm Is the AICP discord the only place for bug reports and feature requests for AICP in general (i.e. not Pro1-specific)? I'm more used to something structured like github issues. Edited December 3, 2020 by John Veness Quote Link to post Share on other sites
tdm 2,322 Posted December 4, 2020 Author Share Posted December 4, 2020 11 hours ago, John Veness said: @tdm Is the AICP discord the only place for bug reports and feature requests for AICP in general (i.e. not Pro1-specific)? I'm more used to something structured like github issues. I honestly don't know. But I am on discord and the aicp server is active. 2 1 Quote Link to post Share on other sites
tdm 2,322 Posted December 5, 2020 Author Share Posted December 5, 2020 Another quick update... My day job has been keeping me pretty busy, but I've made some progress. The archiver now builds and runs on Android, both in stand-alone and client/server mode. I have some more work to do before it is ready, but it's definitely progressing. Also, I still have to write a basic app for creating and managing backups and restores. I'd like to say this will be done in the next couple weeks, but I can't make any promises. Additionally, I was reminded that neither stock nor Lineage support exfat. So I will add that into the kernel for my AICP builds before putting out an update. I hope to have that done within a week. After that, I am not sure how much I'll be updating AICP Q. All the developers, both Lineage and AICP, are focused on R now. 6 Quote Link to post Share on other sites
tdm 2,322 Posted December 6, 2020 Author Share Posted December 6, 2020 (edited) EDIT: this build may not be good, flash at your own risk! Alright the new build is up. Same link. md5=4981e2547d288954d588d8ac4301e3f3 Build date: Dec 6, 2020 I've added exfat support, updated to the latest code, and I'm investigating why the file-based incremental updater (still!) won't work properly. This time it is selinux issues. Sigh. Edited December 6, 2020 by tdm 1 4 Quote Link to post Share on other sites
