Noob 158 Posted August 26, 2021 Share Posted August 26, 2021 (edited) If you're willing to spend a few bucks, another build option is to use AWS or a similar cloud instance. It's been a while since I've done it, but in the past I used a super grunty EC2 and built Lineage in under 2 hours. Good to do as a once off, but maybe not so much for frequent builds, especially if it's incremental. Edited August 26, 2021 by Noob 1 Quote Link to post Share on other sites
claude0001 1,424 Posted August 26, 2021 Share Posted August 26, 2021 1 hour ago, VaZso said: I would need to add special characters where "í" does not even reachable [...] You are probably determined to do it your way, which is fine. However, did you even consider to just use the provided QWERTZ layout as it is? All the special characters in your example sentence can be typed using the standard layout in LOS 16.0. "ö" is available as a key of its own. "í", "é", and "á" can be typed using the dead-key function of "´" (i.e. "´" followed by "i", "e", or "a"). Just sayin' ... Typing french is indeed more complicated, as only "´" and "ˋ" have a dead-key function (on LOS 16, that is), not "^", which is a pity ... 1 1 Quote Link to post Share on other sites
Slion 1,201 Posted August 26, 2021 Share Posted August 26, 2021 (edited) 1 hour ago, claude0001 said: Typing french is indeed more complicated, as only "´" and "ˋ" have a dead-key function (on LOS 16, that is), not "^", which is a pity ... There is one on QWERTY. No self respecting French is using QWERTZ 🤣 Edited August 26, 2021 by Slion 1 1 Quote Link to post Share on other sites
Pierre 9 Posted August 26, 2021 Share Posted August 26, 2021 18 minutes ago, Slion said: There is one on QWERTY. No self respecting French is using QWERTZ 🤣 Peuh you know what I do ? I use only QWERTY and never ever type accents, anywhere (pc, phone, work, family). You d be surprised how tolerant people are of 0 accent writing in French. Fuck AZERTY. Burn AZERTY. Add accents to QWERTY 😄 3 Quote Link to post Share on other sites
Slion 1,201 Posted August 26, 2021 Share Posted August 26, 2021 @VaZso To come back to my questions it seems your answers are as follow: Which hardware keyboard do you have? Qwertz Which keymap are you trying to use? Qwertz Which layout do you want to use? English US Which languages do you want to type in? Hungarian Your configuration is convoluted because you are trying to use the qwertz keymap together with a qwerty layout. For some keys the keymap makes the assumption that you are using the matching layout notably when the Fn key is issuing logical modifiers when associated with another key. My advise for the time being is similar to what @claude0001 suggested. Don't try fighting the standards try using the Hungarian layout that it provided by Android I reckon your "í" should be done using Sym+I or Sym+J. From there I suggested you could take the KCM for Hungarian and try improve it as you see fit in ways that are compatible with our driver. You could also define a custom keymap as explained at the beginning of that thread by @Sean McCreary, basically if you want to change the functions of Fn you need to define a custom keymap. However AFAICT there is a bug ATM and custom keymap do not work as they should, still it is possible to change it somehow by overwriting the driver file directly. Either way for custom keymap you will need root access as provided by Magisk. I know it is frustrating that Fn cannot be overridden from KCM but it seems that's how it is for now. Maybe we can improve on that later. I don't want to rush into greater changes when I have not even started using Lineage OS as my daily driver. I'm also somewhat reluctant to do driver changes involving QWERTZ as it is hard from me to test and validate them cause I don't have a QWERTZ hardware and I'm not a QWERTZ user. What ever solution you choose to settle for for now, know that it could still be improved upon in the future. Quote Link to post Share on other sites
Slion 1,201 Posted August 26, 2021 Share Posted August 26, 2021 (edited) 24 minutes ago, Pierre said: Fuck AZERTY. Burn AZERTY. Add accents to QWERTY Though I used it for years, old AZERTY really sucks. However I'm a big fan of the new AZERTY standards and have converted most of my keyboards. They are so convenient for international French like myself you can easily type in most every European language without having to look up ASCII codes 😁 Shame that nobody seems interested in adopting the new standards. French people are creature of habits and do get stuck in their old ways even though they don't make sense… so it seems 🤣 Edited August 26, 2021 by Slion 1 Quote Link to post Share on other sites
Slion 1,201 Posted August 26, 2021 Share Posted August 26, 2021 @Sean McCreary I've created a kernel pull request though I'm pretty sure that's not supposed to be happening on github but somewhere in Lineage gerrit. I have to take a look at the contribution process: https://github.com/LineageOS/android_kernel_fxtec_msm8998/pull/1 1 Quote Link to post Share on other sites
Rob. S. 1,667 Posted August 26, 2021 Share Posted August 26, 2021 6 hours ago, Hook said: 7 hours ago, Slion said: Does anyone knows why alt does not bring up the emoji keyboard on LOS like it did on stock? Using English(US) layout, it does (except with software that takes over the keyboard like Softmaker Office). This is strange; last time I tried, I could bring up the emoji selector by long-pressing alt on LOS 18.1, but right now I can't, no matter in which app. This is QWERTY with English (US) International keymap. 1 Quote Link to post Share on other sites
Hook 3,366 Posted August 26, 2021 Share Posted August 26, 2021 4 minutes ago, Rob. S. said: This is strange; last time I tried, I could bring up the emoji selector by long-pressing alt on LOS 18.1, but right now I can't, no matter in which app. This is QWERTY with English (US) International keymap. I switched my keyboard to US International and it seems to work for me. 1 Quote Link to post Share on other sites
Rob. S. 1,667 Posted August 26, 2021 Share Posted August 26, 2021 17 minutes ago, Hook said: I switched my keyboard to US International and it seems to work for me. Strange indeed. 1 Quote Link to post Share on other sites
Slion 1,201 Posted August 26, 2021 Share Posted August 26, 2021 (edited) 43 minutes ago, Hook said: I switched my keyboard to US International and it seems to work for me. I wonder if it depends on your virtual keyboard app. Right now I could get it to show up with the default keyboard. I'm pretty sure earlier it did not work with AnySoftKeyboad. Edited August 26, 2021 by Slion Quote Link to post Share on other sites
Slion 1,201 Posted August 26, 2021 Share Posted August 26, 2021 Did you guy ever get stuck in a mode where capslock is inverted? Like when capslock is on you get lowercase and when it is off you get uppercase. I'm testing my modified driver but I'm pretty sure I did not do break that as I did not touch handling of shifts or caps. Quote Link to post Share on other sites
VaZso 1,999 Posted August 26, 2021 Share Posted August 26, 2021 4 hours ago, claude0001 said: However, did you even consider to just use the provided QWERTZ layout as it is? All the special characters in your example sentence can be typed using the standard layout in LOS 16.0. On stock keyboard, I can't see á/Á, ő/Ő, ú/Ú, é/É, í/Í, ó/Ó, ű/Ű and sorry, it seems ű/Ű may be the unreachable character and not í/Í - so if I would use only characters written on Pro1's keyboard. 4 hours ago, claude0001 said: "ö" is available as a key of its own. "í", "é", and "á" can be typed using the dead-key function of "´" (i.e. "´" followed by "i", "e", or "a"). Yes, that is an option but it makes use of keyboard very ineffective (at least for me). 2 hours ago, Pierre said: You d be surprised how tolerant people are of 0 accent writing in French. Also people are tolerant on forums for writing without accents here, however, if I would write a business e-mail without accents, that would be a shame for me... 2 hours ago, Slion said: Which layout do you want to use? English US English US complemented by Hungarian. 3 hours ago, Slion said: From there I suggested you could take the KCM for Hungarian and try improve it as you see fit in ways that are compatible with our driver. As the driver is the low level, kcm (at higher level) can nothing to do if driver does not generate usable data for it. 3 hours ago, Slion said: You could also define a custom keymap as explained at the beginning of that thread by @Sean McCreary, basically if you want to change the functions of Fn you need to define a custom keymap. You are right, that is an option which I forgot it was included and looking at driver code, it has an option for it to load these arrays. I have also searched for it and found @tdmwrote about it here. It seems the function works through driver's exposed interface but if I create /persist/data/keyboard/keymap file it does not find it. Anyway, I dig a bit inside the code (still without Android studio) and found it checks it as /data/system/keyboard/keymap I don't know if there is something which copies it there upon boot from /persist/ directory, currently I run a search for it. 3 hours ago, Slion said: However AFAICT there is a bug ATM and custom keymap do not work as they should, still it is possible to change it somehow by overwriting the driver file directly. Hmm, okay, so it seems it may not copy to that partition. As in .java file, it searches it in /data/system/keyboard directory, it may be the reason. I don't know if it may not have read access to /persist directory or what is the reason it refers to this directory, but as it reaches qwerty/qwertz settings in /persist, it may only need a simple modification to work on /persist/data/keyboard/keymap instead. There is a file here: lineage/device/fxtec/pro1/devicesettings/src/org/lineageos/settings/device/Constants.java This file has the following definition (there is a macro which refers to this macro): KEYBOARD_KEYMAP_CFG_FILE = "/data/system/keyboard/keymap"; 3 hours ago, Slion said: I'm also somewhat reluctant to do driver changes involving QWERTZ as it is hard from me to test and validate them cause I don't have a QWERTZ hardware and I'm not a QWERTZ user. I understand it, however, basic modifications should apply for both layouts, the difference is the layout handling. Anyway, I have my friend's Pro1 with me for a few days (maybe early next week) for testing... so I have started a build thinking I may try some modifications and also try to set up Android Studio for that (I may need to look after how to do it properly to work on Android). I have fetched Android, I could extract binaries from my phone, started a build but failed. Do you know what the following message mean? Theoretically I was followed steps in WiKi and it is the most recent version, after resync, it has the same message. Quote ERROR: hardware/interfaces/automotive/occupant_awareness/aidl/aidl_api/android.hardware.automotive.occupant_awareness/1: No API file exist ############################################################################### # ERROR: Backward incompatible change detected on AIDL API # ############################################################################### Above AIDL file(s) has changed in a backward-incompatible way, e.g. removing a method from an interface or a field from a parcelable. If a device is shipped with this change by ignoring this message, it has a high risk of breaking later when a module using the interface is updated, e.g., Maineline modules. What do you think what may I do wrong? Quote Link to post Share on other sites
Rob. S. 1,667 Posted August 26, 2021 Share Posted August 26, 2021 12 minutes ago, Slion said: Did you guy ever get stuck in a mode where capslock is inverted? Yes, I did just a few minutes ago. 1 Quote Link to post Share on other sites
VaZso 1,999 Posted August 26, 2021 Share Posted August 26, 2021 (edited) 18 minutes ago, Slion said: Did you guy ever get stuck in a mode where capslock is inverted? I had this problem also on stock when Android did a soft restart and somehow caps lock was toggled before it (I think in closed state). That was during my software reboot-loop I think when kernel was still counting up but Android has restarted on top. So I don't think even if the keyboard driver is the reason. Edited August 26, 2021 by VaZso 1 Quote Link to post Share on other sites
VaZso 1,999 Posted August 26, 2021 Share Posted August 26, 2021 Interesting... if I also creates /data/system/keyboard/keymap file then it can be enabled in settings but it still does not take effect... still something needs to be checked. It takes effect if I manually pass the whole file to /sys/bus/i2c/drivers/aw9523b/6-0058/keymap 1 Quote Link to post Share on other sites
Slion 1,201 Posted August 26, 2021 Share Posted August 26, 2021 (edited) 1 hour ago, VaZso said: Interesting... if I also creates /data/system/keyboard/keymap file then it can be enabled in settings but it still does not take effect... still something needs to be checked. It takes effect if I manually pass the whole file to /sys/bus/i2c/drivers/aw9523b/6-0058/keymap That's what I was telling you earlier. That's the bug. I came to that same conclusion further up this thread. Edited August 26, 2021 by Slion Quote Link to post Share on other sites
Slion 1,201 Posted August 26, 2021 Share Posted August 26, 2021 (edited) 19 minutes ago, Rob. S. said: Yes, I did just a few minutes ago. Would be nice to find a way to reproduce this so that we can get it fixed. Was just trying to reproduce after reboot but no joy so far. Edited August 26, 2021 by Slion Quote Link to post Share on other sites
VaZso 1,999 Posted August 26, 2021 Share Posted August 26, 2021 2 minutes ago, Slion said: That's what I was telling you earlier. That's the bug. I came that same conclusion further up this thread. You are right, I have read that later on writing my message, sorry. 1 Quote Link to post Share on other sites
VaZso 1,999 Posted August 26, 2021 Share Posted August 26, 2021 4 hours ago, Slion said: @Sean McCreary I've created a kernel pull request though I'm pretty sure that's not supposed to be happening on github but somewhere in Lineage gerrit. I have to take a look at the contribution process: https://github.com/LineageOS/android_kernel_fxtec_msm8998/pull/1 Although the CPU is fast, generally it is better to keep the code simple. By calling a function, it needs stack handling and some amount of user memory handling, so calling a function several times in a row at driver level may not be advised. So by using need_forced_modifier() and modifier_forced() may be readable better, performance-wise it is better as it was - at this level a bit larger code may be better if it runs faster. I don't know if compiler optimizes it out or not however. 1 Quote Link to post Share on other sites
Slion 1,201 Posted August 26, 2021 Share Posted August 26, 2021 (edited) 31 minutes ago, VaZso said: Although the CPU is fast, generally it is better to keep the code simple. By calling a function, it needs stack handling and some amount of user memory handling, so calling a function several times in a row at driver level may not be advised. So by using need_forced_modifier() and modifier_forced() may be readable better, performance-wise it is better as it was - at this level a bit larger code may be better if it runs faster. I don't know if compiler optimizes it out or not however. I understand your concerns but: 1. Those functions are marked inline if the compiler does its job there will be no actual function call. 2. Even if they are not inlined there well be absolutely no impact whatsoever. It's not like they are being called 1000 times a second. Even that would not be a problem though. Thanks for the code review though, I appreciate the effort. Edited August 26, 2021 by Slion Quote Link to post Share on other sites
VaZso 1,999 Posted August 26, 2021 Share Posted August 26, 2021 3 minutes ago, Slion said: 1. Those functions are marked inline if the compiler does its job there will be no actual function call. Okay, it has an inline specifier. Anyway, I don't know why it complains me about AIDL CHECK API / "No API file exist" Maybe it has something to do with my host system. :S 1 Quote Link to post Share on other sites
Slion 1,201 Posted August 26, 2021 Share Posted August 26, 2021 (edited) 3 minutes ago, VaZso said: Anyway, I don't know why it complains me about AIDL CHECK API / "No API file exist" Maybe it has something to do with my host system. :S Does that break your build? If not I would not worry about it. Edited August 26, 2021 by Slion Quote Link to post Share on other sites
VaZso 1,999 Posted August 26, 2021 Share Posted August 26, 2021 Just now, Slion said: Does that break you build? If not I would not worry about it. I suspect it was what broke my build but a lot of row followed it where I could not find errors, but then... LD drivers/staging/built-in.o LD drivers/built-in.o LINK vmlinux LD vmlinux.o MODPOST vmlinux.o GEN .version CHK include/generated/compile.h UPD include/generated/compile.h CC init/version.o LD init/built-in.o KSYM .tmp_kallsyms1.o KSYM .tmp_kallsyms2.o LD vmlinux SORTEX vmlinux SYSMAP System.map OBJCOPY arch/arm64/boot/Image DTC arch/arm64/boot/dts/qcom/msm8998-v2-qrd-skuk-t5.dtb GZIP arch/arm64/boot/Image.gz CAT arch/arm64/boot/Image.gz-dtb make[1]: Leaving directory '/root/android/lineage/out/target/product/pro1/obj/KERNEL_OBJ' make: Leaving directory '/root/android/lineage/kernel/fxtec/msm8998' Building DTBs make: Entering directory '/root/android/lineage/kernel/fxtec/msm8998' make[1]: Entering directory '/root/android/lineage/out/target/product/pro1/obj/KERNEL_OBJ' CHK include/config/kernel.release GEN ./Makefile CHK include/generated/uapi/linux/version.h Using /root/android/lineage/kernel/fxtec/msm8998 as source for kernel CHK include/generated/utsrelease.h CHK scripts/mod/devicetable-offsets.h CHK include/generated/timeconst.h CHK include/generated/bounds.h CHK include/generated/asm-offsets.h CALL /root/android/lineage/kernel/fxtec/msm8998/scripts/checksyscalls.sh make[2]: 'include/generated/vdso-offsets.h' is up to date. make[2]: 'include/generated/vdso32-offsets.h' is up to date. DTC arch/arm64/boot/dts/qcom/msm8998-v2-qrd-skuk-t5.dtb DTC arch/arm64/boot/dts/qcom/msm8998-v2-qrd-skuk-t5-overlay.dtbo VERIFY arch/arm64/boot/dts/qcom/msm8998-v2-qrd-skuk-t5-overlay.dtbo ufdt_apply_overlay: took 0.243323000 secs make[1]: Leaving directory '/root/android/lineage/out/target/product/pro1/obj/KERNEL_OBJ' make: Leaving directory '/root/android/lineage/kernel/fxtec/msm8998' 15:22:38 ninja failed with: exit status 1 ninja: build stopped: subcommand failed. #### failed to build some targets (01:19:43 (hh:mm:ss)) #### real 79m44.550s user 572m13.108s sys 32m6.487s I don't know what subcommand it refers. If I run brunch pro1 again: [ 0% 4/67774] AIDL CHECK API: hardware/interfaces/automotive/occupant_awareness/aidl/aidl_api/android.hardware.automotive.occupant_awareness/current against hardware/interfaces/automotive/occupant_awareness/aidl/aidl_api/android.hardware.automotive.occupant_awareness/1 FAILED: out/soong/.intermediates/hardware/interfaces/automotive/occupant_awareness/aidl/android.hardware.automotive.occupant_awareness-api/checkapi_current.timestamp (out/soong/host/linux-x86/bin/aidl --stability vintf --checkapi hardware/interfaces/automotive/occupant_awareness/aidl/aidl_api/android.hardware.automotive.occupant_awareness/1 hardware/interfaces/automotive/occupant_awareness/aidl/aidl_api/android.hardware.automotive.occupant_awareness/current && touch out/soong/.intermediates/hardware/interfaces/automotive/occupant_awareness/aidl/android.hardware.automotive.occupant_awareness-api/checkapi_current.timestamp) || (cat system/tools/aidl/build/message_check_compatibility.txt && exit 1) ERROR: hardware/interfaces/automotive/occupant_awareness/aidl/aidl_api/android.hardware.automotive.occupant_awareness/1: No API file exist ############################################################################### # ERROR: Backward incompatible change detected on AIDL API # ############################################################################### Above AIDL file(s) has changed in a backward-incompatible way, e.g. removing a method from an interface or a field from a parcelable. If a device is shipped with this change by ignoring this message, it has a high risk of breaking later when a module using the interface is updated, e.g., Maineline modules. [ 0% 5/67774] AIDL CHECK API: hardware/interfaces/common/aidl/aidl_api/android.hardware.common/current against hardware/interfaces/common/aidl/aidl_api/android.hardware.common/1 FAILED: out/soong/.intermediates/hardware/interfaces/common/aidl/android.hardware.common-api/checkapi_current.timestamp (out/soong/host/linux-x86/bin/aidl --stability vintf --checkapi hardware/interfaces/common/aidl/aidl_api/android.hardware.common/1 hardware/interfaces/common/aidl/aidl_api/android.hardware.common/current && touch out/soong/.intermediates/hardware/interfaces/common/aidl/android.hardware.common-api/checkapi_current.timestamp) || (cat system/tools/aidl/build/message_check_compatibility.txt && exit 1) ERROR: hardware/interfaces/common/aidl/aidl_api/android.hardware.common/1: No API file exist ############################################################################### # ERROR: Backward incompatible change detected on AIDL API # ############################################################################### Above AIDL file(s) has changed in a backward-incompatible way, e.g. removing a method from an interface or a field from a parcelable. If a device is shipped with this change by ignoring this message, it has a high risk of breaking later when a module using the interface is updated, e.g., Maineline modules. [ 0% 6/67774] AIDL CHECK API: hardware/interfaces/graphics/common/aidl/aidl_api/android.hardware.graphics.common/current against hardware/interfaces/graphics/common/aidl/aidl_api/android.hardware.graphics.common/1 FAILED: out/soong/.intermediates/hardware/interfaces/graphics/common/aidl/android.hardware.graphics.common-api/checkapi_current.timestamp (out/soong/host/linux-x86/bin/aidl --stability vintf --checkapi hardware/interfaces/graphics/common/aidl/aidl_api/android.hardware.graphics.common/1 hardware/interfaces/graphics/common/aidl/aidl_api/android.hardware.graphics.common/current && touch out/soong/.intermediates/hardware/interfaces/graphics/common/aidl/android.hardware.graphics.common-api/checkapi_current.timestamp) || (cat system/tools/aidl/build/message_check_compatibility.txt && exit 1) ERROR: hardware/interfaces/graphics/common/aidl/aidl_api/android.hardware.graphics.common/1: No API file exist ############################################################################### # ERROR: Backward incompatible change detected on AIDL API # ############################################################################### Above AIDL file(s) has changed in a backward-incompatible way, e.g. removing a method from an interface or a field from a parcelable. If a device is shipped with this change by ignoring this message, it has a high risk of breaking later when a module using the interface is updated, e.g., Maineline modules. [ 0% 8/67774] AIDL CHECK API: hardware/interfaces/identity/aidl/aidl_api/android.hardware.identity/2 against hardware/interfaces/identity/aidl/aidl_api/android.hardware.identity/1 FAILED: out/soong/.intermediates/hardware/interfaces/identity/aidl/android.hardware.identity-api/checkapi_2.timestamp (out/soong/host/linux-x86/bin/aidl --stability vintf --checkapi hardware/interfaces/identity/aidl/aidl_api/android.hardware.identity/1 hardware/interfaces/identity/aidl/aidl_api/android.hardware.identity/2 && touch out/soong/.intermediates/hardware/interfaces/identity/aidl/android.hardware.identity-api/checkapi_2.timestamp) || (cat system/tools/aidl/build/message_check_compatibility.txt && exit 1) ERROR: hardware/interfaces/identity/aidl/aidl_api/android.hardware.identity/1: No API file exist ############################################################################### # ERROR: Backward incompatible change detected on AIDL API # ############################################################################### Above AIDL file(s) has changed in a backward-incompatible way, e.g. removing a method from an interface or a field from a parcelable. If a device is shipped with this change by ignoring this message, it has a high risk of breaking later when a module using the interface is updated, e.g., Maineline modules. [ 0% 9/67774] AIDL CHECK API: hardware/interfaces/identity/aidl/aidl_api/android.hardware.identity/current against hardware/interfaces/identity/aidl/aidl_api/android.hardware.identity/2 FAILED: out/soong/.intermediates/hardware/interfaces/identity/aidl/android.hardware.identity-api/checkapi_current.timestamp (out/soong/host/linux-x86/bin/aidl --stability vintf --checkapi hardware/interfaces/identity/aidl/aidl_api/android.hardware.identity/2 hardware/interfaces/identity/aidl/aidl_api/android.hardware.identity/current && touch out/soong/.intermediates/hardware/interfaces/identity/aidl/android.hardware.identity-api/checkapi_current.timestamp) || (cat system/tools/aidl/build/message_check_compatibility.txt && exit 1) ERROR: hardware/interfaces/identity/aidl/aidl_api/android.hardware.identity/2: No API file exist ############################################################################### # ERROR: Backward incompatible change detected on AIDL API # ############################################################################### Above AIDL file(s) has changed in a backward-incompatible way, e.g. removing a method from an interface or a field from a parcelable. If a device is shipped with this change by ignoring this message, it has a high risk of breaking later when a module using the interface is updated, e.g., Maineline modules. [ 0% 13/67774] Building Kernel Config make: Entering directory '/root/android/lineage/kernel/fxtec/msm8998' make[1]: Entering directory '/root/android/lineage/out/target/product/pro1/obj/KERNEL_OBJ' GEN ./Makefile # # configuration written to .config # make[1]: Leaving directory '/root/android/lineage/out/target/product/pro1/obj/KERNEL_OBJ' make: Leaving directory '/root/android/lineage/kernel/fxtec/msm8998' make: Entering directory '/root/android/lineage/kernel/fxtec/msm8998' make[1]: Entering directory '/root/android/lineage/out/target/product/pro1/obj/KERNEL_OBJ' GEN ./Makefile scripts/kconfig/conf --savedefconfig=defconfig Kconfig make[1]: Leaving directory '/root/android/lineage/out/target/product/pro1/obj/KERNEL_OBJ' make: Leaving directory '/root/android/lineage/kernel/fxtec/msm8998' 23:15:19 ninja failed with: exit status 1 #### failed to build some targets (5 seconds) #### Quote Link to post Share on other sites
VaZso 1,999 Posted August 27, 2021 Share Posted August 27, 2021 I feel a bit better as I have created a keymap file which I can load through kernel driver, however, I had to rewrite .kcm file to use AltGr instead of fn and also use AltGr in keymap file because keyboard driver currently does not support passing "FN" as function key. However, my custom layout works that way. It is still not a final solution as somehow it does not load it upon boot (I have to run it manually) and a rootless solution would be much better. Anyway, I have looked into the code and adding some options to advanced keyboard settings or adding physical layouts are seem to be really simple and straightforward. ...just I need to go through this build process on my own machine (find out what's wrong) and I can even test it if I can solve it till the end of this weekend. 1 Quote Link to post Share on other sites
