EskeRahn 5,598 Posted August 24, 2022 Share Posted August 24, 2022 @Spargeltim Just a wild idea if you have not sent it in. Have you tried with a FAST charger? (QC 3.0) It just MIGHT be able to provide it with that little extra needed (I do not know if the system handles fast charges that early, but could be worth a try) Quote Link to post Share on other sites
Tsunero 215 Posted August 27, 2022 Share Posted August 27, 2022 (edited) On 8/23/2022 at 8:41 AM, Spielverderber said: Good morning, the solution for me is: sending the new Pro1-X to the U.K. for exchange/repair/what ever. 😭 After nearly two years of waiting: quite disappointing. I wouldn't send it in, there is a high chance you won't see it for another year..or never. If it's indeed a battery depletion issue, just grab one from Ali or whatever and switch it out, it's easy to service. (or if you got the means, take out the original and give it some charge other way) Edited August 27, 2022 by Tsunero Quote Link to post Share on other sites
Rob. S. 1,667 Posted August 27, 2022 Share Posted August 27, 2022 46 minutes ago, Tsunero said: If it's indeed a battery depletion issue, just grab one from Ali or whatever and switch it out, it's easy to service. (or if you got the means, take out the original and give it some charge other way) Problem is, until now, the battery cannot be found anywhere but at Fxtec. Might actually be a unique design for them. On the other hand, I'd at least expect Fxtec to be able to ship batteries some time soon. 2 Quote Link to post Share on other sites
Hook 3,313 Posted August 27, 2022 Share Posted August 27, 2022 (edited) 2 hours ago, Tsunero said: I wouldn't send it in, there is a high chance you won't see it for another year..or never. Sorry, but based on an n=2, that's flatly false. First time I sent mine in, one month, second time was 6 months because they didn't have parts, but they were clear about that when I sent it in and I had it back 3 weeks after parts became available. They probably, as said, can supply the battery, but given it is a new phone under warranty and the exact nature of the problem hasn't been established, myself, I would send it in. They will tell you what to expect when you work out the trouble ticket with them before sending it in. Edited August 27, 2022 by Hook 1 Quote Link to post Share on other sites
Spielverderber 7 Posted October 31, 2022 Share Posted October 31, 2022 On 8/27/2022 at 7:59 PM, Tsunero said: I wouldn't send it in, there is a high chance you won't see it for another year..or never. If it's indeed a battery depletion issue, just grab one from Ali or whatever and switch it out, it's easy to service. (or if you got the means, take out the original and give it some charge other way) You were right. I should not have send it in. Now its two month because of a depleated battery and it does not look like I might have it back soon. They are "performing multiple charging and draining tests". But maybe the battery is really dead after a month of charging and draining 😭. 2 Quote Link to post Share on other sites
Danct12 58 Posted November 4, 2022 Share Posted November 4, 2022 On 10/31/2022 at 11:23 PM, Spielverderber said: You were right. I should not have send it in. Now its two month because of a depleated battery and it does not look like I might have it back soon. They are "performing multiple charging and draining tests". But maybe the battery is really dead after a month of charging and draining 😭. That doesn't look good, try contact them again and see what they respond. I've seen a few people on Discord got the same issue and got the phone back within a few weeks. 2 Quote Link to post Share on other sites
Casey 321 Posted November 4, 2022 Share Posted November 4, 2022 On 10/31/2022 at 4:23 PM, Spielverderber said: You were right. I should not have send it in. Now its two month because of a depleated battery and it does not look like I might have it back soon. They are "performing multiple charging and draining tests". But maybe the battery is really dead after a month of charging and draining 😭. Sorry for the delays. I have your device with me and it is fixed already. The reason we ask to keep it for longer is to help our developers debug the issue so it doesn't happen again. We're working with Snapdragon to resolve this problem and will soon be able to send back your phone. Again, thank you for your patience. 1 4 Quote Link to post Share on other sites
Spielverderber 7 Posted November 4, 2022 Share Posted November 4, 2022 24 minutes ago, Casey said: Sorry for the delays. I have your device with me and it is fixed already. The reason we ask to keep it for longer is to help our developers debug the issue so it doesn't happen again. We're working with Snapdragon to resolve this problem and will soon be able to send back your phone. Again, thank you for your patience. The problem is, that you did not ask wether you can keep it. You also did not tell me that you are going to keep it. You just told me, that it is fixed and this is one month ago. Normally one expects to get back the things you send in for repair. 🤷♂️ 3 Quote Link to post Share on other sites
Casey 321 Posted November 4, 2022 Share Posted November 4, 2022 Just now, Spielverderber said: The problem is, that you did not ask wether you can keep it. You also did not tell me that you are going to keep it. You just told me, that it is fixed and this is one month ago. Normally one expects to get back the things you send in for repair. 🤷♂️ I see. Things definitely were lost in translation here. As I wasn't the one handling your ticket, it appears my colleague left this out. Can you provide your ticket ID so I can follow up? 1 2 Quote Link to post Share on other sites
Spielverderber 7 Posted November 4, 2022 Share Posted November 4, 2022 14 minutes ago, Casey said: I see. Things definitely were lost in translation here. As I wasn't the one handling your ticket, it appears my colleague left this out. Can you provide your ticket ID so I can follow up? I send you the ticket number per pm. 1 1 Quote Link to post Share on other sites
Spielverderber 7 Posted December 8, 2022 Share Posted December 8, 2022 One month later.... nothing has happened. I still did not get my Pro1-x back. Unfortunately my OnePlus stopped working today - so I am without a mobile whilst I should have my Pro1-X since AUGUST! 2 Quote Link to post Share on other sites
Rasva 25 Posted December 9, 2022 Share Posted December 9, 2022 (edited) OK, so I seem to be in similar situation. Yesterday I left phone with about 70% battery, this morning is dead. No notification light, no reaction on the charger, no reaction for long holding of power button. But the phone was configured to charge when switched off. The only sign of life is when I connect it to PC via USB, it reports itself as QUSB_BULK_SN:xxxxxx Any suggestions? It seems to me that this QUSB_BULK device on USB suggests that the phone waits for initial factory flashing? Edit: phone was running on Sailfish Edited December 9, 2022 by Rasva 1 Quote Link to post Share on other sites
EskeRahn 5,598 Posted December 9, 2022 Share Posted December 9, 2022 4 hours ago, Rasva said: Any suggestions? It seems to me that this QUSB_BULK device on USB suggests that the phone waits for initial factory flashing? Seems bad... Googling a bit I found someone with a quite similar experience for a Pixel here. Have you tried holding the power button in for a very long time? (say 30-60 seconds), and see if anything happens at all? When connected to power it should attempt to charge -or with the silly default, that you had turned off- try to boot - and should show something on the display. Have you got a usb-meter? Like e.g. this. I'm wondering if it will draw any current at all when connected to a charger. Also try to look into the USB-port and see if e.g. some pocket lint could be causing troubles... Similar try a different cable, or check that the cable works with another device. (Yes I know I'm clutching at straws here, but just to eliminate potentially simple issues) Quote Link to post Share on other sites
Rasva 25 Posted December 9, 2022 Share Posted December 9, 2022 Yes, I wanted to use usb-c cable with power meter, when I will be back at home. So I connected it to fast USB PD charger with this cable and notification LED started to flash red immediately, cable was showing 4W load and after a minute phone came back to life with 15W fast charging. Now it is charging also when connected to PC or any other slow USB charger. So the conclusion is that some bug in Sailfish managed to completely discharge the phone in about 8 hours, battery management allowed to deep discharge the battery and apparently the only way to bring it back to life was fast USB-PD charger. (or of course removing the battery and "kickstarting it with DC power supply) 1 Quote Link to post Share on other sites
Name_not_avail 75 Posted December 9, 2022 Share Posted December 9, 2022 I have had the phone suddenly go black brick for no apparent reason, after leaving it on the table with a 70% or better charge. In my case, what worked was holding all three buttons (both volume and power) for about 30 seconds. That seemed to start a reboot cycle, as the Android image flashed up for a fraction of a second, but then stopped. I did the same again, and again I got the brief Android flash, then nothing. I then held the power button alone for about 30 seconds, and the phone booted normally. It showed 76% battery or something at that point. Good luck. 1 Quote Link to post Share on other sites
EskeRahn 5,598 Posted December 9, 2022 Share Posted December 9, 2022 3 hours ago, Name_not_avail said: I then held the power button alone for about 30 seconds, Yup, I have seen this do wonders too - I do not know exactly what it is doing but my guess it is as close to a cold reboot we get without a mechanical power-switch. There seems to be both a "long", and a "VERY long" hold-power in the menu of possibilities. I would guess one is about 8s+, and the other somewhere beyond 30s. Quote Link to post Share on other sites
Name_not_avail 75 Posted December 10, 2022 Share Posted December 10, 2022 The very long power button hold did not work the first time I tried it. Only after twice doing the "3 fingered salute" I described, did the power button hold (alone) suddenly work. Something weird about those brief boot attempts with the 3 fingered salute, seems to have enabled the long power button hold afterwards. 1 Quote Link to post Share on other sites
mattock 8 Posted December 30, 2022 Share Posted December 30, 2022 Is there really no way to get any charge into a flat battery? Since my repaired Pro1-X was returned, I've been waiting for updated ubports or lineageos, and thinking of maybe selling the phone altogether. So imagine my dismay when I come to turn it on and find it won't turn on OR charge! Tried the long power presses, and all key combinations suggested or listed elsewhere. No change. So my choice now is to try and un-expertly dismatle a brand new phone to charge the battery, or return it to fxtec AGAIN. Really? Oh dear oh dear oh dear. (I do try to be positive, but this is baaad.) 2 Quote Link to post Share on other sites
Rasva 25 Posted December 31, 2022 Share Posted December 31, 2022 If you connect it to a PC, does it report itself anyhow? See my two posts above what I mean. Quote Link to post Share on other sites
claude0001 1,424 Posted January 2, 2023 Share Posted January 2, 2023 On 12/30/2022 at 5:51 PM, mattock said: Is there really no way to get any charge into a flat battery? From this thread, it seems like you already know all there is to know. Still, here is my summary for any newcomers dropping in: For unknown reasons, F(x)tec ship their phones configured in a way that allows battery charging only with a running OS. If, by whatever circumstances, the battery charge ever drops to zero in that configuration, re-charging will no longer work, as this would require to first boot the OS which - in turn - would need at least some residual charge to be left in the battery. In that situation, the only way to re-charge is probably to disconnect the battery from the controller circuit and to energize it using a laboratory power supply (I haven't tried this). Imho, the first thing to do when you receive your F(x)tec phone (Pro1 or Pro1X alike!) is to connect to a PC, fire up fastboot, and do fastboot oem off-mode-charge 1 which will enable charging the battery with the device powered-off. 2 Quote Link to post Share on other sites
Rob. S. 1,667 Posted January 2, 2023 Share Posted January 2, 2023 (edited) Finally decided to enable off-mode charge on my Pro1 X, too, but while the fastboot connection itself does work, the specific command fails: $ fastboot devices c3156900 fastboot $ fastboot oem enable-charger-screen FAILED (remote: 'Command not supported in default implementation') fastboot: error: Command failed $ fastboot oem off-mode-charge 1 FAILED (remote: 'Command not supported in default implementation') fastboot: error: Command failed $ fastboot reboot Rebooting OKAY [ 0.000s] Finished. Total time: 0.805s Any ideas? Edit: Got back to my Pro1 where I hadn't applied the change yet, either, and there it worked: $ fastboot devices da51126d fastboot $ fastboot oem enable-charger-screen OKAY [ 0.004s] Finished. Total time: 0.004s $ fastboot oem off-mode-charge 1 OKAY [ 0.000s] Finished. Total time: 0.000s $ fastboot reboot Rebooting OKAY [ 0.000s] Finished. Total time: 0.101s Edited January 2, 2023 by Rob. S. Quote Link to post Share on other sites
EskeRahn 5,598 Posted January 2, 2023 Share Posted January 2, 2023 3 hours ago, Rob. S. said: Any ideas? Weird, works on a Pro1X here.... Are you at the standard bootloader menu that can be reached with this?adb reboot bootloader If I write say "On" instead of the "1" I get an error BUT a different text:FAILED (remote: 'Invalid input entered') And if I change the command-name I getFAILED (remote: 'unknown command') So it seems that the it sees your command, but report it as not supported, so could be a different fastboot-menu - If I do recall incorrectly, there is another one with tiny text that can be reached by another key-combo than the usual: VolDown while holding power. Quote Link to post Share on other sites
VaZso 1,999 Posted January 2, 2023 Share Posted January 2, 2023 3 hours ago, Rob. S. said: Any ideas? If I remember well, it worked after I have allowed ADB connection of my PC (there is a notification appears with a "MAC-address" where you can tick to remember). I don't know if fastboot has anything to do with ADB but I could enable offline charging of my Pro1X afterwards. Quote Link to post Share on other sites
EskeRahn 5,598 Posted January 2, 2023 Share Posted January 2, 2023 Found it. The problem is if you only take the first part here: On 8/6/2022 at 2:16 AM, matf-kabouik said: - Pick your clacky Pro1x, power it down, hold down [Volume -] and [Power] until it boots. It will show a dead droid logo. From there, hold [Power] and without releasing it, hit [Volume +] briefly with another finger. From the menu that just appeared, select Bootloader. The phone will reboot into bootloader mode. Plug it to your computer, then from the PC: If you go in by the "Enter fastboot" this way will give exactly the reportedFAILED (remote: 'Command not supported in default implementation') fastboot: error: Command failed But if you choose "Reboot to bootloader" you wlil get to the menu where it works.OKAY [ 0.000s] Finished. Total time: 0.000s 4 Quote Link to post Share on other sites
Rob. S. 1,667 Posted January 2, 2023 Share Posted January 2, 2023 Yay! Worked! 1 Quote Link to post Share on other sites
