mangled 26 Posted July 25, 2023 Share Posted July 25, 2023 Hi, Anyone using this as a daily driver on pro1x? Is the camera and GPS working OK? Quote Link to post Share on other sites
steeb 28 Posted July 26, 2023 Share Posted July 26, 2023 12 hours ago, mangled said: Hi, Anyone using this as a daily driver on pro1x? Is the camera and GPS working OK? The GPS works about as well as it does in Android/Lineage and I find Pure Maps to be a reasonable navigation app as long as you pitch in on OpenStreetMaps. The camera, however, doesn't work out of the box. After installing `pinhole` the camera works but is NOT full-featured. The experience outside of the camera (and broken convergence) is smoother than on my Librem 5, but it's certainly not fully polished. Quote Link to post Share on other sites
mangled 26 Posted July 30, 2023 Share Posted July 30, 2023 On 7/25/2023 at 9:59 PM, steeb said: The GPS works about as well as it does in Android/Lineage and I find Pure Maps to be a reasonable navigation app as long as you pitch in on OpenStreetMaps. The camera, however, doesn't work out of the box. After installing `pinhole` the camera works but is NOT full-featured. The experience outside of the camera (and broken convergence) is smoother than on my Librem 5, but it's certainly not fully polished. There's been tweets about megapixel app working with some android devices on post market os. I'm curiouse if it would work on this device. Quote Link to post Share on other sites
mangled 26 Posted September 19, 2023 Share Posted September 19, 2023 https://droidian.org/blog/state-of-droidian-week-36-2023/ Latest developments in Droidian includes fixes to the camera stack. Has anyone been able to record video on pro1x? 1 Quote Link to post Share on other sites
mangled 26 Posted October 31, 2023 Share Posted October 31, 2023 I would like to make the switch to Droidian though the camera is a huge factor for me. Is there anyone here that can confirm if camera works. Is it possible to record video? If not through the OS, can you record or use camera through waydroid? Quote Link to post Share on other sites
Tomatoman29 11 Posted November 23, 2023 Share Posted November 23, 2023 If Droidian would work better with Pro1 I would choose it as my daily driver. At this moment, OS is so choppy on the original Pro1 it's just unusable. 1 Quote Link to post Share on other sites
mangled 26 Posted June 7, 2024 Share Posted June 7, 2024 Hi how is this os today? Quote Link to post Share on other sites
ralpholzer 1 Posted August 28, 2024 Share Posted August 28, 2024 Hi! I Installed it last weekend, the latest verion i have found, from: api30-arm64-next_20240823.zip I have some fundamental problems with it: I did not mange to set my network connection APN or even the time: I can enter the values in the GUI, but there is now button that sayes: OK or Save, even the Back-Button does not work... The phone is responsing and working, there is just now way to save the settings... Any idea how this works? Thanks Ralph Quote Link to post Share on other sites
ralpholzer 1 Posted August 28, 2024 Share Posted August 28, 2024 (edited) On 10/31/2023 at 5:25 PM, mangled said: I would like to make the switch to Droidian though the camera is a huge factor for me. Is there anyone here that can confirm if camera works. Is it possible to record video? If not through the OS, can you record or use camera through waydroid? Camera is working, but if I take a picture, nothing happends, the button just changes the colour to grey. The picture is not saved anywhere... Same with the video mode Edited August 28, 2024 by ralpholzer spelling Quote Link to post Share on other sites
mangled 26 Posted August 28, 2024 Share Posted August 28, 2024 (edited) Have you tried to extend partition? Edited August 28, 2024 by mangled Quote Link to post Share on other sites
ralpholzer 1 Posted August 29, 2024 Share Posted August 29, 2024 23 hours ago, mangled said: Have you tried to extend partition? No. Should I ? If yes how and which partiton? There are 3 mountpoints that are shown as 100% usage: /android /dev/mapper/dynpart-system_ext_a /dev/mapper/dynpart-product_a All other have planty of space. Quote Link to post Share on other sites
mangled 26 Posted August 29, 2024 Share Posted August 29, 2024 (edited) 4 hours ago, ralpholzer said: No. Should I ? If yes how and which partiton? There are 3 mountpoints that are shown as 100% usage: /android /dev/mapper/dynpart-system_ext_a /dev/mapper/dynpart-product_a All other have planty of space. I found a quick troubleshoot. Is your userdata ext4? If not you need to format it. fastboot format:ext4 userdata https://github.com/droidian-images/droidian Someone in the past had an issue with partitions as well and confirmed reflashing them in fastboot had fixed it. You will lose your data. Edited August 29, 2024 by mangled Quote Link to post Share on other sites
ralpholzer 1 Posted August 30, 2024 Share Posted August 30, 2024 (edited) 14 hours ago, mangled said: Someone in the past had an issue with partitions as well and confirmed reflashing them in fastboot had fixed it. You will lose your data. I do not have any data to lose, but his problem was: "If the image does not boot and your userdata is not an ext4 partition, you might try formatting it." I have many ext4 partitions the firmware and some android vendor partitions are vfat and mountpoints with fuse and tracefs So its not in any way related, it will not bring back any missing buttons. At the moment Doridian is not useable in any way, no Mobile Internet connection, missing buttons wrong time, missing buttons Cam does not save pictures Firefox is crashing at startup no updates for any packets even if you fix the EXPKEYSIG-Problem (many broken packages) I have no idea why it was listed under supported in the last FXTEC Newsletter. Working: Shell, keyboard and Wifi Edited August 30, 2024 by ralpholzer 1 Quote Link to post Share on other sites
zegoo 13 Posted August 30, 2024 Share Posted August 30, 2024 Should it be coming from rights issues ? As if you could not write somewhere needed by apps... WhiteList xml files ? Quote Link to post Share on other sites
zegoo 13 Posted October 30, 2024 Share Posted October 30, 2024 Hi All. I would like to install Droidian on my Pro1x but i'm under LOS21. I need to roll back the OS to Android 11 Stock. So does someone knows how much time it takes to @Casey to allow access on their Google files's sharings ? Or, is there someone with the files needed to share ? Quote Link to post Share on other sites
Hook 3,315 Posted October 30, 2024 Share Posted October 30, 2024 On Sunday, Casey communicated to me that he had all the files and would create new links "Next week." I don't know if that meant the week we are in or really next week. I suspect it hasn't been quicker because he is not where he can easily take care of this. But it will happen. There is someone in our unofficial Discord who is currently sharing the files on Proton Drive if you are impatient. That's where you would want to ask questions about it. 3 Quote Link to post Share on other sites
zegoo 13 Posted October 30, 2024 Share Posted October 30, 2024 Hi @Hookand thanks for your reply. I was not aware regarding the 'Our' Unofficial Dicsord. I'm going to take a look... 2 Quote Link to post Share on other sites
Hook 3,315 Posted October 30, 2024 Share Posted October 30, 2024 3 hours ago, zegoo said: Hi All. I would like to install Droidian on my Pro1x but i'm under LOS21. I need to roll back the OS to Android 11 Stock. So does someone knows how much time it takes to @Casey to allow access on their Google files's sharings ? Or, is there someone with the files needed to share ? The links were all just restored, so you should be able to get everything from the forum here again. :) 3 Quote Link to post Share on other sites
EskeRahn 5,598 Posted October 30, 2024 Share Posted October 30, 2024 4 hours ago, Hook said: The links were all just restored, so you should be able to get everything from the forum here again. 🙂 Great news, thanks@Casey 1 Quote Link to post Share on other sites
suicidal_orange 103 Posted November 30, 2024 Share Posted November 30, 2024 Just in case anyone else hits this error when running flash_all.sh: Sending sparse 'userdata' 1/5 (765895 KB) OKAY [ 16.362s] Writing 'userdata' FAILED (remote: 'Flashing of userdata is not allowed in snapshotted state') fastboot: error: Command failed The fix is this fastboot snapshot-update cancel 1 2 Quote Link to post Share on other sites
mangled 26 Posted December 4, 2024 Share Posted December 4, 2024 What is the current state of the os? Quote Link to post Share on other sites
suicidal_orange 103 Posted December 5, 2024 Share Posted December 5, 2024 On 12/4/2024 at 5:20 PM, mangled said: What is the current state of the os? The instructions worked fine once I fixed the snapshot thing, as above. Without knowing what your expectations are it's hard to say much more 🙃 Quote Link to post Share on other sites
claude0001 1,424 Posted December 5, 2024 Share Posted December 5, 2024 1 hour ago, suicidal_orange said: Without knowing what your expectations are [...] Camera functionality seems to be important to @mangled. The device pages for Pro1 and Pro1X still state camera stack to be unstable and video recording not to work at all. So I guess the question is whether this information is up to date. Beyond that, here as well as on discord, users reported many more issues related to things fundamental to daily phone use, like mobile connectivity, battery life, and stability of core apps. Those problems are not mentioned at all on the project page, which lists the Pro1 and Pro1X as "officially supported". A brief, but honest, report about how usable Droidian is as daily driver on the Pro1/Pro1X would be very interesting, indeed. 1 Quote Link to post Share on other sites
