phoebus2000 7 Posted August 26, 2022 Share Posted August 26, 2022 My new Pro2X had a problem on that it doesn't always charge at night. Over the past four nights it failed to charge on two of them until i rebooted (and the second time in didn't spot until the morning when it has died). I used the supplied charger and other ones, tested with other phones which charged. Any advice? 1 Quote Link to post Share on other sites
phoebus2000 7 Posted August 26, 2022 Author Share Posted August 26, 2022 *Pro1X obviously. Not sure why it changed it! Quote Link to post Share on other sites
EskeRahn 5,604 Posted August 26, 2022 Share Posted August 26, 2022 see other threads... known android issue 11/12 isssue on many devices.ADD see e.g. this hopefully they will add workaround soon Quote Link to post Share on other sites
Logan 22 Posted August 27, 2022 Share Posted August 27, 2022 Yeah I've seen this on my Pixel2XL which has Linage 18.1, so certainly not a Pro1-X issue alone. 1 Quote Link to post Share on other sites
EskeRahn 5,604 Posted August 27, 2022 Share Posted August 27, 2022 ...But as e.g. Nokia did a workaround for their device, it is a bug that can be circumvented. I do not know if the details of this fix is open, so it is 'just' a matter of FxTec implementing it in an OTA update, or they will have to 'reinvent the wheel' here... It is NOT a fix that is so common/open that it is part of e.g. Lineage 18 or 19 for the Pro1 that see the same issue (That was not there for Lineage 16, nor stock 9). Quote Link to post Share on other sites
Rob. S. 1,667 Posted August 27, 2022 Share Posted August 27, 2022 (edited) It might be interesting to see if that non-charging state of the Pro1X is displayed as 'not charging' instead of 'discharging' in AccA (which would need a rooted device with ACC/AccA installed, which I haven't done yet as I seem to get along quite well with unrooted stock), too, as it used to be with the Pro1. As of now, I haven't experienced charging issues on the Pro1X myself. Edited August 27, 2022 by Rob. S. 1 Quote Link to post Share on other sites
phoebus2000 7 Posted August 28, 2022 Author Share Posted August 28, 2022 (edited) Interesting, thanks I hadn't realised that such a bug would be an Android wide problem. I was on Android 9 before this. It's crazy that such a major issue hasn't been fixed by Android yet. Did have me worried that I'd have to part with my new phone if I couldn't rely on it charging but it seems that others are also affected. Edited August 28, 2022 by phoebus2000 1 Quote Link to post Share on other sites
foxfreejack 60 Posted August 28, 2022 Share Posted August 28, 2022 Interesting indeed, but what's puzzling to me is how much the OS is managing charging nowadays... I feel it should be less, but huh... progress I guess... 1 Quote Link to post Share on other sites
Tsunero 215 Posted September 3, 2022 Share Posted September 3, 2022 On 8/28/2022 at 9:19 PM, phoebus2000 said: Interesting, thanks I hadn't realised that such a bug would be an Android wide problem. I was on Android 9 before this. It's crazy that such a major issue hasn't been fixed by Android yet. Did have me worried that I'd have to part with my new phone if I couldn't rely on it charging but it seems that others are also affected. My OG Pro 1 does it too (still on Android 9 lmao, I am so lazy..). Thought I just had a dying charging port but it has been like that since day 1, it charges fine 95% of the time despite me giving it heavy abuse these past 2 years. Quote Link to post Share on other sites
EskeRahn 5,604 Posted September 3, 2022 Share Posted September 3, 2022 4 hours ago, Tsunero said: My OG Pro 1 does it too (still on Android 9 lmao, I am so lazy..). Thought I just had a dying charging port but it has been like that since day 1, it charges fine 95% of the time despite me giving it heavy abuse these past 2 years. Interesting. Just to be sure: Is it completely ignoring the attached charger, or powering the device without charging the battery? (that is, is the battery indicator more or less stable or dropping as if unplugged in this state?) If ignoring completely, you could have a defect on port/cable/charger or merely some pocketlint in the port Quote Link to post Share on other sites
Tsunero 215 Posted September 3, 2022 Share Posted September 3, 2022 9 hours ago, EskeRahn said: Interesting. Just to be sure: Is it completely ignoring the attached charger, or powering the device without charging the battery? (that is, is the battery indicator more or less stable or dropping as if unplugged in this state?) If ignoring completely, you could have a defect on port/cable/charger or merely some pocketlint in the port The indicator light is on but it just doesn't charge sometimes. A couple tries fixes it. (but yeah it's possible I got some gunk in there as well) 1 Quote Link to post Share on other sites
EskeRahn 5,604 Posted September 3, 2022 Share Posted September 3, 2022 6 hours ago, Tsunero said: The indicator light is on but it just doesn't charge sometimes. A couple tries fixes it. (but yeah it's possible I got some gunk in there as well) Sound like something similar, but different. It is the first time i heard of it on 9, s[ I think it is hardware not software. With a little luck mere dirt. I would try to take a magnifying glass and look into the port, if nothing visible, try another cable Quote Link to post Share on other sites
pistikem 86 Posted September 4, 2022 Share Posted September 4, 2022 23 hours ago, Tsunero said: The indicator light is on but it just doesn't charge sometimes. A couple tries fixes it. (but yeah it's possible I got some gunk in there as well) same issue here - need then to re-attach the charger cable. i usually check now on the screen if the percent power left is increasing after a minute or so of charging... 1 Quote Link to post Share on other sites
Bob78 0 Posted December 20, 2022 Share Posted December 20, 2022 I have this problem with my pro1 really bad .umpteen goes to get it to. Charge seems physical to me motherboard fault. Any ideas on fix much same on any cable started from new but very bad now Quote Link to post Share on other sites
Adrienspawn 126 Posted December 22, 2022 Share Posted December 22, 2022 Same issue with original pro 1. Needs a restart. No clue. Quote Link to post Share on other sites
Adrienspawn 126 Posted May 19, 2023 Share Posted May 19, 2023 Hah. Back a few months later curious about the issue again on LOS20. Quote Link to post Share on other sites
brunoais 335 Posted May 22, 2023 Share Posted May 22, 2023 (edited) I have this problem sometimes but I think it's caused by ACC. It appears like there's some bugs in the custom android kernel which doesn't like when some of the settings inside /sys are used. I'm still probing because this only happens to me many hours after I start charging. However, if you have root permissions, this script works well for me: echo 1 > /sys/class/power_supply/battery/input_current_limited echo 0 > /sys/class/power_supply/battery/input_suspend echo 2 > /sys/class/power_supply/battery/charge_control_limit I appear to only need it if I have the phone connected to the PC for charging (how I usually charge). I haven't had issues when connected to the wall charger. @Adrienspawn If you have rooted (or can adb root) see if that script solves. Otherwise, the issue is something different than me. Ofc, this is still sth that needs to be fixed in the kernel. Edited May 22, 2023 by brunoais 1 1 Quote Link to post Share on other sites
Adrienspawn 126 Posted May 24, 2023 Share Posted May 24, 2023 On 5/22/2023 at 7:17 AM, brunoais said: I have this problem sometimes but I think it's caused by ACC. It appears like there's some bugs in the custom android kernel which doesn't like when some of the settings inside /sys are used. I'm still probing because this only happens to me many hours after I start charging. However, if you have root permissions, this script works well for me: echo 1 > /sys/class/power_supply/battery/input_current_limited echo 0 > /sys/class/power_supply/battery/input_suspend echo 2 > /sys/class/power_supply/battery/charge_control_limit I appear to only need it if I have the phone connected to the PC for charging (how I usually charge). I haven't had issues when connected to the wall charger. @Adrienspawn If you have rooted (or can adb root) see if that script solves. Otherwise, the issue is something different than me. Ofc, this is still sth that needs to be fixed in the kernel. Looks like I keep losing Magisk/root every time I update Lineage using their automated updater, but once I figure out how to do it smoothly I'll try it thanks. 2 Quote Link to post Share on other sites
Hook 3,368 Posted May 24, 2023 Share Posted May 24, 2023 1 hour ago, Adrienspawn said: Looks like I keep losing Magisk/root every time I update Lineage using their automated updater, but once I figure out how to do it smoothly I'll try it thanks. I believe you have to flash Magisk as a zip in recovery the first time and then set it up in Magisk Manager in order for root to survive OTAs. If that's what you did, then I don't know. 1 Quote Link to post Share on other sites
Adrienspawn 126 Posted June 6, 2023 Share Posted June 6, 2023 On 5/24/2023 at 10:18 AM, Hook said: I believe you have to flash Magisk as a zip in recovery the first time and then set it up in Magisk Manager in order for root to survive OTAs. If that's what you did, then I don't know. Turns out I just needed to install the OTA but before rebooting, click 'install to slot' in Magisk Manager. That way it manages to dodge the reset and reinsert itself during the reboot. Neat. I'm old. Quote Link to post Share on other sites
Hook 3,368 Posted June 6, 2023 Share Posted June 6, 2023 14 minutes ago, Adrienspawn said: Turns out I just needed to install the OTA but before rebooting, click 'install to slot' in Magisk Manager. That way it manages to dodge the reset and reinsert itself during the reboot. Neat. I'm old. I'm 70. Does that count as old? 😉 Quote Link to post Share on other sites
EvilDNA127 39 Posted June 6, 2023 Share Posted June 6, 2023 5 hours ago, Hook said: I'm 70. Does that count as old? 😉 You're only as old as you feel. 😉 1 Quote Link to post Share on other sites
Hook 3,368 Posted June 7, 2023 Share Posted June 7, 2023 5 hours ago, EvilDNA127 said: You're only as old as you feel. 😉 Then, no, I'm not old. Just ask Mrs. Hook 😄 2 Quote Link to post Share on other sites
phoebus2000 7 Posted July 10, 2023 Author Share Posted July 10, 2023 I sent my Pro1X back and it they made some changes but I still can't get it to charge from a low-voltage adaptor, which is frustrating. It charges for a minute or two and that's it. This problem is when connected to a wall charger, not a PC/Mac connection. 2 Quote Link to post Share on other sites
