Hook 3,318 Posted July 5, 2021 Share Posted July 5, 2021 (edited) Update to lineage-18.1-20210705-nightly-pro1-signed with the June 5th security patch with Magisk 23.0 and MindTheGapps-11.0.0-arm64-20210412_124247 completed successfully via adb sideload Edited July 5, 2021 by Hook Haha grabbed the wrong file name 2 Quote Link to post Share on other sites
Rob. S. 1,667 Posted July 7, 2021 Share Posted July 7, 2021 On 7/5/2021 at 5:27 PM, Hook said: Update to lineage-18.1-20210705-nightly-pro1-signed with the June 5th security patch with Magisk 23.0 and MindTheGapps-11.0.0-arm64-20210412_124247 completed successfully via adb sideload Success here with OTA update, too, which kept Magisk and MindThe Gapps as they were. 3 1 Quote Link to post Share on other sites
Hook 3,318 Posted July 7, 2021 Share Posted July 7, 2021 6 minutes ago, Rob. S. said: Success here with OTA update, too, which kept Magisk and MindThe Gapps as they were. I'm pretty sure I don't really need to reflash Magisk or Gapps each time, but it's quick and easy, so I do. 🙂 1 Quote Link to post Share on other sites
TeZtdevice 368 Posted July 12, 2021 Share Posted July 12, 2021 lineage-18.1-20210712-nightly-pro1-signed.zip on June 5 2021 security patch installed smoothly using OTA 2 Quote Link to post Share on other sites
Hook 3,318 Posted July 12, 2021 Share Posted July 12, 2021 I did OTA for the first time rather than ADB and it works great. And, yes, root is preserved. 2 Quote Link to post Share on other sites
EskeRahn 5,598 Posted July 12, 2021 Share Posted July 12, 2021 (lineage-18.1-20210712-nightly-pro1-signed.zip on June 5 security patch installed smoothly using adb sideload and MindTheGapps-11.0.0-arm64-20210412_124247) Then redid with the new OpenGapps 11, Including a WIPE of the user data! (lineage-18.1-20210712-nightly-pro1-signed.zip on June 5 security patch installed smoothly using adb sideload and Open_Gapps-arm64-11-pico-20210712) 3 Quote Link to post Share on other sites
pebert 98 Posted July 14, 2021 Share Posted July 14, 2021 I have installed both lineage-18.1-20210614-nightly-pro1-signed and lineage-18.1-20210712-nightly-pro1-signed both of them acting strange, when I try to make a phone call, the dialer app doesn´t go into the call active mode, but stays as it was before pressing the green handset. nothing in the status bar show an active call either, so only way the end the call is to power off the phone. then Some Microsoft Office 365 apps won´t start, like Onedrive and excel, but Teams and sharepoint works fine. this issue was seen on the 20210614 build, stayed when doing an OTA upgrade, but dissapeared when doing a factory reset- Quote Link to post Share on other sites
Hook 3,318 Posted July 14, 2021 Share Posted July 14, 2021 56 minutes ago, pebert said: I have installed both lineage-18.1-20210614-nightly-pro1-signed and lineage-18.1-20210712-nightly-pro1-signed both of them acting strange, when I try to make a phone call, the dialer app doesn´t go into the call active mode, but stays as it was before pressing the green handset. nothing in the status bar show an active call either, so only way the end the call is to power off the phone. then Some Microsoft Office 365 apps won´t start, like Onedrive and excel, but Teams and sharepoint works fine. this issue was seen on the 20210614 build, stayed when doing an OTA upgrade, but dissapeared when doing a factory reset- All I can address is that on mine , the dialer app is fine. I don't have any Microsoft apps. Quote Link to post Share on other sites
pebert 98 Posted July 15, 2021 Share Posted July 15, 2021 can someone help me setting up the development environment for building lineage OS for Pro1? 1 Quote Link to post Share on other sites
claude0001 1,424 Posted July 15, 2021 Share Posted July 15, 2021 (edited) 6 hours ago, pebert said: can someone help me setting up the development environment for building lineage OS for Pro1? The instructions in the LineageOS wiki are really good. Just follow them and make sure not to miss any steps: https://wiki.lineageos.org/devices/pro1/build It is really not that hard. I have been self-building LOS 16.0 without issues for some time now, although I understand next to nothing about the internals of the build system ... Even if you have some Linux running on your main PC already, I strongly suggest to set up a dedicated VM with the latest Ubuntu LTS to stay as close as possible to the recommended environment. Ubuntu Server is sufficient btw. (and much easier on your VM), you won't need any GUI tools. Make sure to assign enough disk space, though. Although the final ROMs are only ~600 MB, the sources and building process easily consume around 150 GB. The build will fail if it runs out of disk space. CPU and RAM are less critical than the wiki suggests: My VM has only 3 cores and 6 GB. Builds take 10-12 h, including download of the sources over a 100 Mbit/s line. Edited July 15, 2021 by claude0001 4 1 Quote Link to post Share on other sites
Hook 3,318 Posted July 19, 2021 Share Posted July 19, 2021 The July 19th update with the July 2021 security patch installed smoothly via OTA. Root retained. 2 Quote Link to post Share on other sites
EskeRahn 5,598 Posted July 19, 2021 Share Posted July 19, 2021 (lineage-18.1-20210719-nightly-pro1-signed.zip on July 5 security patch installed smoothly using adb sideload and Open_Gapps-arm64-11-pico-20210712) 3 Quote Link to post Share on other sites
benoitjeffrey 66 Posted July 23, 2021 Share Posted July 23, 2021 (edited) On 7/14/2021 at 9:30 AM, pebert said: When I try to make a phone call, the dialer app doesn´t go into the call active mode, but stays as it was before pressing the green handset. nothing in the status bar show an active call either, so only way the end the call is to power off the phone. Hi, i can't help for the office thing but I had the same trouble for the phone app. It looks stupid but there is no default phone app selected so it just don't know what to do with calls. Go in apps settings, select default apps and phone is probably empty and it shouldn't be, which was the case for me. Edited July 24, 2021 by benoitjeffrey Typo 2 1 Quote Link to post Share on other sites
TeZtdevice 368 Posted July 26, 2021 Share Posted July 26, 2021 lineage-18.1-20210726-nightly-pro1-signed.zip on July 5 2021 security patch installed smoothly using OTA ....and the input issue is solved!! AMAZING JOB!! https://gitlab.com/LineageOS/issues/android/-/issues/3321https://review.lineageos.org/c/LineageOS/android_frameworks_native/+/312770/3#message-38cd89dc8bbd979418ae520841df099f05831d8a Special thanks to @EskeRahn and @Sean McCreary 3 1 Quote Link to post Share on other sites
EskeRahn 5,598 Posted July 26, 2021 Share Posted July 26, 2021 (lineage-18.1-20210726-nightly-pro1-signed.zip on July 5 security patch installed smoothly using adb sideload and Open_Gapps-arm64-11-pico-20210712) 1 Quote Link to post Share on other sites
EskeRahn 5,598 Posted July 26, 2021 Share Posted July 26, 2021 42 minutes ago, TeZtdevice said: ...and the input issue is solved!! AMAZING JOB!! Good news! Indeed thanks to @Sean McCreary again. 👍 2 Quote Link to post Share on other sites
pebert 98 Posted July 28, 2021 Share Posted July 28, 2021 On 7/23/2021 at 2:08 PM, benoitjeffrey said: can't help for the office thing but I had the same trouble for the phone app. It looks stupid but there is no default phone app selected so it just don't know what to do with calls. Go in apps settings, select default apps and phone is probably empty and it shouldn't be, which was the case for me. After installing LineageOS 16 and then back to 18.1 together wit nikgapps core it works like a charm. 1 Quote Link to post Share on other sites
Sean McCreary 328 Posted July 30, 2021 Share Posted July 30, 2021 On 7/26/2021 at 1:19 AM, TeZtdevice said: lineage-18.1-20210726-nightly-pro1-signed.zip on July 5 2021 security patch installed smoothly using OTA ....and the input issue is solved!! AMAZING JOB!! https://gitlab.com/LineageOS/issues/android/-/issues/3321https://review.lineageos.org/c/LineageOS/android_frameworks_native/+/312770/3#message-38cd89dc8bbd979418ae520841df099f05831d8a Special thanks to @EskeRahn and @Sean McCreary Users on other devices reported problems with the touchscreen after this change when using certain apps. Consequently, it has been pulled for now :-( If we can fix the problems with the touchscreen, it will be resubmitted and merged again. This means next week's build will have the old bug. If this will cause you problems, please don't update until the August security patches have been merged. With luck we will have a fix by then :-) 1 3 Quote Link to post Share on other sites
TeZtdevice 368 Posted July 30, 2021 Share Posted July 30, 2021 3 hours ago, Sean McCreary said: Users on other devices reported problems with the touchscreen after this change when using certain apps. Consequently, it has been pulled for now 😞 If we can fix the problems with the touchscreen, it will be resubmitted and merged again. This means next week's build will have the old bug. If this will cause you problems, please don't update until the August security patches have been merged. With luck we will have a fix by then 🙂 Thanks a lot! Yes, I read the new changelog and I won´t update my system 🙂 1 Quote Link to post Share on other sites
EskeRahn 5,598 Posted August 9, 2021 Share Posted August 9, 2021 (lineage-18.1-20210809-nightly-pro1-signed.zip on August 5 security patch installed smoothly using adb sideload and Open_Gapps-arm64-11-pico-20210712) ...But keyboard bug reintroduced is not yet fixed, see comment from @Sean McCreary above. Did not try to do a factory reset first... But did try to flash back to 0726, and that claimed the data to be corrupt, so was forced to reset... So made a third flash WITH a wipe... and that did not work with the 0809, so went back to 0726, with another wipe required. And things work again. I hope for better luck next week . 😇 1 Quote Link to post Share on other sites
Sean McCreary 328 Posted August 9, 2021 Share Posted August 9, 2021 7 hours ago, EskeRahn said: (lineage-18.1-20210809-nightly-pro1-signed.zip on August 5 security patch installed smoothly using adb sideload and Open_Gapps-arm64-11-pico-20210712) ...But keyboard bug reintroduced is not yet fixed, see comment from @Sean McCreary above. Did not try to do a factory reset first... But did try to flash back to 0726, and that claimed the data to be corrupt, so was forced to reset... So made a third flash WITH a wipe... and that did not work with the 0809, so went back to 0726, with another wipe required. And things work again. I hope for better luck next week . 😇 Yes, today's build has the August 5th security patches but not the fix for the keymap bug. Trying to flash an older release triggers the rollback protection in the closed source components, and will force a factory reset to recover :-( Unfortunately we haven't found a fix for the problems with the touchscreen on other devices. This leaves us with a difficult choice, between the security patches and proper keymap support when the accessibility hook is enabled. I don't have any easy answer (other than building your own OS image), but the full details of the August security patches are here: https://source.android.com/security/bulletin/2021-08-01 My suggestion is to not use apps that use the accessibility hook until we have a better fix for the keymap bug. 4 Quote Link to post Share on other sites
EskeRahn 5,598 Posted August 10, 2021 Share Posted August 10, 2021 13 hours ago, Sean McCreary said: My suggestion is to not use apps that use the accessibility hook until we have a better fix for the keymap bug. Thanks for the reply. I personally merely use Lineage for tests currently (so no big deal with resets). I'm just reporting so others can decide if they should upgrade or stay on the 20210726 for now. 🙂 If someone need an app that uses the accessibility keyboard hook and interferes, but does not use it frequently one can consider as another option to leave the accessibility off for the app, and only turn it on when needed temporarily. People should also note that it is not all apps using the accesibility hooks that interfere. (e.g. There are no issues with Greenify) 1 Quote Link to post Share on other sites
Rob. S. 1,667 Posted August 11, 2021 Share Posted August 11, 2021 Hmm... Is it possible to downgrade from LineageOS 18.1 to 17.1 without data loss (before upgrading to 18.1 again)? Quote Link to post Share on other sites
EskeRahn 5,598 Posted August 11, 2021 Share Posted August 11, 2021 5 hours ago, Rob. S. said: Hmm... Is it possible to downgrade from LineageOS 18.1 to 17.1 without data loss (before upgrading to 18.1 again)? No. We are not even allowed to downgrade from 18.1 20210809 to 20210726 ...Though there is a SLIM possibility that it might work it works, if you do not attempt to boot into 17.1, but stay at bootloader or recovery level 1 Quote Link to post Share on other sites
EskeRahn 5,598 Posted August 11, 2021 Share Posted August 11, 2021 22 minutes ago, EskeRahn said: ...Though there is a SLIM possibility that it might work, if you do not attempt to boot into 17.1, but stay at bootloader or recovery level IT WORKS!!!! 😮😮 Here is what I did boot to bootloader fastboot flash boot_a lineage-17.1-20210222-recovery-pro1.img Roll down to "Recovery Mode" with VolDown, and press Power to select. Await recovery boot. Select "Apply update", "Apply from ADB" for main flash adb sideload lineage-17.1-20210222-nightly-pro1-signed.zip From main menu, select Advanced, "Reboot to recovery". Await recovery boot. Select "Apply update", "Apply from ADB" to add Gapps adb sideload open_gapps-arm64-10.0-pico-20210327.zip If prompted (shortly after 47%) tap "yes" to "...Install anyway" Main menu, advanced, reboot to bootloader then ran fastboot getvar all just to do something with fastboot.... Repeated step 2-9 with lineage-18.1-20210726.... and open_gapps-arm64-11.0-pico-20210712.zip (and from main menu selected reboot) 2 Quote Link to post Share on other sites
