EskeRahn 5,604 Posted October 10, 2022 Share Posted October 10, 2022 (lineage-19.1-20221010-nightly-pro1-signed.zip on October 5 security patch installed smoothly using adb sideload and MindTheGapps-12.1.0-arm64-20220605_174313) Still with the keyboard bug introduced that messes accessibility apps (works on AICP R/S based on Android 11/12) see e.g. this. Quote Link to post Share on other sites
Wheeljack 212 Posted October 12, 2022 Share Posted October 12, 2022 This reminded me: whatever happened to split screen since 19.1? Quote Link to post Share on other sites
Hook 3,367 Posted October 12, 2022 Share Posted October 12, 2022 1 hour ago, Wheeljack said: This reminded me: whatever happened to split screen since 19.1? Still there. A little odd... you first actually have to launch the two apps you want to split. Then you have to go to the app switcher. I use the old navigation bar, so I just tap the square to get to the switcher. Then hold the icon over the first app you want on the split screen. It offers the option to "split left". Then it will ask you to pick the card for the second app. Just tap that apps card and the two apps will pop up in split screen. Used to be easier and more flexible, but I think that's probably Android 12. 3 Quote Link to post Share on other sites
EskeRahn 5,604 Posted October 18, 2022 Share Posted October 18, 2022 (lineage-19.1-20221017-nightly-pro1-signed.zip on October 5 security patch installed smoothly using adb sideload and MindTheGapps-12.1.0-arm64-20220605_174313) Still with the keyboard bug introduced that messes accessibility apps (works on AICP R/S based on Android 11/12) see e.g. this. Quote Link to post Share on other sites
EskeRahn 5,604 Posted October 24, 2022 Share Posted October 24, 2022 (lineage-19.1-20221024-nightly-pro1-signed.zip on October 5 security patch installed smoothly using adb sideload and MindTheGapps-12.1.0-arm64-20220605_174313) Still with the keyboard bug introduced that messes accessibility apps (works on AICP R/S based on Android 11/12) see e.g. this. Spontaneous boot trying to update apps!!! But happy after boot... Status bar spontaneously disappear.... ???? Happened twice within the first minutes of 'jumping around', and reappeared spontaneously too. Maybe some of all these damned gesture things I have triggered??? Quote Link to post Share on other sites
Hook 3,367 Posted October 24, 2022 Share Posted October 24, 2022 4 hours ago, EskeRahn said: (lineage-19.1-20221024-nightly-pro1-signed.zip on October 5 security patch installed smoothly using adb sideload and MindTheGapps-12.1.0-arm64-20220605_174313) Still with the keyboard bug introduced that messes accessibility apps (works on AICP R/S based on Android 11/12) see e.g. this. Spontaneous boot trying to update apps!!! But happy after boot... Status bar spontaneously disappear.... ???? Happened twice within the first minutes of 'jumping around', and reappeared spontaneously too. Maybe some of all these damned gesture things I have triggered??? Updated via OTA. The usual 2 hours to finish, but seeing neither of the symptoms you described so far. I don't use gestures, 1 Quote Link to post Share on other sites
EskeRahn 5,604 Posted October 24, 2022 Share Posted October 24, 2022 1 hour ago, Hook said: I don't use gestures, Me neither - or at the least I tried to turn them off.... 😂 1 Quote Link to post Share on other sites
EskeRahn 5,604 Posted November 9, 2022 Share Posted November 9, 2022 (Nothing substantially seems to happen with the updates. Will still update the device, and report here if something new happens....) Quote Link to post Share on other sites
FlyingAntero 871 Posted November 9, 2022 Share Posted November 9, 2022 Just installed LOS 19.1 to my Pro1 also. Everything is good so far. Quote Link to post Share on other sites
FlyingAntero 871 Posted November 11, 2022 Share Posted November 11, 2022 According to user reports, Lineage OS is affected of the bug below. However, vulnerability should be patched in the November security update. - https://9to5google.com/2022/11/10/pixel-lockscreen-unlock-bug/ 1 Quote Link to post Share on other sites
Hook 3,367 Posted November 14, 2022 Share Posted November 14, 2022 Updated OTA to lineage-19.1-20221114-nightly-pro1-signed.zip with the November 5th security patch. Installed smoothly, left root intact, Still takes about 2.5 hours to do the OTA. I have no idea why, but I'm too lazy to set up flashing. It works and I am sitting at a computer for that 2.5 hours. 1 Quote Link to post Share on other sites
FlyingAntero 871 Posted November 14, 2022 Share Posted November 14, 2022 Updated to latest version also. I can confirm that the SIM card lock screen bypass vulnerability is now fixed. (But my Zenfone 9 is still vulnerable with stock firmware) 1 Quote Link to post Share on other sites
Hook 3,367 Posted November 21, 2022 Share Posted November 21, 2022 Strange. No new nightly today. 1 Quote Link to post Share on other sites
EskeRahn 5,604 Posted November 21, 2022 Share Posted November 21, 2022 1 hour ago, Hook said: Strange. No new nightly today. My thought exactly, was about to post something similar *LOL* 1 Quote Link to post Share on other sites
EskeRahn 5,604 Posted November 23, 2022 Share Posted November 23, 2022 On 11/21/2022 at 4:12 PM, Hook said: Strange. No new nightly today. ...It is here today... 1 2 Quote Link to post Share on other sites
Hook 3,367 Posted December 5, 2022 Share Posted December 5, 2022 And this week too. Another Wednesday update? ;-) Quote Link to post Share on other sites
Hook 3,367 Posted December 5, 2022 Share Posted December 5, 2022 7 hours ago, Hook said: And this week too. Another Wednesday update? ;-) Nope, just showed up late. 1 Quote Link to post Share on other sites
EskeRahn 5,604 Posted January 9, 2023 Share Posted January 9, 2023 (Split @CornholioGSM's hint on 20.0 for original Pro1 to separate thread here) Quote Link to post Share on other sites
