claude0001 1,424 Posted April 28, 2023 Share Posted April 28, 2023 27 minutes ago, Sean McCreary said: If the off-mode-charge flag is set, it will start the charger program instead of the full Android UI. I had been suspecting this was the case for some time now. Thanks for clarifying. This means that off-mode-charging cannot actually protect us from the battery depletion bug. If the battery is flat, it's game over, irrespective of the off-mode-charge setting. 29 minutes ago, Sean McCreary said: LineageOS doesn't have licenses for this source code, so we need F(x)tec to fix it. Thanks, it is clear to me that LineageOS cannot fix those bits. Does anyone know whether F(x)tec actually have the sources? I.e. can they fix these things in house or do they rely on some external software company for maintaining the stock OS and its drivers? 1 Quote Link to post Share on other sites
Hook 3,339 Posted May 4, 2023 Author Share Posted May 4, 2023 For anyone worried by the hiccup with the Pro1 update, the 20230504 update for the Pro1x installed smoothly and all is good. Still April security patch, as expected. 1 1 Quote Link to post Share on other sites
eorg 11 Posted May 6, 2023 Share Posted May 6, 2023 Nice to hear, that the linage is finally official! Has anyone yet heard of the lineage os for microg implementation? I can only find the pro1 on their downloads page, but nothing from the pro1x: https://download.lineage.microg.org/ I already tried to build it on my own, but for some reasons I'm not able to install docker, neither on wsl, nor on windows :-/ Quote Link to post Share on other sites
Noob 158 Posted May 7, 2023 Share Posted May 7, 2023 You could try raising an issue on their Github repo. I see other such requests here, or you can try the Docker CD image repo instead. What issue do you have installing Docker? Quote Link to post Share on other sites
Joubolei 0 Posted May 7, 2023 Share Posted May 7, 2023 i've switched the pro1x phone from stock android to lineage os 20. phone calls don't seem to work someimes. i can hear the other person but they can't hear me. wondering if anyone else has encounter the issue. also - on verzion. SMS/text works - sometimes it seems like they don't want to come thru, but a restart seems to fix the issue with text/sms. Quote Link to post Share on other sites
Hook 3,339 Posted May 7, 2023 Author Share Posted May 7, 2023 1 hour ago, Joubolei said: i've switched the pro1x phone from stock android to lineage os 20. phone calls don't seem to work someimes. i can hear the other person but they can't hear me. wondering if anyone else has encounter the issue. also - on verzion. SMS/text works - sometimes it seems like they don't want to come thru, but a restart seems to fix the issue with text/sms. Did phone calls work consistently on stock? Lineage really doesn't really change that, as far as I can tell. Quote Link to post Share on other sites
eorg 11 Posted May 8, 2023 Share Posted May 8, 2023 On 5/7/2023 at 10:37 AM, Noob said: You could try raising an issue on their Github repo. I see other such requests here, or you can try the Docker CD image repo instead. What issue do you have installing Docker? thanks for the link, didn't find the first one on my own and the second seemed not the right place for my request. I will try to ask there, although I'm not very optimistic, since some of the requests for device supports ar from august last year... When I try to install the docker windows desktop app it allways fails, no idea why. When I install it in wsl und try to run the 'hello world' example it says that docker could not be started or somethin like that... Quote Link to post Share on other sites
Joubolei 0 Posted May 8, 2023 Share Posted May 8, 2023 23 hours ago, Hook said: Did phone calls work consistently on stock? Lineage really doesn't really change that, as far as I can tell. to be honest - i don't remember. it did work with sms and voicemail. i'll have to go back to stock and test. Quote Link to post Share on other sites
Joubolei 0 Posted May 9, 2023 Share Posted May 9, 2023 3 hours ago, Joubolei said: to be honest - i don't remember. it did work with sms and voicemail. i'll have to go back to stock and test. so, after testing with stock android - same issue. not sure if its a fault with the phone or not compatible with verizon's network. sometimes the other person can hear and sometimes nothing Quote Link to post Share on other sites
Name_not_avail 75 Posted May 9, 2023 Share Posted May 9, 2023 On 5/3/2023 at 1:28 PM, claude0001 said: This forum documents that we're not alone. More and more, this place feels like a party that's actually long over, except for the few guys still hanging around 'cause they're too drunk to realise they should better go home. 🙂 It's the phone. Or maybe it's the firmware drivers, but it makes no difference, it won't get fixed at this point. You have a wifi tablet with a mechanical keyboard, not a phone. We have all been soaked, and LOS can't fix it. Quote Link to post Share on other sites
Hook 3,339 Posted May 9, 2023 Author Share Posted May 9, 2023 7 hours ago, Name_not_avail said: It's the phone. Or maybe it's the firmware drivers, but it makes no difference, it won't get fixed at this point. You have a wifi tablet with a mechanical keyboard, not a phone. We have all been soaked, and LOS can't fix it. Unless, as in my case, you bought it to be a wifi pocket computer (it's not a tablet). I should demand a refund... they sent me a phone. 😉 3 Quote Link to post Share on other sites
AndytheNoob 40 Posted May 9, 2023 Share Posted May 9, 2023 So... Quick question becuase this thread seems to have gone off on tangents Is this release of Lineage OS 20 stable and useable on the Pro1x? P.S. For what it's worth I've been running my Pro1x on the stock Android OS as my daily driver for more than a week now and it's been absolutely fine. No signal strength issues, no random drop outs, it's perfectly fine. If I were to be picky I would say that I'd like the corner LED to behave the same as the Pro1 used to, but that's it. Quote Link to post Share on other sites
Hook 3,339 Posted May 9, 2023 Author Share Posted May 9, 2023 24 minutes ago, AndytheNoob said: So... Quick question becuase this thread seems to have gone off on tangents Is this release of Lineage OS 20 stable and useable on the Pro1x? P.S. For what it's worth I've been running my Pro1x on the stock Android OS as my daily driver for more than a week now and it's been absolutely fine. No signal strength issues, no random drop outs, it's perfectly fine. If I were to be picky I would say that I'd like the corner LED to behave the same as the Pro1 used to, but that's it. Yes, as the title states (and threads here can get caught up in issues) this is the thread for the Official version. They are referred to as "nightlies," but they are posted weekly, so, yeah, a little confusing. Each one is the current official version with updated security patches. There is a change log available on the Lineage site where you download the files for first flash. After that, you can update OTA. The links are in the OP. Quote Link to post Share on other sites
--- 129 Posted May 10, 2023 Share Posted May 10, 2023 Exciting times, but a couple of quick questions before I dive in and break something. 1. Do I need to backup 'device specific partitions' before I flash LineageOS, or is this only relevant to Sailfish or Ubuntu Touch, or is a backup not required but a good idea anyway? 2. I understand LineageOS needs a factory reset prior to install, is this taken care of in the install: or is it advisable/necessary to perform a factory reset prior to starting the install procedure (I'm currently on V2.1.5 GMS-free rooted)? Apologies if these questions are a bit basic, so am I, and if I break my daily driver I'm in trouble. Plus I'm also rather fond of my little PrawnX. 🥰😍 1 Quote Link to post Share on other sites
Hook 3,339 Posted May 10, 2023 Author Share Posted May 10, 2023 1 hour ago, MonCon said: Exciting times, but a couple of quick questions before I dive in and break something. 1. Do I need to backup 'device specific partitions' before I flash LineageOS, or is this only relevant to Sailfish or Ubuntu Touch, or is a backup not required but a good idea anyway? 2. I understand LineageOS needs a factory reset prior to install, is this taken care of in the install: or is it advisable/necessary to perform a factory reset prior to starting the install procedure (I'm currently on V2.1.5 GMS-free rooted)? Apologies if these questions are a bit basic, so am I, and if I break my daily driver I'm in trouble. Plus I'm also rather fond of my little PrawnX. 🥰😍 1. LineageOs doesn't mess with the persist partition. 2. You need to erase userdata before installing Lineage. So after you flash the dtbo.img and the recovery.img, as per the instructions, you reboot into recovery and select factory reset on the recovery menu. Then you are finally ready to adb sideload the Lineage zip file. 2 Quote Link to post Share on other sites
--- 129 Posted May 10, 2023 Share Posted May 10, 2023 (edited) @HookThanks for the clarity, much appreciated, I'll have a play. Edit: That went well, first impressions it looks nice and smooth. Thank you Developers, Community, FxTec. Edited May 10, 2023 by MonCon 3 Quote Link to post Share on other sites
Hook 3,339 Posted May 12, 2023 Author Share Posted May 12, 2023 Just got around to updating to the 20230511 nightly (Official) OTA and everything is fine. It has the May 2023 security patch. 2 Quote Link to post Share on other sites
azamrazman 7 Posted May 12, 2023 Share Posted May 12, 2023 Hi Community, Do you loose Root if you update Lineage via OTA? Quote Link to post Share on other sites
Hook 3,339 Posted May 12, 2023 Author Share Posted May 12, 2023 49 minutes ago, azamrazman said: Hi Community, Do you loose Root if you update Lineage via OTA? No, at least I don't. 1 Quote Link to post Share on other sites
DieBruine 397 Posted May 13, 2023 Share Posted May 13, 2023 After selling my Pro1 this morning I decided to flash my Pro1x to LoS 20. I'm going on a 3 week tourist trip trough Japan on Monday. Flashin took like 5 minutes. Runs nice and smooth. but wouldn't you know, the one app that I can't configure is my banking app. It's supposed to take a picture of my ID. But it freezes when the camera is accessed. If I remember correctly, the same happened with my Pro1 on LoS 20. Any users able to activate ING banking app? F-ing annoying I'll say. I have ordered a MiFi for my trip, so that's why I thought of giving the Pro1x a go. But if I can't activate my banking app while on holiday 😪 1 Quote Link to post Share on other sites
Benni 192 Posted May 13, 2023 Share Posted May 13, 2023 35 minutes ago, DieBruine said: After selling my Pro1 this morning I decided to flash my Pro1x to LoS 20. I'm going on a 3 week tourist trip trough Japan on Monday. Flashin took like 5 minutes. Runs nice and smooth. but wouldn't you know, the one app that I can't configure is my banking app. It's supposed to take a picture of my ID. But it freezes when the camera is accessed. If I remember correctly, the same happened with my Pro1 on LoS 20. Any users able to activate ING banking app? F-ing annoying I'll say. I have ordered a MiFi for my trip, so that's why I thought of giving the Pro1x a go. But if I can't activate my banking app while on holiday 😪 I'm pretty sure you need to pass safetynet/play integrity for banking apps. I do that using: * MagiskHide Props Config - with the stock fingerprint (config in attachment) * Univarsal SafetyNet Fix * Blacklist in Magisk printslist 1 Quote Link to post Share on other sites
eorg 11 Posted May 13, 2023 Share Posted May 13, 2023 2 hours ago, Benni said: I'm pretty sure you need to pass safetynet/play integrity for banking apps. I do that using: * MagiskHide Props Config - with the stock fingerprint (config in attachment) * Univarsal SafetyNet Fix * Blacklist in Magisk printslist 116 B · 0 downloads Hey @Benni did I understand this correct: with your mod I am able to root my phone, spoof for example microG to be the actual GMS and then make any app believe that my phone is not rooted, so apps that don't allow my to root my phone would work? Quote Link to post Share on other sites
Hook 3,339 Posted May 13, 2023 Author Share Posted May 13, 2023 Wow, I guess US Banks are (thankfully) less security conscious. Bank of America has no problem with either LOS 20 or my Pro1x being rooted (although I just did this as a test-- I actually do my banking on my not rooted cheap moto). Frankly, it makes me happy that BoA doesn't mind. Maybe makes up for having such crappy carriers. 😄 Quote Link to post Share on other sites
DieBruine 397 Posted May 13, 2023 Share Posted May 13, 2023 (edited) 13 hours ago, Benni said: I'm pretty sure you need to pass safetynet/play integrity for banking apps. I do that using: * MagiskHide Props Config - with the stock fingerprint (config in attachment) * Univarsal SafetyNet Fix * Blacklist in Magisk printslist 116 B · 1 download I thank you for the suggestion, and will try it. But I'm pretty sure this is not the case. It always worked on LoS 16, 17, and 19 on several other phones and tablets, including my Pro1. I believe it is a software issue/ bug and not a security issue. The app just freezes trying to scan my ID. I think it's because of a driver or call to the camera. The app responds, kinda. But the image freezes where it's supposed to focus and recognize the characters in the image. Guess I'll have to get used to accessing my account when I get home. Edited May 14, 2023 by DieBruine Tried... Quote Link to post Share on other sites
Benni 192 Posted May 14, 2023 Share Posted May 14, 2023 10 hours ago, eorg said: Hey @Benni did I understand this correct: with your mod I am able to root my phone, spoof for example microG to be the actual GMS and then make any app believe that my phone is not rooted, so apps that don't allow my to root my phone would work? No idea how it works with microG, sorry. Also not my mod, I'm just a user. Quote Link to post Share on other sites
