TeZtdevice 368 Posted March 1, 2019 Share Posted March 1, 2019 @dreamflasher Yes, after the bootloader is unlocked Quote Link to post Share on other sites
david 929 Posted March 1, 2019 Share Posted March 1, 2019 The blog about the screen states: "We also chose a curved-edge screen to match the shape & contours of the main body. Itโs important the device looks slick & feels comfortable at the same time!"ย The website homepage and video states: "Function is key"ย The whole point of this phone should be function. A curved edge screen is not a functional feature. It is a liability. A keyboard phone isn't going to convince all the iPhone (and similar) users of the world to buy it. It is for people who have used a keyboard phone in the past and understand how it is functionally better than virtual keyboard. Looking "slick" is not what your target market cares about. They care about one thing above all else, which is to have a physical keyboard on their phone.ย This phone won't have a big enough market for 3rd party vendors to create accessories for it. With a flat screen, it may have been possible for people to mold their own case or 3D print a case to fit the screen portion. But with a curved screen that probably isn't possible and is doubly bad, because a curved screen is more prone to being damaged in the first place.ย The screen is too large, as others have stated, but that can be forgiven in trying to find a compromise, given that there will be only on model produced versus other manufacturers producing small, medium and large to cater to users who prefer different sizes. A curved screen, however, is simply a bad design decision for multiple reasons. You have to ask yourself, will my target market not buy this phone if it comes with a flat screen? Highly doubtful. Will my target market not buy this phone if it comes with a curved screen? Yes, in some cases, that will cause people not to buy it.ย 6 GB RAM, SD card slot, 128 GB storage, vanilla Android, USB-C, many cellular bands. All great. All functional. 5 row, staggered (important), backlit (important) keyboard. Wonderful. Very functional.ย Sell a case, or at least provide the 3D model files for the phone so that people can print their own or use a 3rd party 3D print vendor to print one for them, and you'll make your customers happier.ย If you change to a flat screen for the next version, you'll sell more phones. Quote Link to post Share on other sites
mcdinner 375 Posted March 1, 2019 Share Posted March 1, 2019 I really second the curved screen issue! Maybe there is still time and a possibility to change that. At least put a decent case/bumper to the phone.ย Quote Link to post Share on other sites
Florian 0 Posted March 1, 2019 Share Posted March 1, 2019 I also don't get that curved screen stuff. I have a note 8, and I hate the curved screen, especially, when you use the pen to write notes, the screen is to small to write on it, the edges make it even smaller and worse. I also had a glass screen protector on it, and after a few days it came loose in the curved edge, when I tried to reapply the glass cover it broke. While I was waiting for a new cover I got already two bad scratches in the screen. ย Who needs a curved screen, its just a gimmick. I loved the screen of my Note3 which was flat and wide enough for a pen. Also the screen of my N97 was awesome, the screen was fully readable (Monochrome) in direct sunlight. ย If I would have the choice, I would love to see - Qi (Wireless Charging) - Removable Battery (Its ok if it works as in the Moto Droid4, screw + glue) - More battery power 4000mah - Dual Sim + MicroSD ( not shared) - USB-C on both sides of the phone. (HDMI, Charging, USB-Drive, ...) - Low price version 399 Euro ( 32 GB / 4 GB) Anyway the rendering and photos show an awesome device, with the background of unlockable bootloader and "community" support, it will be just awesome. But not for m Quote Link to post Share on other sites
EskeRahn 5,598 Posted March 2, 2019 Share Posted March 2, 2019 David, Florian and others. Personally an edges screen or not is not a big issue.ย As I see it, it is already quite wide (as wide as the Samsung S8+/S9+ phablets, and if we should have any practically protective bezels, it should be even wider, or with reduced display. Both of which I believe would scare of more users than the edge design. Since there seem to be this silly fashion that phablets go bigger and bigger all the time.ย Personally I already ordered some tempered glass protectors for the longer S8+ and S9+ (one is 0.2mm less wide, one is 0.2mm wider) and hope it got the same curvature, so I will only need to cut in one or both ends with a glass cutter to have it fit.ย Anyway the glass part is clearly edged lengthwise only, so it will be fairly easy to cut a simple flat protective film. Again my guess is those for the S8+/S9+ will be a good starting point.ย But of course we will not know for sure yet.. Quote Link to post Share on other sites
david 929 Posted March 5, 2019 Share Posted March 5, 2019 EskeRahn,ย I disagree. People for whom screen size is a main consideration aren't going to buy this phone because it has a larger screen. The target market of this phone is people who want physical keyboards. I believe there is an overlap of people who want physical keyboards and people who do not want extra large screens. A smaller screen is more functional, because it can be transported easier and held easier for typing. ย The answer to bezels making the phone wider is to use a less wide screen. People who want bigger screens can buy a tablet or another phablet phone. People who want a physical, horizontal keyboard slider have no other options.ย Regular users don't want to cut glass screen protectors made for other phones. I agree that cutting a protective film to provide scratch resistance should be doable for most people. However, without a bezel, those are going to peel off VERY quickly. Another reason for a bezel phone.ย But as it pertains to dropping the phone on a corner, the first line of defense should always be a case. Non-keyboard phones without curved edges have the ability to have a case that extends above the plane of the screen to protect it when dropped. No such protection exists when the screen can be moved away from the bottom part of the phone (as in the Pro 1) and with a small market phone for which there may not be 3rd party cases created. A bezel may protect a slider's screen from being broken.ย As Florian said, a curved screen is a gimmick. It isn't functional. It is about style over function. Protecting this phone is even more important than protecting a mass market phone. Many buyers are still holding onto outdated keyboard phones and have protected them for years, because they can't just buy a newer model phone if it breaks (because there are no other similar keyboard phones being made). This phone probably won't sell in large enough numbers for phone repair shops to support replacing the screen (and will f(x)tech supply them with replacement screens even if they want to?).ย People who fear breaking the screen on their phone will *reluctantly* purchase the Pro 1 and some will not do so out of this fear. Those who do buy it and break the screen are not going to be happy customers and those reports will deter other non-early adopters from making a purchase later. A non-bezel screen on a phone where the screen moves away from the body of the phone *should* have been a mutually exclusive situation.ย Curved screen or not, I hope the company will provide 3D model files for the phone so that buyers can use 3D printing services that print phone cases. It would cost very little for the company to provide these files and there could be some provided with taller edges at the top and bottom of the phone to provide extra protection if the phone is dropped. Since the scree pivots instead of sliding, it might even be possible to provide a design that allows for taller edges on the long sides of the phone to protect those edges as well. It wouldn't even increase the thickness of the phone, since the edges just need to be taller than the bottom edge of the curved screen, which is lower than the flat part of the screen. The key is protecting the corners, however. Quote Link to post Share on other sites
david 929 Posted March 5, 2019 Share Posted March 5, 2019 Florian,ย I agree. A removable battery is another huge consideration. The batteries often only last a couple years. Keeping a rare, keyboard phone functioning for a long period of time requires being able to replace the battery *somehow*. I'm guessing this will involve a special procedure and a lot of risk for this phone, but when the battery goes, people will have to start resorting to risky options.ย Until the industry wakes up and provides the type of modularity that made IBM PCs and clones so successful (and less wasteful), we need phones that we can keep alive for a long time. Google never should have cancelled Project Ara. That was the worst thing that could have happened for consumers in the mobile device market. Quote Link to post Share on other sites
netman 1,424 Posted March 5, 2019 Share Posted March 5, 2019 As for me I am happy if the battery can be replaced without dealing with adhesives all over the place, and i do agree rounded screen is not ideal but it does look nice... I'm sold either way. Quote Link to post Share on other sites
EskeRahn 5,598 Posted March 5, 2019 Share Posted March 5, 2019 Well I'm with netman here. I would take almost any physical version of the device to get a real landscape keyboard slider. I'm in no way in love with the edge design, as mentioned very early on, I too would have preferred the whole thing reduced.ย But I'm quite sure they have taken long and thorough considerations on what size and design to go for. I mean I'm sure a simple flat screen is still cheaper so if they believed that is what people want, they would have gone for that.ย By going this big, the keys are 10mm apart so some people with fine fingers could even do full ten-finger typing on it on a table! I know a friend of mine that is texting a LOT and she would be an obvious candidate here...ย Sure it is far from optimal to fiddle with cutting screen protectors, and I of course hope there will be one for the device. My point was that there might be tolerable workarounds for creating one our selves, if a native one is not offered.ย To want a different design is a bit like looking for a phone sized highly speced device, here there are currently only TWO options, and only one available outside Japan. So there are no room for being picky either.ย But YES I agree that there is an overlap of users that want both a compact device and a device with Qwerty - old people like me is in it - but I doubt it is the majority of either group. And so did the developers obviously.ย But if the Proยน hopefully gets a huge success (the press reaction have been really nice what I have seen so far), who is to say if there will be a compact version also later on? Quote Link to post Share on other sites
abowers 0 Posted March 6, 2019 Share Posted March 6, 2019 I just now discovered this, and I'd like to add my voice to the discussion. I believe I am well within the target market of this phone, and I'm strongly considering ordering one. ย Thank everything holy someone decided to bring landscape physical keyboards back. This will be a massive improvement, I HATE typing on touch screens, text entry via touch screen is just a bafflingly stupid engineering concept that I'll never live long enough to forgive Steve Jobs for. In the movie Die Hard, John McClain dismissed a touch screen as a "cute toy." He's RIGHT.ย I'm in favor of a 5-inch class phone, for a few reasons: 1. Those who are interested in video consumption and photography are WELL served by every single mainstream phone on the market. 2. Those who primarily use text (sms, email, slack, etc) basically haven't been served since 2012 or so. 3. Those who have clung to physical keyboard phones and really want a new one are probably using 4-inch class devices with large bezels. modern 5 inch phone with modern narrow bezels would still be portable yet would still make for a significant increase in screen size for the target market. 4. I've heard three excuses for increasing phone size: a. Think of the poor starving Africans who can only afford a phone, we'd better discontinue everything below 6 inches. b. Well you keep insisting we make it thinner, so if it didn't get wider where would we put the battery? c. Now that we've done away with physical keyboards, the onscreen keyboard takes up a lot more space so we HAVE to make the screen larger. All three of these specifically don't apply to this phone, especially the third one. With a physical landscape keyboard, all the screen real estate is available for viewing the app, none taken up with user input. Effectively, for users who heavily use text input, a 5 inch phone will be more than equivalent in usability to a 6 inch phone. 5. A 5 inch phone will be dramatically more portable, it will fit in more pockets, especially given the additional thickness of a two-layer phone. 6. I'm actually concerned about the ergonomics of thumb typing on such a large keyboard, It's a long way to reach your thumbs to the center of that keyboard.ย I realize the Pro1 is late in development, so changes to hardware are very unlikely. I learned about this project via a preview on Youtube. My hopes are this phone is a solid enough success with the underserved "we want a keyboard" market, enough that a future Pro2 could (exist, and) be available in two sizes.ย If anything, a 6 inch keyboard tempts you to add too many keys. You could save some space (and I would hope, cost) by eliminating two columns of special character keys and instead putting them as alternate symbols on the letter keys. I'm comparing my old 4" class phones (LG EnV2, Ally and Enlighten) to a Rii i8 keyboard. The 4-row phones do feel slightly cramped and strange with the space bar either split and on either side or crammed between the bottom row, along with awkward inclusion of the arrow keys. On the other hand the Rii feels too large, it feels slow and cumbersome to keep reaching for the spacebar. I think a 5-inch phone would be a better compromise.ย Though, I have to imagine that choice was really made for you, probably just buying a screen off the shelf from Samsung. That's what they've got now that sub-6 inch are illegal, so you've got to go with what they've got. It's a slightly boutique product, so you're not going to sell enough to tool up a custom run of screens. ย I'm not so sure about the angled screen. I've always had just straight sliders, and I think for the task of holding the phone in your hands and thumb typing, having the screen parallel to the keyboard is the appropriate angle, though I'd like to handle the device before passing final judgement. I'm also wondering which mechanism allows the keyboard to emerge farther, a simple slide, or this dogbone hinge arrangement? ie which one reveals more of the inner side of the phone?ย I'm one of those who is not interested in a curved screen. I haven't seen any evidence that it improves the usability or functionality of the device, while making it less durable, more difficult to encase or protect, and harder to handle. It's following trends because they're trendy.ย I really appreciate the presence of a camera shutter button, expandable storage, and a headphone jack. Those are welcome additions.ย I would like to see support for non-Android OSes, Sailfish or even just straight-up GNU/Linux, though side loading F-Droid would be sufficient for me.ย As for cases: I wonder if dbrand could be persuaded to make a skin for it? I carry my phone in a pocket, I'm not interested in holsters or clips, just some basic anti-scratching. I'm not too worried about drops and such. My current phone is a Galaxy S4 mini I've carried since 2013, it has Gorilla Glass 2, no case, no screen protector, and the glass is pristine. I've never broken a phone screen, and they've only gotten more durable since.ย Overall, it's likely you'll have a customer.ย ย Quote Link to post Share on other sites
EskeRahn 5,598 Posted March 6, 2019 Share Posted March 6, 2019 Well abowers, I'm with you part of the way. But the thought of removing columns of keys gets a big NO from me or we would end up with a keyboard only really suited for countries with alphabets limited to A-Z. The 14 columns are one of the long awaited things with the Proยน, as is the fifth row for numbers.. So I hope any future more compact version would keep the overall keyboard design, but 'just' shrink everything 8:9ย The limitation by the size as I see it is primarily the one handed operation in portrait, but there are possible software-tricks that might help here, that I hope they'll implement, to help those of us that haven't got huge hands, but still want one handed operation with a secure grip. Quote Link to post Share on other sites
david 929 Posted March 6, 2019 Share Posted March 6, 2019 abowers - Well put!ย Thatโs what theyโve got now that sub-6 inch are illegal...ย Ha! Quote Link to post Share on other sites
EskeRahn 5,598 Posted March 6, 2019 Share Posted March 6, 2019 David and abowers, yup *LOL*. Manufacturers generally think that lesser must be combined with mediocre or worse.... :-(ย I usually use this link to expose the VERY limited availability. All I request is at the most 65mm wide, and at the least FHD - and get TWO, of which ONE is available outside Japan....ย Pretty absurd with so little variation in all the phablets that are pumped out. Different people different needs/wishes.... and this SHOULD lead to different products by normal market mechanisms - but oddly it does not seem to happen?ย ...Maybe people are getting tired of more of the same huge phablets only, and that could be reason behind the smartphone sales according to IDC are slowing down Quote Link to post Share on other sites
peter 6 Posted March 9, 2019 Share Posted March 9, 2019 Well I'm with EskeRahn on the numbers row, I always hated on the N900 having to shift to get at them when particularly when adding someone to a contacts list. It also made using the terminal built in to the N900 surprisingly hard work.ย I'm not all that bothered about curved screens or overall size but I hope this happens as I think it's a better alternative to the cosmo which seems to be a bit flawed as a phone.ย Anyway I placed my order on launch day and right now I wish the crew all the best. Getting that first batch of hardware manufactured is a hard task and I just need my current phone to last long enough. Quote Link to post Share on other sites
EskeRahn 5,598 Posted March 12, 2019 Share Posted March 12, 2019 On the GPS, I'm not sure about Galileo, but can't imagine that the others are not there. And if I look here it is clear that the chipset is supported, so would be very surprised if that did not work as well. Quote Link to post Share on other sites
pedro4444 36 Posted March 12, 2019 Share Posted March 12, 2019 hello please Will be have this device irda for infra remote control device? Quote Link to post Share on other sites
nbtodd 0 Posted March 13, 2019 Share Posted March 13, 2019 hello please Will be have this device irda for infra remote control device?ย At this point it's safe to say no.ย ย Quote Link to post Share on other sites
nbtodd 0 Posted March 13, 2019 Share Posted March 13, 2019 I really appreciate the presence of a camera shutter button, expandable storage, and a headphone jack. Those are welcome additions.ย My girlfriend has a flashed PQ and besides ergonomics which that device truly excels in, this is what matters to her. That phone's Achilles heel is the lens' susceptibility to cracking on impact and becoming unusable. So my thoughts on the curved screen. Unless you're always sitting at a table, you'll be pushing the phone open all the time. And your thumbs will slip often, especially if they're not clean. Which leads to the chance of dropping, for which designing a decent case for will be a problem. And this is a big phone, which presumably takes a little more effort to open. Because of this I'll get a Pro1 for me, but not her.ย Quote Link to post Share on other sites
bob3k 0 Posted March 14, 2019 Share Posted March 14, 2019 I've preordered, but now that I read more details, specifically the really just too big size--over 6 inches in width? and the dumb useless gimicky curved edged screen, on both sides!-- I'm seriously considering canceling my preorder. I am still using my Droid 4. I would love to have a new qwerty phone, but those two things are almost a deal breaker. ย It needs to fit in my pocket, it needs to fit in my hand...and curved edged screen...are just stupid in every way.ย Please make a 5ish inch flat screened qwerty slider phone. I guarantee it's really what 90% of the people on here want. Quote Link to post Share on other sites
EskeRahn 5,598 Posted March 14, 2019 Share Posted March 14, 2019 bob3k, Have you tried a Samsung S8+ or S9+? The width is right between the two, and the Proยน a bit shorter. Remember that it is 2:1 not 16:9 so 6" sounds larger than it really is. It is substantially less wide than a BlackBerry Priv (with the keyboard in the wrong direction) Quote Link to post Share on other sites
Siani_8 105 Posted March 18, 2019 Share Posted March 18, 2019 Trusted members on the Blackberry Forum are throwing around .7 pound weight for this phone and while there is nothing to back up the claim, the members are listening and believing it and probably turning away some current Priv owners looking for an upgrade. Is there any way we can get the real weight of this device? Quote Link to post Share on other sites
EskeRahn 5,598 Posted March 18, 2019 Share Posted March 18, 2019 ยฝ pound, afaik. I do not know why the specs does not tell the weight. My GUESS is that some details can yet be adjusted, so they wont promise an exact weight. Quote Link to post Share on other sites
Siani_8 105 Posted March 19, 2019 Share Posted March 19, 2019 Thank you! Quote Link to post Share on other sites
RoninX 0 Posted March 20, 2019 Share Posted March 20, 2019 Personally, coming from an LG V30 and having owned V20, Note 5, and Nexus 6P in the past, I think the Pro 1's 6-inch screen is the perfect size.ย Quote Link to post Share on other sites
EskeRahn 5,598 Posted May 22, 2019 Share Posted May 22, 2019 Personally I already ordered some tempered glass protectors for the longer S8+ and S9+ (one is 0.2mm less wide, one is 0.2mm wider) and hope it got the same curvature, so I will only need to cut in one or both ends with a glass cutter to have it fit.ย This failed miserably, but protectors for the Elephone U Pro with the same front exists. Quote Link to post Share on other sites
