EskeRahn 5,592 Posted October 24, 2019 Share Posted October 24, 2019 Hi everyone, We now all have the option to report stuff. So help us all to keep the forum clean and please 🧹 Report it when you see spam or other unwanted content. 🧹 The conversion did not go smooth on all the spam, so I have 'just' manually been through all pages of all threads, and tried to weed out the missed spam. But it would be a miracle if I did not overlook something, so please report whatever junk you stumble upon. Add: Netman and SirBaconIII reported below that the Report option is not always easily visible, it appears at the top right of a post when the mouse is somewhere inside the square around the comment. (And when you are logged in only) 1 5 Quote Link to post Share on other sites
netman 1,424 Posted October 24, 2019 Share Posted October 24, 2019 I have reported a lot of them going trough what was marked unread. Do they arrive? Important thing to note is that where you should look is the top right of a post when you have the mouse hovering over it, only then the "report post" link appears, it's not immediately obvious. 1 1 Quote Link to post Share on other sites
EskeRahn 5,592 Posted October 24, 2019 Author Share Posted October 24, 2019 23 minutes ago, netman said: I have reported a lot of them going trough what was marked unread. Do they arrive? Important thing to note is that where you should look is the top right of a post when you have the mouse hovering over it, only then the "report post" link appears, it's not immediately obvious. Yup, I got those too, thanks. Did not realise it was not always visible, I think we should report that as a bug. As a moderator I see it there all the time, and as you had reported some I thought it was visible to everyone. Quote Link to post Share on other sites
SirBaconIII 66 Posted October 24, 2019 Share Posted October 24, 2019 1 minute ago, EskeRahn said: Did not realise it was not always visible, I think we should report that as a bug. Its not that it's isn't always visible as much as it really blends into the background when you're not mousing over it. It could just be that I sit pretty low compared to my monitors. I would agree that it could do with being a bit darker when inactive, though. 2 Quote Link to post Share on other sites
magicafternoon 38 Posted November 1, 2019 Share Posted November 1, 2019 Forum has been raided by Korean bots Quote Link to post Share on other sites
netman 1,424 Posted November 1, 2019 Share Posted November 1, 2019 If the forum is any good it should be possible to remove them all in one go because they are from the same user at least. Is there a captcha or alike for creating new accounts already? Quote Link to post Share on other sites
Zimeon 11 Posted November 1, 2019 Share Posted November 1, 2019 32 minutes ago, netman said: If the forum is any good it should be possible to remove them all in one go because they are from the same user at least. Is there a captcha or alike for creating new accounts already? Sure hope so, if not it should be added and enabled. Quote Link to post Share on other sites
Erik 1,487 Posted November 1, 2019 Share Posted November 1, 2019 3 hours ago, netman said: If the forum is any good it should be possible to remove them all in one go because they are from the same user at least. Is there a captcha or alike for creating new accounts already? I am going to change the spam settings. I am just afraid it might start blocking the good users too. Email [email protected] if anyone has trouble with the new spam system which is active now. 3 1 Quote Link to post Share on other sites
windraver 63 Posted November 4, 2019 Share Posted November 4, 2019 @EskeRahn, Why did you merge my thread "Post here only when you have a tracking number" when it was clearly different, provide different value, and intended to address a need in the community? I appreciate you intent to keep the forum clean but merging these threads was not helpful. For your reference. 1 1 Quote Link to post Share on other sites
enPfzr4v 239 Posted November 5, 2019 Share Posted November 5, 2019 I think the threads are getting very messy due to all of this merging. I would prefer if different discussions were kept separate. Thanks for all your hard work and effort! 1 2 Quote Link to post Share on other sites
EskeRahn 5,592 Posted November 11, 2019 Author Share Posted November 11, 2019 On 11/5/2019 at 7:33 PM, abielins said: I think the threads are getting very messy due to all of this merging. I would prefer if different discussions were kept separate. Thanks for all your hard work and effort! I think the forum is getting messy with people making new threads that are slight variations over existing threads. If I was less lazy, I guess I ought to merge more not less... On the other hand some threads are getting messy because things go off topic, so these ought to be split - and some of the splits from different threads merged.... But it's complex, especially if (as is often the case) the comment that starts a thread to go 'off topic', also includes something that is ON topic, so it is the comment in itself that ought to be split first, and that is not a simple task to do that clean. I'm not even sure there is a function to copy a comment as a split to a new thread, so I could edit the two copies and thus split the comment - and I really do not like to edit in peoples comments, unless explicitly asked to do so by the author, or if the alternative is to delete the post completely (e.g. a post with relevant content combined with an attack on another user). Fortunately I have not had the need to do this (yet). Except killing the obvious spam of course. 2 1 Quote Link to post Share on other sites
Doktor Oswaldo 916 Posted November 11, 2019 Share Posted November 11, 2019 1 hour ago, EskeRahn said: I think the forum is getting messy with people making new threads that are slight variations over existing threads. If I was less lazy, I guess I ought to merge more not less... On the other hand some threads are getting messy because things go off topic, so these ought to be split - and some of the splits from different threads merged.... But it's complex, especially if (as is often the case) the comment that starts a thread to go 'off topic', also includes something that is ON topic, so it is the comment in itself that ought to be split first, and that is not a simple task to do that clean. I'm not even sure there is a function to copy a comment as a split to a new thread, so I could edit the two copies and thus split the comment - and I really do not like to edit in peoples comments, unless explicitly asked to do so by the author, or if the alternative is to delete the post completely (e.g. a post with sensible content combined with an attack on another user). Fortunately I have not had the need to do this (yet). Except killing the obvious spam of course. Basically this whole Forum is a mess (Don't look at me, I am completely innocent). This is unlikely to get better until there is some real user2user content here. So I would say do not put too much work into it until we got the phones. 2 2 Quote Link to post Share on other sites
Siani_8 105 Posted November 11, 2019 Share Posted November 11, 2019 45 minutes ago, Doktor Oswaldo said: Basically this whole Forum is a mess (Don't look at me, I am completely innocent). This is unlikely to get better until there is some real user2user content here. So I would say do not put too much work into it until we got the phones. Once I get my phone, I'll most likely be following XDA more to see what the wizards and warloks are doing to make the phone better 3 Quote Link to post Share on other sites
zurvan2 125 Posted November 11, 2019 Share Posted November 11, 2019 5 hours ago, EskeRahn said: I think the forum is getting messy with people making new threads that are slight variations over existing threads. If I was less lazy, I guess I ought to merge more not less... Eh. We have one thread that is over 30 pages long. That's far, far too long to be useful to anyone. The goal should be to have a high Signal/Noise ratio. Sometimes this means moving things together, sometimes it means keeping things separate. Sometimes it means leaving things where they are so there is less noise from people complaining. 😉 Quote Link to post Share on other sites
Siani_8 105 Posted November 11, 2019 Share Posted November 11, 2019 2 minutes ago, zurvan2 said: Eh. We have one thread that is over 30 pages long. That's far, far too long to be useful to anyone. The goal should be to have a high Signal/Noise ratio. Sometimes this means moving things together, sometimes it means keeping things separate. Sometimes it means leaving things where they are so there is less noise from people complaining. 😉 The 'real' info is a running joke in that thread anyway. Every few days we get info that the fist batch is shipping and tracking will be provided 'soon' lol 1 Quote Link to post Share on other sites
EskeRahn 5,592 Posted November 11, 2019 Author Share Posted November 11, 2019 5 minutes ago, zurvan2 said: Eh. We have one thread that is over 30 pages long. That's far, far too long to be useful to anyone. The goal should be to have a high Signal/Noise ratio. Sometimes this means moving things together, sometimes it means keeping things separate. Sometimes it means leaving things where they are so there is less noise from people complaining. 😉 Certainly. You might consider reading all the way down to the line below starting with "On the other hand some threads ...." 😜 2 Quote Link to post Share on other sites
silversolver 849 Posted November 28, 2019 Share Posted November 28, 2019 On 11/11/2019 at 2:30 PM, Siani_8 said: The 'real' info is a running joke in that thread anyway. Every few days we get info that the fist batch is shipping and tracking will be provided 'soon' lol It shipped. ROFL Quote Link to post Share on other sites
FlyingAntero 871 Posted December 4, 2019 Share Posted December 4, 2019 Hi! I can't find the thread about Twitter post anymore. Is it deleted? The name was something like "they see light in the end of the tunnel" etc. Quote Link to post Share on other sites
Raksura 270 Posted December 4, 2019 Share Posted December 4, 2019 10 minutes ago, FlyingAntero said: Hi! I can't find the thread about Twitter post anymore. Is it deleted? The name was something like "they see light in the end of the tunnel" etc. It has been merged with "On the production status" as they ended up talking about the same issue(s). 1 1 1 Quote Link to post Share on other sites
