tdm 2,322 Posted July 6, 2020 Author Share Posted July 6, 2020 2 hours ago, JooJooBee666 said: Are you going to push the changes to the repos any time soon? I'd like to test here but build my own. Shortly. I'm working on fixing the device specific stuff right now. Then I'll make a new release and push up the changes. 1 3 Quote Link to post Share on other sites
tdm 2,322 Posted July 6, 2020 Author Share Posted July 6, 2020 test18 is up. The only changes are fixing device specific selinux rules (for eg. fingerprint, keyboard, touchscreen margins, etc.) Again, this is on the verge of being submitted for official Lineage builds. Please report any issues. Also pushed up code changes to github. Enjoy! 1 3 Quote Link to post Share on other sites
Wheeljack 212 Posted July 6, 2020 Share Posted July 6, 2020 Can confirm QWERTZ layout is fixed. Big THX. 3 1 Quote Link to post Share on other sites
SteffenWi 139 Posted July 6, 2020 Share Posted July 6, 2020 (edited) I've done a fresh installation (Full wipe and flashing of .img and .zip and gapps), but when I try to get through the setup wizard I'm stuck at setting up a WiFi connection. The connection is established, but the process doesn't continue. I can only skip, but then I get stuck at the next screen (copying apps and files) - regardless of what I select I get an error "Login not possible" ("Anmeldung nicht möglich") This did work in test15. Edited July 6, 2020 by SteffenWi 1 Quote Link to post Share on other sites
tdm 2,322 Posted July 6, 2020 Author Share Posted July 6, 2020 21 minutes ago, SteffenWi said: I've done a fresh installation (Full wipe and flashing of .img and .zip and gapps), but when I try to get through the setup wizard I'm stuck at setting up a WiFi connection. The connection is established, but the process doesn't continue. I can only skip, but then I get stuck at the next screen (copying apps and files) - regardless of what I select I get an error "Login not possible" ("Anmeldung nicht möglich") This did work in test15. Okay thanks. There may be something in selinux that is preventing it. We have two options: I can try to reproduce it here, or you can download a permissive boot image to try. Which do you prefer? 1 Quote Link to post Share on other sites
marmistrz 93 Posted July 6, 2020 Share Posted July 6, 2020 1 minute ago, tdm said: Okay thanks. There may be something in selinux that is preventing it. We have two options: I can try to reproduce it here, or you can download a permissive boot image to try. Which do you prefer? You can change the selinux mode without flashing a new image afaik: SELinuxModeChanger (Set SELinux mode on boot) - https://f-droid.org/app/com.mrbimc.selinux 1 Quote Link to post Share on other sites
EskeRahn 5,598 Posted July 6, 2020 Share Posted July 6, 2020 Installed Test 18. During boot after install it says "app keeps stopping" on the "Trebuchet". But it started non the less. ADD: Arrows works again 🙂 Quote Link to post Share on other sites
tdm 2,322 Posted July 6, 2020 Author Share Posted July 6, 2020 2 minutes ago, EskeRahn said: Installed Test 18. During boot after install it says "app keeps stopping" on the "Trebuchet". But it started non the less. ADD: Arrows works again 🙂 Both nova and trebuchet worked for me. Can you get a log? Anyone else having issues? Quote Link to post Share on other sites
EskeRahn 5,598 Posted July 6, 2020 Share Posted July 6, 2020 2 minutes ago, tdm said: Both nova and trebuchet worked for me. Can you get a log? Anyone else having issues? Restarting did NOT bring this back. I'll try a new flash and see if I get it again. 1 Quote Link to post Share on other sites
EskeRahn 5,598 Posted July 6, 2020 Share Posted July 6, 2020 19 minutes ago, EskeRahn said: Restarting did NOT bring this back. I'll try a new flash and see if I get it again. Flashed and did NOT get it. Flashed one more time, and did still not get it, 1 Quote Link to post Share on other sites
Hook 3,317 Posted July 6, 2020 Share Posted July 6, 2020 I flashed Test18. So far no problems. I use Nova. Arrow keys work again. 😄 1 1 Quote Link to post Share on other sites
SteffenWi 139 Posted July 6, 2020 Share Posted July 6, 2020 1 hour ago, marmistrz said: You can change the selinux mode without flashing a new image afaik: SELinuxModeChanger (Set SELinux mode on boot) - https://f-droid.org/app/com.mrbimc.selinux I'd try that but ...if I get to the part where I can install apks and change settings in them, I'm well past the wizard ;). @tdm I'd be ok with the permissive boot image. Quote Link to post Share on other sites
tdm 2,322 Posted July 6, 2020 Author Share Posted July 6, 2020 10 minutes ago, SteffenWi said: I'd try that but ...if I get to the part where I can install apks and change settings in them, I'm well past the wizard ;). @tdm I'd be ok with the permissive boot image. http://files.nwwn.com/android/pro1/lineage-16.0-pro1-test18-boot-permissive.img Just flash this with fastboot and see if the setup wizard can connect to wifi. Thanks! 1 Quote Link to post Share on other sites
SteffenWi 139 Posted July 6, 2020 Share Posted July 6, 2020 (edited) 18 minutes ago, tdm said: http://files.nwwn.com/android/pro1/lineage-16.0-pro1-test18-boot-permissive.img Just flash this with fastboot and see if the setup wizard can connect to wifi. Thanks! Just for clarification: The wizard does connect to WiFi, but it doesn't proceed after the connection is established. Thanks for uploading the image, will try it tomorrow! Edited July 6, 2020 by SteffenWi 2 1 Quote Link to post Share on other sites
acrux 56 Posted July 7, 2020 Share Posted July 7, 2020 (edited) 13 hours ago, SteffenWi said: I've done a fresh installation (Full wipe and flashing of .img and .zip and gapps), but when I try to get through the setup wizard I'm stuck at setting up a WiFi connection. The connection is established, but the process doesn't continue. I can only skip, but then I get stuck at the next screen (copying apps and files) - regardless of what I select I get an error "Login not possible" ("Anmeldung nicht möglich") This did work in test15. Could not confirm here. At first just flashed test18 over test17, but then rebooted to recovery, Wipe data / factory reset, sideloaded test18 to another slot, booted to initial setup and it passed the wifi setup with no problems (no sim card) and internet connection was present (time was updated). However - no gapps here. Edited July 7, 2020 by acrux 3 Quote Link to post Share on other sites
tdm 2,322 Posted July 7, 2020 Author Share Posted July 7, 2020 I've started the process of making this official. Someone took the time to actually review the device stuff, so I am fixing that now. Should have a mostly final build in the next day or two. I also need to create lineage wiki pages for the device which is always a couple hours of fun tracking down the device specs, finding a sample picture, writing instructions, etc. 8 Quote Link to post Share on other sites
EskeRahn 5,598 Posted July 7, 2020 Share Posted July 7, 2020 Allow me to put peoples attention to the below post, if anyone feel like sending TDM some (additional) 'beers' for his great work. 3 1 Quote Link to post Share on other sites
TeZtdevice 368 Posted July 7, 2020 Share Posted July 7, 2020 @tdm *ringring* *you got a sms* 🤝🍺 1 Quote Link to post Share on other sites
Vince 3 Posted July 7, 2020 Share Posted July 7, 2020 I think the only thing I'm missing is getting SafetyNet/ctsProfile working for google pay, then there's no going back to stock 🙂 Thanks again for all the hard work! 1 Quote Link to post Share on other sites
tdm 2,322 Posted July 7, 2020 Author Share Posted July 7, 2020 So I'm wading through all the commits to bring 16.0 up to 17.1 and I found a bunch of VoLTE props that are missing in 16.0. I probably removed those before I realized that VZW folks actually used VoLTE (the other major carrier that uses it is in India, which is probably why I removed those props). I would find a VZW customer to work with to test VoLTE with these props set, but I should have a VZW SIM shortly anyway. Long story short, looks like VoLTE will probably be working Real Soon Now. 1 Quote Link to post Share on other sites
SteffenWi 139 Posted July 7, 2020 Share Posted July 7, 2020 @tdm sorry, was a bit busy today, finally managed to flash the permissive image. For the record, I flashed the permissive image, did a factory reset, flashed the v18 .zip file, rebooted into recovery mode, flashed the GApps zip, rebooted and got into the wizard. I skipped the SIM question, because I don't have a SIM in the device, then connected to WiFi and as soon as the connection was established, the wizard started searching for updates and after that continued on as expected. 2 Quote Link to post Share on other sites
tdm 2,322 Posted July 7, 2020 Author Share Posted July 7, 2020 2 minutes ago, SteffenWi said: @tdm sorry, was a bit busy today, finally managed to flash the permissive image. For the record, I flashed the permissive image, did a factory reset, flashed the v18 .zip file, rebooted into recovery mode, flashed the GApps zip, rebooted and got into the wizard. I skipped the SIM question, because I don't have a SIM in the device, then connected to WiFi and as soon as the connection was established, the wizard started searching for updates and after that continued on as expected. Great, thank you. So you are confirming that the WiFi in the setup wizard does not work in enforcing, but it does work in permissive. Is that correct? 1 Quote Link to post Share on other sites
SteffenWi 139 Posted July 7, 2020 Share Posted July 7, 2020 (edited) That is correct @tdm The two important bits - I believe - of information here are that I have Google apps installed (the package you have linked on your site) and that I do not have a SIM card in the phone. Edited July 7, 2020 by SteffenWi 1 Quote Link to post Share on other sites
tdm 2,322 Posted July 8, 2020 Author Share Posted July 8, 2020 [tease] A wild 17.1 branch appears... https://github.com/tdm/android_device_fxtec_pro1/tree/lineage-17.1 [/tease] 2 1 Quote Link to post Share on other sites
acrux 56 Posted July 8, 2020 Share Posted July 8, 2020 (edited) 7 hours ago, SteffenWi said: @tdm sorry, was a bit busy today, finally managed to flash the permissive image. For the record, I flashed the permissive image, did a factory reset, flashed the v18 .zip file, rebooted into recovery mode, flashed the GApps zip, rebooted and got into the wizard. I skipped the SIM question, because I don't have a SIM in the device, then connected to WiFi and as soon as the connection was established, the wizard started searching for updates and after that continued on as expected. Shouldn't you flash the permissive image after you flash the test18 image? Currently it seems that you just proved, that there are no problems with test18 image and if there were any, they were resolved with factory reset? Of course, I could be totally wrong how I'm understanding the situation... Edited July 8, 2020 by acrux Quote Link to post Share on other sites
Posted by tdm,
Recommended by EskeRahn
5 reactions
Go to this post
