  • 1 month later...
  • Replies 222
I had to replace screen of my Pro1 again (after replacing it last Sunday) because of falling two times, first to concrete and then to tile (after not dropping it since years) and the last one caused it to have a lot of cracks of screen glass but otherwise it still worked perfectly (cracks made reading texts hard anyway).
So I have decided to replace it again - this was one of my latest display orders, so it had a margin unset, but I put it in a Pro1 which still has stock Android 9 installed and I felt is has solved margin problem (I could not reach top menu in landscape mode, then I could).
So I have glued the screen in my daily driver and assembled it.
Today, I have found something is still not looks to be okay as I can not reach applications at long corners or even send a message in Aliexpress (I can not press that button at all).
I have tried a touch screen area test which showed the following result - dots above are touch presses and below are finger dragging:
So basically screen seems to be okay (sensing all of its area) but it is insensitive for touches at the edge of the screen.
Now I have started thinking somehow it went back to default settings as I only see registers 0x805B and 0x805C are the related settings (and top/bottom parts are okay).
Does it the same way it worked after screen replacement without setting margins using stock OS?
(I may try to disassemble both devices again to try it again if it is the case)...
It is very annoying...
However, do anyone have have a clue about how to reach touch panel's registers under Android?
As far as I remember well, I was able to unload kernel module so touch panel stopped working under OS but I still could not reach I2C device for communication under chrooted Linux environment.
So an example code for Android which reads/writes register of an I2C device would be very welcome (what I could modify for doing these settings).
However, it may happen simply trying to access it after unloading kernel module may not be enough as well...
  • Sad 1
If you look again at the OP of this thread, the behaviour you observe is exactly as described for a screen having not reveived the "Stock-firmware-magic": The outer ~7 mm are insensitive to tapping but still correctly register dragging your finger form the central area outwards.
I had understood stock Android 9 does its touch-calibration thing only on first boot. So just connecting the screen to an already-installed stock-Pro1 might not be enough. I would try to facory-reset the "calibrating" device first.
Edited by claude0001
This device had stock state of Android (came from repair earlier) which I have updated to the latest software version yesterday (I was surprised update works at all).
After applied latest-1 update, I thought margin settings were modified and as far as I remember well, I could pull down Android nofitication bar in landscape orientation...
Now it is on build QX1000_EEA_20200707225313 (security 2020. april 05.)
So now I put the display to this device, did a factory reset and I still cannot pull down notification bar of Android in landscape mode... Currently I don't understand why it does not apply this setting (other than if it checks only the other setting before modify which seems to be set correctly).
Do anyone has the 3rd-party modificator app and its applying instuctions?
Anyway, before I moved to LineageOS, I put all of my displays once to the phone to set margin and I did not have any problems installing those screens... but I have received this one after moving to LineageOS - so I think it should also do it without a factory reset...
Yesterday I really felt this setting was applied, that was why I moved forward every OTA update steps on the phone and checked it works, otherwise I would have been applied another screen which is a bit worse at edges.
So I really don't understand it...
It might be slightly worse than that, that is one might need to reflash, not 'only' factory reset,
Anyway, it went to update written above and in this thread, there is 20200825 written (against 20200707)...
...I will try to install that one...
So... I had to unlock bootloader of this phone - as far as I remember well, it was initially unlocked and I am sure I have enabled offline charging which was currently disabled.
(It went for repair and received back a long time ago.)
As I wrote above, it was still at the very first stock image which I was able to update yesterday step-by-step (lot of updates), up to "QX1000_EEA_20200707225313 (security level 2020. april 05.)".
Now I have installed latest stock using fastboot and it currently has "QX1000_EEA_20200825231443_20200825-2316" and same security patch level.
So I think only the very last update was missing although system showed to be up-to-date.
Also, after updating, display margin was set correctly (but as far as I remember well, this setting was included prior latest update).
I will try it after my recently ordered screens arriving (I think from the same location where my currently installed screen comes from), maybe I will also order a few after weekend.
So, thank you @claude0001  and @EskeRahn your help, now my replaced display works well in my daily driver.
I will check if it also sets my last ordered displays to proper margin setting.
However, if somebody has an example code of Android handling an I2C device, it would be very welcome. 🙂
(I don't know if that is as simple as unloading touch-handler or reaching the hardware is only possible upon boot, prior loading anything related.)
So it currently works well, thank you your help.
This would indeed be welcome if there was a simple way of doing what ever is needed to program the display, isolated, and not as a part of a whole full flash.
  • 5 months later...
Just ran into the same issue on my 2nd display swap. First one had no issues immediately but then pink vertical line appeared outside the return/refund window.
This one I need to get it to register touches on the side it seems. I take it there's still no easy fix and I'll need to backup, flash stock and only then AICP?
Edited by Adrienspawn
I think this is the easiest fix we currently know of. I personally haven't found other ways since that post (and alas, I have replaced my screen a few times since then):
  • 1 year later...
It's 2025, and I am going to necro the sh1t out of this thread because it confused me a lot ... but helped me getting the touchscreen on my replacement display for my Pro1 to work properly 😁
Essentially, Kaali said it all and provided the correct files. I uploaded translated and modified instructions as a PDF.
I don't know why the instructions say to start the GTP Tools directly after installing it, because it just crashed since it can't access the hardware yet. The "fix" are the adb commands, which can also be performed in Termux (as SU) on the phone itself. Set SELinux permissive (setenforece 0), and chmod 777 /proc/gmnode0404302 (same for all Pro1?). After that, the GTP Tools app started without error, and I could flash the provided firmware "GT9286_1.1.28(3C02).bin".
The touchscreen was responsive to the very edge right away. It stayed this way after I powered down my phone and switched it on again. This was very easy and seemed a safe procedure on my LOS 17.1.
Oh, and I did not follow the last instruction to flash back the "Releasese Version", whatever that means.
GTP Tools APK and firmware:
On 5/21/2022 at 8:09 AM, Kaali said:
TP固件烧录指南.zh-CN.en.pdf
Edited by daniel.schaaaf
  • Thanks 4
This is very interesting, and seems a LOT easier than flashing to stock on a Pro1. But I lack one crucial detail, did you do this on a Pro1 or a Pro1X. It would be SO great if you provided a method for finally doing this on a Pro1X, as this has previously not been known (previously the trick was to mount the display on an a mule Pro1, and flash that to stock, and then move the display back)
Sorry to disappoint you, I own the older Pro1 model. I edited my posting accordingly.
Maybe I misunderstood what I read in this thread. I got the impression that even for the Pro1 we would have to re-flash Android, and I was excited to see that the app was able to flash the display directly on a running LOS.
Oh indeed this is also simpler for Pro1, but would be really great if it also worked for pro1X, where there are no known fix at all (except using a Pro1 to do it)
The main problem for the Pro1x is that the app doesn't work on any version of Android after Android 10 (Lineage 17) and the Pro1x doesn't have any options older than Android 11.
  • Sad 1
I am sure people tried their luck on the Pro1X. I just wanted to say that the app warns about having been built for an older Android version on LOS 17.1 (Android 10) too, and still works as intended.
  • 3 weeks later...
Does not work you mean cannot be installed or cannot work correctly?
...i can test to edit apk for newer api support.
BUT first - have you tested apk sideload from pc?
Test this:
adb install --bypass-low-target-sdk-block path/to/PACKAGE.apk
EDIT - adb install is working on los22.2. If apk runs correctly i am not sure
Edited by CornholioGSM
Test this:
Interesting,  I *think* but do not know that it means does not work correctly.  The trouble is, to test it, I would need to replace the screen, and I'd rather not.  Lol.  But you raise a good possibility. If I ever have a screen fail on my Pro1x, I will test.
I have now crazy problem with my display (pro1-not X).
On classic phones will it be for 99% mechanical/water damage problem.
Yesterday my phone was out of battery...only 4%batt.
I was inside tipping message when my display starts to self press random touch pressing. Pressing and pressing until powering off - out of battery.
( This same problem was on old motorola phones - low battery = problem with digitizer, bad charger = problem with digitizer)
Ok phone was charged to full...but problem still.
So i have removed display from frame - all dust etc i have cleaned and then glued it again to frame.
More testing tomorrow
...i am now on spare display from FX with black corners.
soo back to ^^.
Tomorrow i will test to replace display back and maybe it will be good...or not 🙂 😞
Then i will test to "reflash or recalibrate" display.
*** i am now on spare display - old display delivered when my phone was new. Blinded colors on low brightness and black corners 😞
The same thing happened to my Pro1 about a month before the end of its 2 year warranty. Replacing the screen didn't fix it, so it isn't the screen or at least not entirely. Luckily this was 2021 and FxTec accepted it for warranty repair. I had to wait 6 months until they got their Pro1 parts shipments. Unfortunately, I didn't ask what the exact problem was and what they did to fix it. I was just happy to get my phone back 6 months later. It has never reoccurred.
By me it is display problem - i have installed my old display with bad black corners and all is working...so thats relative good.
I am now inside searching on internet for display  without bad corners.
  • 3 months later...
Hello,
Soo today i have tested today touch fix on new display from ali.
Method with goodix app does not work on los22...all was fine...selinux set, read data from display was working too, but after flashing new firmware phone makes reboot and nothing - still same.
But method - flashing stock rom without wipe, wait for boot and then flash back los22 works fine 🙂
...only reinstal magisk was needed
  • Thanks 4
