EskeRahn 5,596 Posted December 28, 2021 Share Posted December 28, 2021 (lineage-18.1-20211227-nightly-pro1-signed.zip on December 5 security patch installed smoothly using OTA ) ...But the reintroduced (early August) Accessibility / keyboard bug is not (yet) fixed. The stage after download and install called "Finalising package installation" is surprising slow though) 1 Quote Link to post Share on other sites
VaZso 1,999 Posted December 28, 2021 Share Posted December 28, 2021 2 hours ago, EskeRahn said: (lineage-18.1-20211227-nightly-pro1-signed.zip on December 5 security patch installed smoothly using OTA ) I am afraid this version is exactly the same as previous version was (because of Christmas). 🙂 (I look at the changelog for every new releases and this was the only one yet which did not had any changes. 🙂 ) 2 Quote Link to post Share on other sites
EskeRahn 5,596 Posted January 10, 2022 Share Posted January 10, 2022 (lineage-18.1-20220110-nightly-pro1-signed.zip on 2021 December 5 security patch installed smoothly using OTA ) ...But the reintroduced (early August) Accessibility / keyboard bug is not (yet) fixed. The stage after download and install called "Finalising package installation" is surprising slow though) 1 Quote Link to post Share on other sites
Rob. S. 1,667 Posted January 10, 2022 Share Posted January 10, 2022 On 11/17/2021 at 11:28 AM, Rob. S. said: On 11/6/2021 at 1:34 PM, Rob. S. said: [...] The most obvious difference to the earlier behaviour, by the way, is also a slight improvement: While earlier a failure to charge (along with entering the "not charging" mode) still showed a battery plus flash symbol in the status area as if it was charging, now the flash doesn't even appear, so I can at least see that it doesn't charge without having to open the AccA or Accu Battery app to check. On 11/12/2021 at 2:59 PM, Rob. S. said: Following up to my last post: since the 18.1-20211108-NIGHTLY-pro1 OTA update on Monday I haven't observed any charging interruptions so far. Spoken too soon; in the morning (now on 18.1-20211115-NIGHTLY-pro1), while connected, the battery was down to 20%, there was no flash symbol in the status bar and AccA again reported "not charging". (It's been some time, but I think the latter should have read "there was a flash symbol"...) Strange things continue to happen. Today, just before successfully updating to 18.1-20220110-NIGHTLY-pro1, the phone was down to 28%, "discharging", no flash symbol, while being connected to a charger. No connection problem, I immediately tried different cables and chargers. After reboot, charging immediately started again... 1 Quote Link to post Share on other sites
EskeRahn 5,596 Posted January 11, 2022 Share Posted January 11, 2022 10 hours ago, Rob. S. said: (It's been some time, but I think the latter should have read "there was a flash symbol"...) Strange things continue to happen. Today, just before successfully updating to 18.1-20220110-NIGHTLY-pro1, the phone was down to 28%, "discharging", no flash symbol, while being connected to a charger. No connection problem, I immediately tried different cables and chargers. After reboot, charging immediately started again... Are yours actually discharging while connected? What I have seen is that it 'stabilise' around the current value (plus minus a few percent-points) Quote Link to post Share on other sites
Rob. S. 1,667 Posted January 11, 2022 Share Posted January 11, 2022 (edited) 30 minutes ago, EskeRahn said: Are yours actually discharging while connected? What I have seen is that it 'stabilise' around the current value (plus minus a few percent-points) Cannot say whether it's discharging as quickly as it would be without being connected, but yes, my impression is that in both cases (both the "not charging" state and, like this time, "discharging"), the phone is actually discharging. I'll have a closer look, though, as I'm also running the AccuBattery app which should be able to authoritatively answer that question. [Edit:] Yesterday: 06:52: used for 32m, 75% -> 70% (this was the normal discharge cycle. After that, charging should have started again) 07:24: used for 7h 38m, 71% -> 28% (connected all the time; at 28%, state was "discharging" [no flash symbol], while I cannot rule out that the state might have been "not charging" [flash symbol showing] earlier in that period). Edited January 11, 2022 by Rob. S. 1 Quote Link to post Share on other sites
EskeRahn 5,596 Posted January 11, 2022 Share Posted January 11, 2022 1 hour ago, Rob. S. said: 07:24: used for 7h 38m, 71% -> 28% (connected all the time; at 28%, state was "discharging" [no flash symbol], while I cannot rule out that the state might have been "not charging" [flash symbol showing] earlier in that period). Oh. Too bad, so this means there are TWO errors (related or not), of not charging substantially and not charging at all while connected. Both fixed (for a while) by a reboot... Quote Link to post Share on other sites
EskeRahn 5,596 Posted January 17, 2022 Share Posted January 17, 2022 (lineage-18.1-20220117-nightly-pro1-signed.zip on 2021 December 5 security patch installed smoothly using OTA ) ...But the reintroduced (early August) Accessibility / keyboard bug is not (yet) fixed. The stage after download and install called "Finalising package installation" is surprising slow though) 1 Quote Link to post Share on other sites
dreamflasher 120 Posted January 19, 2022 Share Posted January 19, 2022 On 1/11/2022 at 12:52 PM, EskeRahn said: Oh. Too bad, so this means there are TWO errors (related or not), of not charging substantially and not charging at all while connected. Both fixed (for a while) by a reboot... Just came here to see if someone else is having these charging issues. So yeah, looks like I am not alone – I have exactly the same thing. It started happening last year in December. So I guess it's a software issue? 1 Quote Link to post Share on other sites
EskeRahn 5,596 Posted January 19, 2022 Share Posted January 19, 2022 1 hour ago, dreamflasher said: . So I guess it's a software issue? Yes, We see it/them on LineageOS & AICP not stock android. As said earlier my guess is that at least the one keeping it at around a fixed low level is the battery protection system added, that kicks in under wrong conditions. (A system to avoid overcharging an already fully charged battery) 1 Quote Link to post Share on other sites
Wheeljack 212 Posted January 22, 2022 Author Share Posted January 22, 2022 I've seen the charging issue too over past few weeks. Usually I turn my phone off overnight so that means a clean start each morning. I see this issue come up when I'm heavily using the phone during the day and I recharge to 100% then use it some more and want to top out again starting between 70%-80%. I see the battery level just stuck at 78% or whatever it was when plugged in, so I'm with your self-sustaining power draw theory. 1 Quote Link to post Share on other sites
Jacob_S 128 Posted January 24, 2022 Share Posted January 24, 2022 For me this appears regularly after the phone went to Energy Saving Mode (I have the setting active, that it automatically does that below 15% remaining charge). The same with the issue of some apps not being able to use the internet, even though in others it works (described in the AICP thread). That also happens while Energy Saving Mode is active and persists even when the phone is recharged afterwards. So from my experience I would have suspected Energy Saving Mode as the culprit. But as some here seem to observe the same issue(s) without it, it maybe really is about heavy usage causing a too quick energy drain, which then triggers some system meant to slow down the discharge or protect the battery. Quote Link to post Share on other sites
EskeRahn 5,596 Posted January 24, 2022 Share Posted January 24, 2022 (lineage-18.1-20220124-nightly-pro1-signed.zip on January 5 security patch installed smoothly using OTA ) ...But the reintroduced (early August) Accessibility / keyboard bug is not (yet) fixed. The stage after download and install called "Finalising package installation" is surprising slow though) 1 Quote Link to post Share on other sites
EskeRahn 5,596 Posted January 31, 2022 Share Posted January 31, 2022 (lineage-18.1-20220131-nightly-pro1-signed.zip on January 5 security patch installed smoothly using OTA ) ...But the reintroduced (early August) Accessibility / keyboard bug is not (yet) fixed. The stage after download and install called "Finalising package installation" is surprising slow though) 2 Quote Link to post Share on other sites
EskeRahn 5,596 Posted February 10, 2022 Share Posted February 10, 2022 (lineage-18.1-20220207-nightly-pro1-signed.zip on January 5 security patch installed smoothly using OTA ) ...But the reintroduced (early August) Accessibility / keyboard bug is not (yet) fixed. The stage after download and install called "Finalising package installation" is surprising slow though) 1 Quote Link to post Share on other sites
EskeRahn 5,596 Posted February 14, 2022 Share Posted February 14, 2022 (lineage-18.1-20220214-nightly-pro1-signed.zip on January 5 security patch installed smoothly using OTA ) ...But the reintroduced (early August) Accessibility / keyboard bug is not (yet) fixed. The stage after download and install called "Finalising package installation" is surprising slow though) 2 Quote Link to post Share on other sites
EskeRahn 5,596 Posted February 21, 2022 Share Posted February 21, 2022 (lineage-18.1-20220221-nightly-pro1-signed.zip on February 5 security patch installed smoothly using OTA ) ...But the reintroduced (early August) Accessibility / keyboard bug is not (yet) fixed. The stage after download and install called "Finalising package installation" is surprising slow though) 1 Quote Link to post Share on other sites
EskeRahn 5,596 Posted February 28, 2022 Share Posted February 28, 2022 (lineage-18.1-20220228-nightly-pro1-signed.zip on February 5 security patch installed smoothly using OTA ) ...But the reintroduced (early August) Accessibility / keyboard bug is not (yet) fixed. The stage after download and install called "Finalising package installation" is surprising slow though) 1 Quote Link to post Share on other sites
Rob. S. 1,667 Posted March 1, 2022 Share Posted March 1, 2022 On 10/25/2021 at 2:00 PM, Rob. S. said: The hiccup was that the phone, after restarting and then displaying the LineageOS animation for 20 minutes or so, booted into some kind of recovery, showing this screen (but after hitting 'try again', the system came up without problems in normal time, i.e. a few seconds) : Now of course I wonder whether this was caused by something in the update or maybe my phone is developing a problem...? I can finally clear this up! It was indeed the latter. After yesterday's LOS update the animation was up for three hours or so until I stopped it by switching the phone off with a power long-press, after which it booted up normally—but without any trace of my 512 GB Kingston "Canvas Go! Plus" micro sd card. Seems a file system check was taking it so long. (On my laptop, I could read the card ok, but a file system check aborted with read errors.) Definitely one of the more expensive cards I bought, and it seems it doesn't do much (if any) wear levelling. Never happened to me before except with really cheap cards in Raspberry Pis. Ordered a SanDisk card now... 3 Quote Link to post Share on other sites
claude0001 1,422 Posted March 1, 2022 Share Posted March 1, 2022 (edited) 6 hours ago, Rob. S. said: I can finally clear this up! Thanks for sharing. Few would think about the SD card being the reason for the long boot time. Good luck with your next card. I've had a Sandisk Extreme 256 GB almost since day one. I run my GNU/Linux chroot on it (which certainly causes above-average disk-I/O) and it still hasn't failed me. Edited March 1, 2022 by claude0001 2 Quote Link to post Share on other sites
EskeRahn 5,596 Posted March 7, 2022 Share Posted March 7, 2022 (lineage-18.1-20220307-nightly-pro1-signed.zip on February 5 security patch installed smoothly using OTA ) ...But the reintroduced (early August) Accessibility / keyboard bug is not (yet) fixed. The stage after download and install called "Finalising package installation" is surprising slow though) 1 Quote Link to post Share on other sites
Rob. S. 1,667 Posted March 7, 2022 Share Posted March 7, 2022 On 11/4/2021 at 2:43 PM, Rob. S. said: [...] I've had several occasions in which charging wouldn't start after connecting, with the state still "discharging"? I cannot totally exclude the possibility that in some of those cases AccA was keeping the device in "discharging" mode because the lower limit wasn't reached yet, but I don't think that was the case in all those occasions here... Just for the record, with last Monday's update I again had several occasions of the phone not charging, but the state being "discharging" with a negative charging current and no flash symbol in the status bar, contrary to the usual "not charging" state with a small, two-digit positive current and the flash symbol showing. Downloading the new update now... Quote Link to post Share on other sites
Rob. S. 1,667 Posted March 7, 2022 Share Posted March 7, 2022 (edited) [deleted] Edited March 8, 2022 by Rob. S. 1 Quote Link to post Share on other sites
EskeRahn 5,596 Posted March 14, 2022 Share Posted March 14, 2022 (lineage-18.1-20220314-nightly-pro1-signed.zip on March 5 security patch installed smoothly using OTA ) ...But the reintroduced (early August) Accessibility / keyboard bug is not (yet) fixed. The stage after download and install called "Finalising package installation" is surprising slow though) 1 1 Quote Link to post Share on other sites
EskeRahn 5,596 Posted March 16, 2022 Share Posted March 16, 2022 There might be something rotten in the new version, it eats battery at an alarming rate while idle. (same programs running, most killed with Greenify as usual, and according to Gsam, the apps is responsible for less than 1%. No phone connection, WiFi only - it is the preproduction unit with no Imei) (Before charge was the old version. charged and upgraded) 1 Quote Link to post Share on other sites
