gelraen.ua 33 Posted January 28, 2020 Share Posted January 28, 2020 Is there way to customize notification LED? Problem I'm facing right now is that while connected to power and already fully charged, LED is shining in bright green. And because I normally charge my phone overnight, this means that it illuminates half the room the whole night. I've tried to use https://play.google.com/store/apps/details?id=com.koo.lightmanager3, but it seems to have no effect whatsoever. 2 Quote Link to post Share on other sites
VaZso 1,999 Posted January 28, 2020 Share Posted January 28, 2020 10 minutes ago, gelraen.ua said: Is there way to customize notification LED? Problem I'm facing right now is that while connected to power and already fully charged, LED is shining in bright green. And because I normally charge my phone overnight, this means that it illuminates half the room the whole night. I've tried to use https://play.google.com/store/apps/details?id=com.koo.lightmanager3, but it seems to have no effect whatsoever. Maybe try Light Manager to set up custom notifications. Quote Link to post Share on other sites
EskeRahn 5,598 Posted January 28, 2020 Share Posted January 28, 2020 It was controllable early on, but they changed that, as the placement of the individual RGB had the effect that in some angles one were more or less blocked, giving a wrong resulting colour. So what is best/worst is hard to say. But as so many details, it COULD be an option people could choose. ADD: If is still controllable here, though the simple app that previously worked for me no longer does, the one linked in the above two posts does work. 3 2 Quote Link to post Share on other sites
Slion 1,201 Posted January 28, 2020 Share Posted January 28, 2020 (edited) That LED is definitely too bright making it not so nice to use the phone while charging in the dark. It won't keep me awake at night though 😁 Edited January 28, 2020 by Slion Quote Link to post Share on other sites
Slion 1,201 Posted January 28, 2020 Share Posted January 28, 2020 1 hour ago, VaZso said: I've tried to use https://play.google.com/store/apps/details?id=com.koo.lightmanager3, but it seems to have no effect whatsoever. You could try a hardware workaround using one of those LED dimmer stickers. 1 Quote Link to post Share on other sites
Slion 1,201 Posted January 28, 2020 Share Posted January 28, 2020 21 minutes ago, Slion said: You could try a hardware workaround using one of those LED dimmer stickers. Or put it face down while sleeping 😁 3 2 Quote Link to post Share on other sites
EskeRahn 5,598 Posted January 28, 2020 Share Posted January 28, 2020 20 minutes ago, Slion said: You could try a hardware workaround using one of those LED dimmer stickers. If I will ever be in need of changing the display, I would experiment with some diffuser 🙂 1 Quote Link to post Share on other sites
gelraen.ua 33 Posted January 28, 2020 Author Share Posted January 28, 2020 9 hours ago, EskeRahn said: It was controllable early on, but they changed that, as the placement of the individual RGB had the effect that in some angles one were more or less blocked, giving a wrong resulting colour. So what is best/worst is hard to say. But as so many details, it COULD be an option people could choose. I would appreciate even controlling whether it's on or off for a particular event and level of brightness. Controlling color is much less important for me here 🙂 1 Quote Link to post Share on other sites
CornholioGSM 370 Posted January 28, 2020 Share Posted January 28, 2020 ...i mean that best app for led colors, flashing etc is LightFlow 2 Quote Link to post Share on other sites
Slion 1,201 Posted January 28, 2020 Share Posted January 28, 2020 4 minutes ago, CornholioGSM said: ...i mean that best app for led colors, flashing etc is LightFlow Is it working with Pro1? Quote Link to post Share on other sites
CornholioGSM 370 Posted January 28, 2020 Share Posted January 28, 2020 i dont know...but why not...led is controlled same way as on other phones. Download free version and test it 🙂 Quote Link to post Share on other sites
Jordi 72 Posted January 29, 2020 Share Posted January 29, 2020 (edited) I just tried Light Manager and it's working. There is advertisements but hopefully only when the app is open, i.e. during the set up. Let's see if it doesn't consume too much battery. Edit: it's called Light manager 2 Edit 2 : I just tried setting different colors for different apps. Edited January 29, 2020 by Jordi 1 Quote Link to post Share on other sites
_DW_ 628 Posted January 29, 2020 Share Posted January 29, 2020 On 1/28/2020 at 12:49 PM, Slion said: Or put it face down while sleeping 😁 I always do that with phones for this very reason. Also those pesky emails in the middle of the night!! 2 Quote Link to post Share on other sites
_DW_ 628 Posted January 29, 2020 Share Posted January 29, 2020 37 minutes ago, Jordi said: I just tried Light Manager and it's working. There is advertisements but hopefully only when the app is open, i.e. during the set up. Let's see if it doesn't consume too much battery. Edit: it's called Light manager 2 If it does the job just buy it 😉 1 Quote Link to post Share on other sites
EskeRahn 5,598 Posted January 29, 2020 Share Posted January 29, 2020 1 hour ago, _DW_ said: I always do that with phones for this very reason. Also those pesky emails in the middle of the night!! (If you do not want to be disturbed, use aeroplane mode. Quick to turn on/off and saves battery) 2 Quote Link to post Share on other sites
jjarmasz 81 Posted January 29, 2020 Share Posted January 29, 2020 I just tried it - it doesn't seem to let you turn off the LED when it's charging, just control the lights for different app notifications. Guess I'll have to go back to keeping the phone face-down when it's charging overnight... 1 1 Quote Link to post Share on other sites
Siani_8 105 Posted January 29, 2020 Share Posted January 29, 2020 15 hours ago, CornholioGSM said: ...i mean that best app for led colors, flashing etc is LightFlow I think light flow works best and has more options for rooted users from what I remember. 1 Quote Link to post Share on other sites
gelraen.ua 33 Posted January 29, 2020 Author Share Posted January 29, 2020 16 hours ago, CornholioGSM said: ...i mean that best app for led colors, flashing etc is LightFlow Nope, doesn't work. I mean, it does work for app notifications, but not for what I want to do: LED still lights up when charger is plugged in, despite having a rule in LightFlow to turn it off when charging. 1 Quote Link to post Share on other sites
Siani_8 105 Posted January 29, 2020 Share Posted January 29, 2020 (edited) 36 minutes ago, gelraen.ua said: Nope, doesn't work. I mean, it does work for app notifications, but not for what I want to do: LED still lights up when charger is plugged in, despite having a rule in LightFlow to turn it off when charging. With root access you may also look into Tasker. Can do just about anything with that and it's plugins though there is a learning curve. Chances are though that someone has already tried to do what your asking and may be able to google and find out what steps they took with the app. Edit: Had name of the app wrong. Here's someone on Reddit asking the same thing for another phone and someone replying with how to do it with Trigger. https://www.google.com/amp/s/amp.reddit.com/r/tasker/comments/2qa3vh/request_disable_led_notification_light_while This one has a time profile attached also but it's possible with Tasker. Edited January 29, 2020 by Siani_8 Quote Link to post Share on other sites
CornholioGSM 370 Posted January 29, 2020 Share Posted January 29, 2020 (edited) 6 hours ago, gelraen.ua said: Nope, doesn't work. I mean, it does work for app notifications, but not for what I want to do: LED still lights up when charger is plugged in, despite having a rule in LightFlow to turn it off when charging. ...and what about set black color for charging? 🙂 EDIT ... correct...not working for charging notification ( Edited January 29, 2020 by CornholioGSM Quote Link to post Share on other sites
auvo.salmi 135 Posted January 29, 2020 Share Posted January 29, 2020 The green led really is quite annoying and too bright at night. With nowadays fast charging, there's not so much point on having charging notification leds at all, as you know that when you stick the charger cable in, the battery will be fully charged in an hour at max.. Compared to older phones, when charging took several hours and it was useful to monitor it somehow. Of course having a charging notification is useful in some situations, when your phone is powered off so you won't know otherwise if it's charging or not... But would be nice to for example to have the charging notification led connected to a notification, and by dismissing the notification you could dismiss the led notification too. Just like it works with other notifications, like messages. Quote Link to post Share on other sites
EskeRahn 5,598 Posted January 29, 2020 Share Posted January 29, 2020 37 minutes ago, auvo.salmi said: The green led really is quite annoying and too bright at night. With nowadays fast charging, there's not so much point on having charging notification leds at all, as you know that when you stick the charger cable in, the battery will be fully charged in an hour at max.. Compared to older phones, when charging took several hours and it was useful to monitor it somehow. Of course having a charging notification is useful in some situations, when your phone is powered off so you won't know otherwise if it's charging or not... But would be nice to for example to have the charging notification led connected to a notification, and by dismissing the notification you could dismiss the led notification too. Just like it works with other notifications, like messages. I'm repeating my self from many other threads, but do not do fast charging for a daily basis. It will shorten the lifespan of the battery. Sure the battery is replaceable but not easy user-replaceable. Fast charging is like junk food. Fast and convenient, and fine for occasional use, but very unhealthy for daily usage. 2 2 Quote Link to post Share on other sites
John Veness 57 Posted January 30, 2020 Share Posted January 30, 2020 10 hours ago, EskeRahn said: do not do fast charging for a daily basis What should we do instead? Quote Link to post Share on other sites
EskeRahn 5,598 Posted January 30, 2020 Share Posted January 30, 2020 16 minutes ago, John Veness said: What should we do instead? Use a slow charger. Either an old one, a charger with both a slow and quick charge ports, or usb port on a PC, or any other equipment with a low power output. I would suggest to stay at 5W and under (Many old chargers offers 5V 1A, and thus 5W). The problem is that the worst condition for a battery is charging heated. See e.g. this (This is a practical solution, though the print on the slow ports say 2.1A, it actually only provides 5W to the devices I tested, just as wanted) See also this thread 2 2 Quote Link to post Share on other sites
Craig 1,435 Posted February 7, 2020 Share Posted February 7, 2020 We really need stickies in this forum for info like this. I only really learned this here myself. Now, if I'm going to charge overnight, I use an older slow charger (or from a PC i leave on overnight). Quick charger is now reserved for when I'm getting ready to go out and see my phone isn't full enough, as it can add a lot of charge real quick. 5 Quote Link to post Share on other sites
