EskeRahn 5,598 Posted May 11, 2022 Share Posted May 11, 2022 (lineage-19.1-20220509-nightly-pro1-signed.zip on April 5 security patch installed smoothly using adb sideload and MindTheGapps-12.1.0-arm64-20220416_174313) 1 Quote Link to post Share on other sites
EskeRahn 5,598 Posted May 16, 2022 Share Posted May 16, 2022 (lineage-19.1-20220516-nightly-pro1-signed.zip on May 5 security patch installed smoothly using adb sideload and MindTheGapps-12.1.0-arm64-20220416_174313) EDIT:Warning the Android Market (AKA "play store") is gone! I tried to do the flashing again - same result. I re-installed last weeks 20220509 - requiring a factory reset, and got it back EDIT II: Re-install of today's 0516 on the freshly factory reset did not remove it again. So everything is working - loosing everything by the factory reset obviously....... Quote Link to post Share on other sites
EskeRahn 5,598 Posted May 16, 2022 Share Posted May 16, 2022 On 5/2/2022 at 10:32 PM, EskeRahn said: I tried the described unplug and replug a few times and WAS able to reproduce it twice. Trying to narrow it down, I can no longer provoke it. So it might also be a matter of the charge level, so it only occur under a certain level? But thanks anyway, we really need a way to make it reproducable, for anyone to be able to track it down. Just retried this at 44%. and was not able to trigger it. So we still lacks a secure way to reproduce the bug. Quote Link to post Share on other sites
Sean McCreary 328 Posted May 16, 2022 Share Posted May 16, 2022 15 hours ago, EskeRahn said: (lineage-19.1-20220516-nightly-pro1-signed.zip on May 5 security patch installed smoothly using adb sideload and MindTheGapps-12.1.0-arm64-20220416_174313) EDIT:Warning the Android Market (AKA "play store") is gone! I tried to do the flashing again - same result. I re-installed last weeks 20220509 - requiring a factory reset, and got it back EDIT II: Re-install of today's 0516 on the freshly factory reset did not remove it again. So everything is working - loosing everything by the factory reset obviously....... I haven't experienced this problem, and I don't think anything we changed in the May 16th build would cause this. I talked to a MindTheGapps maintainer, and he has seen this sort of problem if the device isn't rebooted (to recovery) between sideloading LineageOS and MindTheGapps, or if there isn't enough available space on the device. Are either of these a possible cause in your case? 1 Quote Link to post Share on other sites
CornholioGSM 370 Posted May 17, 2022 Share Posted May 17, 2022 Soo i am now littlebit scared...update or dont update and wait for new update? 🙂 Quote Link to post Share on other sites
EskeRahn 5,598 Posted May 17, 2022 Share Posted May 17, 2022 20 hours ago, Sean McCreary said: I haven't experienced this problem, and I don't think anything we changed in the May 16th build would cause this. I talked to a MindTheGapps maintainer, and he has seen this sort of problem if the device isn't rebooted (to recovery) between sideloading LineageOS and MindTheGapps, or if there isn't enough available space on the device. Are either of these a possible cause in your case? Nope, flashing was done with the same bat-file I use each time, and this includes booting. Note that other GApps where still there - so pretty weird. And the phone was practically empty, so that was not the case either. Note that I did NOT make a factory reset when going from 18 to 19, AND that switch included being forced to switch from OpenGapps to MiindTheGapps - so that could be the real cause. (I was quite surprised that the Gapps-switch worked in the first place) Quote Link to post Share on other sites
silversolver 849 Posted May 19, 2022 Share Posted May 19, 2022 On 5/2/2022 at 8:57 AM, agent008 said: Great news! I'm reinstalling today because I replaced my screen (again) and need to go back to stock to make the touch digitiser to work. Has anybody at this point tried Magisk and Google Pay? That's worrying; I need to replace my screen, and wondered how physically difficult it was, but why do we have to go back to stock to make it work? Quote Link to post Share on other sites
EskeRahn 5,598 Posted May 19, 2022 Share Posted May 19, 2022 2 hours ago, silversolver said: That's worrying; I need to replace my screen, and wondered how physically difficult it was, but why do we have to go back to stock to make it work? The tap sensitive margins have to be programmed correctly. If you ask WHY the screens comes with some other default - I have no idea.... Quote Link to post Share on other sites
silversolver 849 Posted May 19, 2022 Share Posted May 19, 2022 7 hours ago, EskeRahn said: The tap sensitive margins have to be programmed correctly. If you ask WHY the screens comes with some other default - I have no idea.... How annoying. Is the necessary programming function something that could be put in an APK to avoid having to completely rework your software for a simple screen change? Of course I'm hijacking this thread with an OT now..... Quote Link to post Share on other sites
EskeRahn 5,598 Posted May 19, 2022 Share Posted May 19, 2022 We have that debate in a display thread, but no known fix less flashing currently. Quote Link to post Share on other sites
VaZso 1,999 Posted May 19, 2022 Share Posted May 19, 2022 1 hour ago, silversolver said: How annoying. Is the necessary programming function something that could be put in an APK to avoid having to completely rework your software for a simple screen change? Of course I'm hijacking this thread with an OT now..... I don't think a simple APK may do it. Anyway, I have tried to experiment a little bit (see display thread mentioned by @EskeRahn), but I don't really know much about Android working and how it may be consulted to release touch panel. I was able to unbind it (it stopped working under system) but still I could not reach hardware yet. However, I have only tried to write a C code (basically for Linux)... okay, and i2cdetect. 🙂 We have a potentially good data sheet for its touch controller which has two registers what we need to modify, so the job seems to be clear but we would need access to the hardware... 3 Quote Link to post Share on other sites
Kaali 77 Posted May 21, 2022 Share Posted May 21, 2022 On 5/19/2022 at 3:21 PM, silversolver said: How annoying. Is the necessary programming function something that could be put in an APK to avoid having to completely rework your software for a simple screen change? Of course I'm hijacking this thread with an OT now..... There is an APK to flash the screen firmware but it only works on Android 10 or lower (basically stock or LoS16 or 17) 1 Quote Link to post Share on other sites
Wheeljack 212 Posted May 22, 2022 Share Posted May 22, 2022 On 5/2/2022 at 10:32 PM, EskeRahn said: I tried the described unplug and replug a few times and WAS able to reproduce it twice. Trying to narrow it down, I can no longer provoke it. So it might also be a matter of the charge level, so it only occur under a certain level? FWIW I've just had my phone charging from about 30% to 52% on an Anker wall charger then unplugged it to bring it to my desk where I just plugged i the phone again into a significantly less powerful USB port of my PC. The charging LED did't even turn on and of course it stayed at 52%. 1 Quote Link to post Share on other sites
Rob. S. 1,667 Posted May 22, 2022 Share Posted May 22, 2022 2 hours ago, Wheeljack said: On 5/2/2022 at 10:32 PM, EskeRahn said: I tried the described unplug and replug a few times and WAS able to reproduce it twice. Trying to narrow it down, I can no longer provoke it. So it might also be a matter of the charge level, so it only occur under a certain level? FWIW I've just had my phone charging from about 30% to 52% on an Anker wall charger then unplugged it to bring it to my desk where I just plugged i the phone again into a significantly less powerful USB port of my PC. The charging LED did't even turn on and of course it stayed at 52%. Earlier I thought the charging LED not turning on was a sign of the software based charging issue having somehow changed, but at least with my device it's (at least mostly) a bad physical connection between charger/PC and battery. Unfortunately, with an USB port that's becoming more and more unreliable, it doesn't get easier to get a grip on what's happening software-wise. Also, if using magnetic cables and adapters like I do (which unfortunately didn't prevent the USB port becoming unreliable, either), they introduce an another potential point of failure for the connection. In the meantime I've also found some of my several magnetic cables to have become more unreliable than others when used on the Pro 1, and the same goes for the magnetic adapters. (Same goes with conventional USB-C cables.) At this point, I've identified these two general cases which sometimes prevent charging even though the cable is connected (and charging control software like ACC is not preventing charging according to its control settings): Charging doesn't resume, the system (according to the AccA app) reports "not charging" instead of either "charging" or "discharging". The longer the uptime, the more probable this is to happen, the reason here clearly is the operating system since LineageOS 18. Rebooting helps. Charging doesn't resume, the system reports "discharging". This, for me, is mostly a bad physical connection due to the USB connector becoming becoming having become unreliable. Still, in a few cases my impression was that it *was* caused by software, as rebooting helped. 2 Quote Link to post Share on other sites
EskeRahn 5,598 Posted May 23, 2022 Share Posted May 23, 2022 10 hours ago, Rob. S. said: At this point, I've identified these two general cases which sometimes prevent charging even though the cable is connected (and charging control software like ACC is not preventing charging according to its control settings): Charging doesn't resume, the system (according to the AccA app) reports "not charging" instead of either "charging" or "discharging". The longer the uptime, the more probable this is to happen, the reason here clearly is the operating system since LineageOS 18. Rebooting helps. Charging doesn't resume, the system reports "discharging". This, for me, is mostly a bad physical connection due to the USB connector becoming becoming having become unreliable. Still, in a few cases my impression was that it *was* caused by software, as rebooting helped. Exactly. And for the first one rebooting the phone resting on the desktop, without touching the plug fixes it so it clearly is NOT related to the physical connection. It is some 'state' it enters, from which the only (known?) exit is a reboot. And we have ONLY had reports on this from those on LineageOS & AICP, not Stock Android, so almost certainly a matter of the kernels handling the hardware differently. It MIGHT be that we would see the same if Stock was offered as 11 or 12. (If i recall correctly this was NOT reported for LineageOS 16 and 17, hence Android 10 most likely OK) 2 Quote Link to post Share on other sites
VaZso 1,999 Posted May 23, 2022 Share Posted May 23, 2022 1 hour ago, EskeRahn said: And we have ONLY had reports on this from those on LineageOS & AICP, not Stock Android, so almost certainly a matter of the kernels handling the hardware differently. It MIGHT be that we would see the same if Stock was offered as 11 or 12. (If i recall correctly this was NOT reported for LineageOS 16 and 17, hence Android 10 most likely OK) Basically kernel is the same as in stock, some kernel modules may be different. So this is probably in higher level, however, I did not have to reboot phone for charging yet. Quote Link to post Share on other sites
silversolver 849 Posted May 23, 2022 Share Posted May 23, 2022 5 hours ago, EskeRahn said: Exactly. And for the first one rebooting the phone resting on the desktop, without touching the plug fixes it so it clearly is NOT related to the physical connection. It is some 'state' it enters, from which the only (known?) exit is a reboot. And we have ONLY had reports on this from those on LineageOS & AICP, not Stock Android, so almost certainly a matter of the kernels handling the hardware differently. It MIGHT be that we would see the same if Stock was offered as 11 or 12. (If i recall correctly this was NOT reported for LineageOS 16 and 17, hence Android 10 most likely OK) I'm using LOS 17.1 now, and used LOS 16 before, never used stock on this device (saw the Scroogle stuff and noped right into LOS flash before even completing the setup wizard lol) and I have never had this problem. My USB port is healthy, and I'm careful to keep it that way. It helps that the battery life is good enough that I never have to charge it anywhere other than on my desk. Quote Link to post Share on other sites
VaZso 1,999 Posted May 23, 2022 Share Posted May 23, 2022 3 hours ago, silversolver said: My USB port is healthy, and I'm careful to keep it that way. I have also tried to keep it that way but it became worn... and not the soldering was the problem but inside the connector itself although I have only charged it once a day. 😞 1 Quote Link to post Share on other sites
EskeRahn 5,598 Posted May 23, 2022 Share Posted May 23, 2022 (lineage-19.1-20220523-nightly-pro1-signed.zip on May 5 security patch installed smoothly using adb sideload and MindTheGapps-12.1.0-arm64-20220416_174313) Quote Link to post Share on other sites
CornholioGSM 370 Posted May 23, 2022 Share Posted May 23, 2022 Updated too...it takes long time...play store still, magisk too...all works 🙂 2 Quote Link to post Share on other sites
agent008 248 Posted May 24, 2022 Share Posted May 24, 2022 On 5/21/2022 at 2:55 AM, Kaali said: There is an APK to flash the screen firmware but it only works on Android 10 or lower (basically stock or LoS16 or 17) Hi! At this point I would be willing to try this. Since not even my old screen (glass broken, touch perfect) worked with touch anymore, I'm not very hopeful it might fix but, why not try? I would flash an older LineageOS and try to run this APK. At the moment the only way I can interact with my Pro1 is by connecting a USB-C hub to it with a mouse and keyboard plugged in. Or with a bluetooth keyboard but in order to pair the phone and the keyboard I still had to plug a mouse into the phone. No phone keyboard and no touchscreen for me. Pretty bummed and had to resort back to a Moto Z2 Play I had in storage. Which had its screen die yesterday.... Quote Link to post Share on other sites
agent008 248 Posted May 24, 2022 Share Posted May 24, 2022 So where can I find the screen fix APK? Thanks Quote Link to post Share on other sites
Hook 3,315 Posted May 24, 2022 Share Posted May 24, 2022 32 minutes ago, agent008 said: So where can I find the screen fix APK? Thanks 1 Quote Link to post Share on other sites
agent008 248 Posted May 24, 2022 Share Posted May 24, 2022 2 minutes ago, Hook said: Thanks! I had just found this very same post. Quote Link to post Share on other sites
marmistrz 93 Posted May 26, 2022 Share Posted May 26, 2022 (edited) Sorry for the rant. Oh my goodness, LineageOS 19.1 is such a downgrade compared to 18.1. The whole UI is so gaudy: the icons, the animations. The large UI widgets that are everywhere resemble a UI I'd build (with all due to respect) for an elderly person with a hindered eyesight. This reminds my why I hate Android. On a proper Linux distro, I'd just install a different DE of my choice. Edited May 26, 2022 by marmistrz Quote Link to post Share on other sites
