OliverTypes 152 Posted January 31, 2020 Share Posted January 31, 2020 13 hours ago, sequestris said: I would answer that if I knew what you meant 😄 Oh my… 😳 HEAT, of course, heat accumulation. Could it be an issue for the display? 1 Quote Link to post Share on other sites
peter.s.fidelman 54 Posted January 31, 2020 Share Posted January 31, 2020 On 1/24/2020 at 3:01 PM, Slion said: I'm gonna try my luck with this one:https://www.amazon.de/dp/B07DFNXFGV Thanks for the suggestion Slion. I bought the same one. Here is the Amazon U.S.A. listing that I used. https://www.amazon.com/gp/product/B07DFP6P35 I used an Exacto knife to trim away the plastic rim that holds the phone. Very easy and now I have access to the ports. I have been using this case for a couple of days and I am very satisfied. 4 Quote Link to post Share on other sites
sequestris 710 Posted January 31, 2020 Share Posted January 31, 2020 2 hours ago, OliverTypes said: Oh my… 😳 HEAT, of course, heat accumulation. Could it be an issue for the display? I haven't found any problems yet. Quote Link to post Share on other sites
sequestris 710 Posted January 31, 2020 Share Posted January 31, 2020 (edited) I don't know if anyone posted this:https://www.amazon.com/kwmobile-Case-Compatible-Huawei-P20/dp/B07JN6SMMX/ref=sr_1_8?keywords=two+piece+p20+phone+case&qid=1580488803&sr=8-8 Just ordered it. We will see... Edited January 31, 2020 by sequestris 1 Quote Link to post Share on other sites
EskeRahn 5,596 Posted January 31, 2020 Share Posted January 31, 2020 27 minutes ago, sequestris said: I don't know if anyone posted this:https://www.amazon.com/kwmobile-Case-Compatible-Huawei-P20/dp/B07JN6SMMX/ref=sr_1_8?keywords=two+piece+p20+phone+case&qid=1580488803&sr=8-8 Just ordered it. We will see... Well I expect one part to fit, and one to be way to big. BUT we might find this type for a SMALLER phone also, and use the bottom part for the P20 Pro and the top part from the smaller phone. e.g the top from a Samsung Note 10, that is 151x71.8mm so I would expect the top part to add 1mm on all sides and thus 153x73.8... 1 Quote Link to post Share on other sites
EskeRahn 5,596 Posted January 31, 2020 Share Posted January 31, 2020 17 minutes ago, EskeRahn said: Well I expect one part to fit, and one to be way to big. BUT we might find this type for a SMALLER phone also, and use the bottom part for the P20 Pro and the top part from the smaller phone. e.g the top from a Samsung Note 10, that is 151x71.8mm so I would expect the top part to add 1mm on all sides and thus 153x73.8... ....Ordered a few different ones and hope the tops parts fits the display... 1 1 Quote Link to post Share on other sites
sequestris 710 Posted January 31, 2020 Share Posted January 31, 2020 48 minutes ago, EskeRahn said: ....Ordered a few different ones and hope the tops parts fits the display... I'm just playing Goldilocks to see what has the least holes and the best fit/touch capacity. 2 Quote Link to post Share on other sites
david 929 Posted January 31, 2020 Share Posted January 31, 2020 Personally, I don't want a clear case covering the screen. However, I could see using a clear case as a basis for a bumper setup, where you cut out the case part that is over the display parts of the screen and leave the parts that hug the edges. At least until a proper 3D printed one becomes available. Quote Link to post Share on other sites
sequestris 710 Posted January 31, 2020 Share Posted January 31, 2020 As I said, I'm just playing Goldilocks. 2 hours ago, sequestris said: I'm just playing Goldilocks to see what has the least holes and the best fit/touch capacity. Quote Link to post Share on other sites
everlast4308 30 Posted January 31, 2020 Share Posted January 31, 2020 1 hour ago, david said: Personally, I don't want a clear case covering the screen. However, I could see using a clear case as a basis for a bumper setup, where you cut out the case part that is over the display parts of the screen and leave the parts that hug the edges. At least until a proper 3D printed one becomes available. Yes, this is what I'm most excited about. Being able to bore out the main swiss-cheese "lens" portion, to be left with only a "surround" of rubbery protection, helps open the device and reduces edge-of-touchscreen accidentals. In theory, anyway. It's lucky that the vol / pwr / etc. buttons are NOT on the top brick (screen), because cutting out the entire screen portion AND extra button holes might make it too weak to rely on. Top-brick: Cut main face, leave sides intact. Bottom-brick: Cut sides for ports, leave main face intact (or small adjustment for camera). Seems legit! I don't mean to harp on but THANK YOU SO MUCH @EskeRahn & @sequestris for buying zillions of extra test cases so the rest of us don't have to. Those cheap cases can add up to a pretty hefty price over time... you guys are so awesome 🙂 3 1 1 Quote Link to post Share on other sites
galaxy 22 Posted February 1, 2020 Share Posted February 1, 2020 I am thinking of trying something like the following: to create the holder for the phone. Then I will use one of the real leather flip cases and glue the holder to it. :) 5 Quote Link to post Share on other sites
silversolver 849 Posted February 1, 2020 Share Posted February 1, 2020 @sequestris I want your cat. :P I have two black cats already, and my orange one looks out of place. Trade? HAHA Quote Link to post Share on other sites
sequestris 710 Posted February 1, 2020 Share Posted February 1, 2020 4 hours ago, everlast4308 said: I don't mean to harp on but THANK YOU SO MUCH @EskeRahn & @sequestris for buying zillions of extra test cases so the rest of us don't have to. Those cheap cases can add up to a pretty hefty price over time... you guys are so awesome 🙂 They don't add up to squat with free Amazon returns! 2 Quote Link to post Share on other sites
sequestris 710 Posted February 1, 2020 Share Posted February 1, 2020 3 minutes ago, silversolver said: @sequestris I want your cat. :P I have two black cats already, and my orange one looks out of place. Trade? HAHA No. She's mine. I wear a lot of black clothes so the hair doesn't show up as much. An orange cat just won't do. 1 2 Quote Link to post Share on other sites
silversolver 849 Posted February 1, 2020 Share Posted February 1, 2020 1 minute ago, sequestris said: No. She's mine. I wear a lot of black clothes so the hair doesn't show up as much. An orange cat just won't do. AWWWWW. The look of loave. She loaves you very much. What a sweetheart. I'm glad you have her. She is glad you have her. :) Quote Link to post Share on other sites
sequestris 710 Posted February 1, 2020 Share Posted February 1, 2020 1 minute ago, silversolver said: AWWWWW. The look of loave. She loaves you very much. What a sweetheart. I'm glad you have her. She is glad you have her. :) Thanks. She is my dolly love <3 My life would be incomplete without her. I'm sure you understand, although why you would get a mismatchy cat I don't know. Surely you remembered the other 2 were black. 1 Quote Link to post Share on other sites
silversolver 849 Posted February 1, 2020 Share Posted February 1, 2020 1 minute ago, sequestris said: Thanks. She is my dolly love <3 My life would be incomplete without her. I'm sure you understand, although why you would get a mismatchy cat I don't know. Surely you remembered the other 2 were black. Because he loaved me. I couldn't just leave such sweet loave just because he didn't match the others in the set. He's a gentleman and a sweetheart. :) Quote Link to post Share on other sites
sequestris 710 Posted February 1, 2020 Share Posted February 1, 2020 1 minute ago, silversolver said: Because he loaved me. I couldn't just leave such sweet loave just because he didn't match the others in the set. He's a gentleman and a sweetheart. 🙂 Damn their sweet, loaving, hides. What are you gonna do? Wait... there's one thing... 2 Quote Link to post Share on other sites
EskeRahn 5,596 Posted February 1, 2020 Share Posted February 1, 2020 3 minutes ago, sequestris said: Damn their sweet, loaving, hides. What are you gonna do? Wait... there's one thing... or.... 5 Quote Link to post Share on other sites
sequestris 710 Posted February 1, 2020 Share Posted February 1, 2020 1 minute ago, EskeRahn said: or.... You could at least recommend a semi-gloss. How rude. Who wants a matte catte? 1 Quote Link to post Share on other sites
EskeRahn 5,596 Posted February 1, 2020 Share Posted February 1, 2020 1 minute ago, sequestris said: You could at least recommend a semi-gloss. How rude. Who wants a matte catte? It will be much better at hunting during night if matte...😇 1 Quote Link to post Share on other sites
sequestris 710 Posted February 1, 2020 Share Posted February 1, 2020 1 minute ago, EskeRahn said: It will be much better at hunting during night if matte...😇 But we want it to match the others or else what's the point of it all? He may as well just stay orange! Quote Link to post Share on other sites
EskeRahn 5,596 Posted February 1, 2020 Share Posted February 1, 2020 Just now, sequestris said: But we want it to match the others or else what's the point of it all? He may as well just stay orange! Easy... more paint... 😇 1 Quote Link to post Share on other sites
sequestris 710 Posted February 1, 2020 Share Posted February 1, 2020 1 Quote Link to post Share on other sites
sequestris 710 Posted February 1, 2020 Share Posted February 1, 2020 8 hours ago, EskeRahn said: ....Ordered a few different ones and hope the tops parts fits the display... Please let us know your findings. I'll have the one from Amazon tomorrow and will report back. Quote Link to post Share on other sites
