Craig 1,435 Posted June 28, 2020 Share Posted June 28, 2020 (edited) 1 hour ago, ToniCipriani said: http://www.idealte.com/product/detail/98.html I guess they are still trying to recover from this mess. Sailfish 2.0? or the liquidmorphium? Edited June 28, 2020 by Craig 1 Quote Link to post Share on other sites
D1ggs 141 Posted June 29, 2020 Share Posted June 29, 2020 (edited) Bumping this thread, is anyone having issues getting phone calls to work? When someone dials me, I hear the dialer but i'm not able to pick up anything. If I press the power button, the ringing stops but I am not given any opportunity to pick up the phone. Edit: disregard, I somehow got the notifications muted. Edited June 29, 2020 by D1ggs 1 Quote Link to post Share on other sites
dt.white 62 Posted July 1, 2020 Share Posted July 1, 2020 On 6/23/2020 at 4:41 PM, EskeRahn said: Just checked it passes SafetyNet check now. 🙂 I've had to reinstall the version that Chen posted as part of the flashing back to stock after trying out Ubuntu Touch for a day (it looks promising, but still needs to mature somewhat). Unfortunately now when I check for updates it states that there are no updates available beyond the September 2019 security update, current version: QX1000_EEA_05500.19Q401_20191111-1505 Anybody with any ideas on how to update to the latest version? 1 Quote Link to post Share on other sites
EskeRahn 5,598 Posted July 1, 2020 Share Posted July 1, 2020 14 minutes ago, dt.white said: Unfortunately now when I check for updates it states that there are no updates available beyond the September 2019 security update, current version: QX1000_EEA_05500.19Q401_20191111-1505 Anybody with any ideas on how to update to the latest version? Hmm that is odd. I would suggest to try a restart first. It OUGHT to be able to update. Note though that I have experienced when the app can not see the net, that it sometimes just says that there are no new updates, when there actually is. 2 Quote Link to post Share on other sites
dt.white 62 Posted July 1, 2020 Share Posted July 1, 2020 2 hours ago, EskeRahn said: Hmm that is odd. I would suggest to try a restart first. It OUGHT to be able to update. Note though that I have experienced when the app can not see the net, that it sometimes just says that there are no new updates, when there actually is. Have tried a restart and also done a factory reset as well (so for now I've installed only the essential apps!) and no luck. Attempted to connect over WiFi and Mobile but to no avail. I've also force stopped the Wireless Update apps to try and get it to start over, no bueno. Is there a way to flash the latest version manually? I could try flashing the original again, not sure if it'd work.. 1 Quote Link to post Share on other sites
EskeRahn 5,598 Posted July 1, 2020 Share Posted July 1, 2020 4 hours ago, dt.white said: ...and no luck..... You have tried what I would. So this is a matter for support. I Added @Erik Quote Link to post Share on other sites
dt.white 62 Posted July 6, 2020 Share Posted July 6, 2020 On 7/1/2020 at 9:16 PM, EskeRahn said: You have tried what I would. So this is a matter for support. I Added @Erik Well out of the blue today all of the updates started coming through and I'm now on the latest. So if anybody else runs into this issue it ended up taking five days to resolve by itself and a little patience! 1 2 Quote Link to post Share on other sites
FlyingAntero 871 Posted July 7, 2020 Share Posted July 7, 2020 Great thing about stock Android is that system does not kill background apps. I just ran "Don'tKillMyApp" benchmark for 4 hours and got 100% score. DontKillMyApp is a benchmark to test how badly your phone handles background apps More informaation: https://dontkillmyapp.com/ Quote Link to post Share on other sites
EskeRahn 5,598 Posted July 7, 2020 Share Posted July 7, 2020 4 hours ago, FlyingAntero said: Great thing about stock Android is that system does not kill background apps. I just ran "Don'tKillMyApp" benchmark for 4 hours and got 100% score. DontKillMyApp is a benchmark to test how badly your phone handles background apps More informaation: https://dontkillmyapp.com/ And the great thing about Greenify, is that it helps keep the stuff down that tries to but really shouldn't run in the background. Sure well written apps could stay in the background, doing nothing. But a myriad of bad apps can not stay inactive, and waste your battery with zero benefit for the user. It could either be bad code, or actively stealing your activities/data. Quote Link to post Share on other sites
FlyingAntero 871 Posted July 7, 2020 Share Posted July 7, 2020 15 minutes ago, EskeRahn said: And the great thing about Greenify, is that it helps keep the stuff down that tries to but really shouldn't run in the background. Sure well written apps could stay in the background, doing nothing. But a myriad of bad apps can not stay inactive, and waste your battery with zero benefit for the user. It could either be bad code, or actively stealing your activities/data. Yes, Greenify is an excellent app but there are dozens of "Task Killers" and "RAM Boosters" that users should not install. Closing Apps to Save Your Battery Only Makes Things WorseWorse Why RAM Boosters and Task Killers Are Bad for Your Android 1 Quote Link to post Share on other sites
Craig 1,435 Posted July 8, 2020 Share Posted July 8, 2020 (edited) Hey, some very good news on twitter, finally looks like some software fixes coming: https://twitter.com/chenliangchen/status/1280900929273958402 I'm hoping that whatsapp thing means the audio-crackle, which is one of the major issues (and a 1 line code fix) that has been plaguing everyone still on stock OS. And glad they fixed Esc key. Hopefully they also enabled wake-on-keypresss (for every key) and keyboard backlight on keypress too while messing with Esc. Hopefully they made SYM key right-alt. Hopefully set keyboard to alpha. Etc. Hopefully this also means someone is finally working on stock firmware and we'll start to see other issues getting fixed soon too... Edited July 8, 2020 by Craig 3 9 Quote Link to post Share on other sites
Rob. S. 1,667 Posted July 8, 2020 Share Posted July 8, 2020 @Craig Excellent! Thanks for the notice. I was already fearing that I might get my device too soon 😉 2 1 Quote Link to post Share on other sites
jjarmasz 81 Posted July 9, 2020 Share Posted July 9, 2020 Yup, looks like it just dropped! 2 4 Quote Link to post Share on other sites
Tsunero 215 Posted July 9, 2020 Share Posted July 9, 2020 Woooo, AMAZING update. Finally that very nasty sound crackling is gone, just tested it in several different games (including dosbox) and they all sound very nice now. Keep dem fixes coming! 1 6 Quote Link to post Share on other sites
jjarmasz 81 Posted July 9, 2020 Share Posted July 9, 2020 9 hours ago, Craig said: Hey, some very good news on twitter, finally looks like some software fixes coming: https://twitter.com/chenliangchen/status/1280900929273958402 I'm hoping that whatsapp thing means the audio-crackle, which is one of the major issues (and a 1 line code fix) that has been plaguing everyone still on stock OS. And glad they fixed Esc key. Hopefully they also enabled wake-on-keypresss (for every key) and keyboard backlight on keypress too while messing with Esc. Hopefully they made SYM key right-alt. Hopefully set keyboard to alpha. Etc. Hopefully this also means someone is finally working on stock firmware and we'll start to see other issues getting fixed soon too... Sadly I can confirm that wake- and backlight-on-keypress are not enabled with this update 😞 And Sym key seems to do nothing still... 1 2 Quote Link to post Share on other sites
ToniCipriani 194 Posted July 9, 2020 Share Posted July 9, 2020 Tested ESC key and no more crackling sounds in Mario Kart. 2 Quote Link to post Share on other sites
Slion 1,201 Posted July 9, 2020 Author Share Posted July 9, 2020 2 hours ago, jjarmasz said: Sadly I can confirm that wake- and backlight-on-keypress are not enabled with this update 😞 And Sym key seems to do nothing still... Ever tried alternative layouts like FX Qwerty? Quote Link to post Share on other sites
Slion 1,201 Posted July 9, 2020 Author Share Posted July 9, 2020 (edited) 3 hours ago, Tsunero said: Finally that very nasty sound crackling is gone Indeed, audio sounds much better overall. Awesome 🥳🥳🥳 Edited July 9, 2020 by Slion 2 3 Quote Link to post Share on other sites
Benni 192 Posted July 9, 2020 Share Posted July 9, 2020 (edited) I just called my mailbox and it's still pretty loud, even on the lowest call volume setting. mailbox = German for voicemail-thingy Edited July 9, 2020 by Benni 1 1 Quote Link to post Share on other sites
Craig 1,435 Posted July 9, 2020 Share Posted July 9, 2020 (edited) 10 minutes ago, Benni said: I just called my mailbox Edited July 9, 2020 by Craig 1 6 Quote Link to post Share on other sites
jjarmasz 81 Posted July 9, 2020 Share Posted July 9, 2020 14 hours ago, Slion said: Ever tried alternative layouts like FX Qwerty? No I haven't - I'll take a look. But I just wanted to report back on whether any of these issues had been addressed in the ROM, since people were wondering. 1 Quote Link to post Share on other sites
VaZso 1,999 Posted July 9, 2020 Share Posted July 9, 2020 5 hours ago, Benni said: I just called my mailbox and it's still pretty loud, even on the lowest call volume setting. I have also called service provider's IVR system and I haven't noticed call is quieter than before... or at least it is still too loud. 2 Quote Link to post Share on other sites
VaZso 1,999 Posted July 10, 2020 Share Posted July 10, 2020 Anyway, I am unsure, but may the low brightness colour issue improved? Maybe I was not looking at appropriate photo, but I have a feeling it may be better now. Also, I am not at home (so it is not latest firmware-related), but at this place, I have "4G+" sign in status row. Quote Link to post Share on other sites
FlyingAntero 871 Posted July 10, 2020 Share Posted July 10, 2020 (edited) 1 hour ago, VaZso said: Anyway, I am unsure, but may the low brightness colour issue improved? Maybe I was not looking at appropriate photo, but I have a feeling it may be better now. I don't see any improvements on my unit. Here is The Dragon picture to check. https://www.deviantart.com/fellfallow/art/CLOSED-Inky-Beast-731904319 Edited July 10, 2020 by FlyingAntero Quote Link to post Share on other sites
Benni 192 Posted July 10, 2020 Share Posted July 10, 2020 3 hours ago, VaZso said: Anyway, I am unsure, but may the low brightness colour issue improved? Color now looks fine for me. Quote Link to post Share on other sites
