Slion 1,201 Posted February 22, 2020 Share Posted February 22, 2020 (edited) 4 hours ago, FlyingAntero said: Also, you can't just select Screen Off - Unlock with fingerprint from Keyboard/Button Mapper. You need to install Nova Launcher and use Nova actions as an activity. I didn't need to do that. Works just fine without Nova it seems. Thanks to you @FlyingAntero I have a functional smart case for my Pro1 🙂 Now I just need to sort out the wake up part. Edited February 22, 2020 by Slion 1 Quote Link to post Share on other sites
DieBruine 397 Posted February 23, 2020 Share Posted February 23, 2020 (edited) ivoler Hülle Case Kompatibel für Huawei P20 Pro, Premium Transparent Klare Tasche Schutzhülle Weiche TPU Silikon Gel Handyhülle Schmaler Cover https://www.amazon.de/dp/B07BVRH8G2/ref=cm_sw_r_cp_apa_i_0sTuEb1173YSK That's the one I bought. I used a hole puncher or whatever its called (additional holes in belts). It looks like a hack job, but I am very satisfied with this bumper. I shaved off volume up. Fingerprint reader took some butchering. But overall very happy. Tomorrow I will cut a better screen protector from vinyl (bestskinever). Edited February 24, 2020 by DieBruine Pictures wouldn't show 1 Quote Link to post Share on other sites
D1ggs 141 Posted February 23, 2020 Share Posted February 23, 2020 Honestly, i'm tempted to give my device off to some engineer to design a case in CAD which can then be 3D printed at will using a nice rubbery material. A proper fitting case is a custom made solution. 4 Quote Link to post Share on other sites
PC_ 61 Posted February 24, 2020 Share Posted February 24, 2020 (edited) On 2/17/2020 at 4:29 PM, PC_ said: If anyone is interested in a well made leather pouch with a pull tab, I recently bought this one from MediaDevil in the UK. I tried a couple of different sizes. It's not perfect as the phone does protrude from the top a bit and it could do with being slightly narrower but until someone produces a custom fitted case for the Pro1 it's a bit more robust than the fabric sleave suplied by F(x)Tec. (It does have a couple of small holes at the back for what I assume is for a speaker on the back of the note 4). https://mediadevil.com/collections/all/products/artisanpouch-leather-pouch-case-samsung-galaxy-note-4?variant=38830827729 Thanks to the guys at MediaDevil, after a couple more attempts we found that their iPhone 6/7/8 Plus leather pulltab case is a far better fit for the Pro1. They ship internationally and I could not recommend their customer service enough. Also the quality and workmanship of the case is excellent. https://mediadevil.com/collections/apple-iphone-8-plus-accessories/products/artisanpouch-leather-pouch-case-apple-iphone-6-plus Edited February 24, 2020 by PC_ 6 1 Quote Link to post Share on other sites
EskeRahn 5,598 Posted February 24, 2020 Share Posted February 24, 2020 On 2/19/2020 at 1:47 PM, EskeRahn said: . Another option is to add some of the adhesive anti-slip tape intended for stairs (black or transparent) e.g. this . This will give you a VERY easy lift.. I made the above halfway as a joke at getting more grip, but it really has grown on me, and a shorter piece is all it need to do the trick. It is especially useful with a flip-case, as it would be a nuisance in&out of a sleeve or pocket if exposed. If you place a piece of just say 2-3 x 15-20 mm above the fingerprint reader, you will be able to unlock an lift in one movement. Touch, await the haptic feedback, and lift. (The red lines are reflections from my red table used as standard background) 2 Quote Link to post Share on other sites
EskeRahn 5,598 Posted February 24, 2020 Share Posted February 24, 2020 On 2/7/2020 at 9:34 AM, _DW_ said: Spotted this today https://www.amazon.co.uk/UMIDIGI-UNIVERSAL-Synthetic-Adjustable-i-Tronixs-Black/dp/B074MBTX5D?ref_=ast_bbp_dp I bought this in a couple of variants, And well that was a waste of money IMHO... 1) The case-sliding is not enough to get in when down, and to expose the flash/torch when up. It moves 30mm (would have needed 40mm) 2) The case is BIG! Mounted 90x165x30 versus the 82xx157x23 of the simple flip cases 3) The hard plastic 'claw' gripping the phone, will require modifications to not grip the power button partly, and to allow access to the fingerprint scanner, 4) No side and end protection, except the parts covered by the claw On the plus side, it is symmetric , so it can be mounted opening either under the display or flapping in front of the keyboard. Note on the last image how both the phone is quite a bit over the case, and also the claws gripping so the phone does not close completely. From two different seller a total of six(!) of these cases arrived today - two of the carbon's should have been different variants, so not quite sure what went wrong BUT I'm not going to use any of them so: If anyone are interested despite the above, they could just PM me and fetch one or all, or I can send at shipping cost. The official value is about £6 each, so if outside EU/EFTA be aware that custom might be added, if above some trifles limit, and no I'm not going to fill out any papers, just sending it as a gift, so any custom issues will be your problem. 1 Quote Link to post Share on other sites
_DW_ 628 Posted February 26, 2020 Share Posted February 26, 2020 @EskeRahn oh well it did look promising 😞 Quote Link to post Share on other sites
EskeRahn 5,598 Posted February 26, 2020 Share Posted February 26, 2020 2 hours ago, _DW_ said: @EskeRahn oh well it did look promising 😞 Indeed it did, but at the least we now know that this is not an optimal solution.... No surprise that no one have asked me to send one.... 🤪 1 Quote Link to post Share on other sites
Bloodhoundje 78 Posted February 28, 2020 Share Posted February 28, 2020 On 2/14/2020 at 4:32 PM, david said: @Keyahnig @Bloodhoundje Any updates on 3D printed/molded cases? Sorry, had some personal issues going on that drained alot of my time. Likely have time to work on the case next week again! 🙂 1 Quote Link to post Share on other sites
david 929 Posted February 29, 2020 Share Posted February 29, 2020 3 hours ago, Bloodhoundje said: Sorry, had some personal issues going on that drained alot of my time. Likely have time to work on the case next week again! 🙂 No rush. Just thought I'd ask, in case (no pun intended) I missed any info. :-) 1 Quote Link to post Share on other sites
wave-rider 9 Posted February 29, 2020 Share Posted February 29, 2020 (edited) On 1/20/2020 at 1:54 PM, EskeRahn said: I would not be at all surprised if quite many of us would be interested in one (or more) of those. What happened to the idea of printing a 2 pieces case with a 3d printer? Seemed to be the best idea for a case? 2 times the same Idea, sorry didn't See this Post before Edited February 29, 2020 by wave-rider 1 Quote Link to post Share on other sites
_DW_ 628 Posted February 29, 2020 Share Posted February 29, 2020 13 hours ago, Bloodhoundje said: Sorry, had some personal issues going on that drained alot of my time. Likely have time to work on the case next week again! 🙂 If your continuing this might be nice to have a 3D printed case thread so people can find/share info on doing this. 2 Quote Link to post Share on other sites
Slion 1,201 Posted March 2, 2020 Share Posted March 2, 2020 (edited) For those of you with custom smart case I started working on a dedicated Accessibility Service to make it work better. I have not published an APK yet but it should compile and the advertised functionalities should be working already. For now the main advantage over a generic solution using Key Mapper and a screen locker app are: Filtering of keys causing page reload and search overlay in Chrome when closing keyboard and case. Built-in lock delay set to three seconds. Screen lock is cancelled if you open your case less than three seconds after you closed it. Sadly I have not find a solution to wake up the screen when opening the case. Edited March 2, 2020 by Slion 1 Quote Link to post Share on other sites
SaiKo 14 Posted March 2, 2020 Share Posted March 2, 2020 48 minutes ago, Slion said: Sadly I have not find a solution to wake up the screen when opening the case. take a look at WaveUp, its on f-droid and source code is here: https://gitlab.com/juanitobananas/wave-up i've been using this on the pro1 and it doesn't have the battery drain issue 1 Quote Link to post Share on other sites
Slion 1,201 Posted March 2, 2020 Share Posted March 2, 2020 41 minutes ago, SaiKo said: take a look at WaveUp, its on f-droid and source code is here: https://gitlab.com/juanitobananas/wave-up Most interesting, I will need to take a closer look at that. Though my main issue is to find a way to get notified when the case is opened and the screen is already lock. Quote Link to post Share on other sites
FlyingAntero 871 Posted March 2, 2020 Share Posted March 2, 2020 2 hours ago, Slion said: Most interesting, I will need to take a closer look at that. Though my main issue is to find a way to get notified when the case is opened and the screen is already lock. Can you the trigger from the sensor when The case is opened? Or isn't it working when screen is off? 1 Quote Link to post Share on other sites
Slion 1,201 Posted March 2, 2020 Share Posted March 2, 2020 1 hour ago, FlyingAntero said: Can you the trigger from the sensor when The case is opened? Or isn't it working when screen is off? Once the screen is locked I can't get the notification that the case is opening anymore. 1 Quote Link to post Share on other sites
SaiKo 14 Posted March 2, 2020 Share Posted March 2, 2020 (edited) 39 minutes ago, Slion said: Once the screen is locked I can't get the notification that the case is opening anymore. like i said, check WaveUp's source code, while its primary function is to wake the phone by waving over the sensor it also has 'pocket mode' which turns on the screen when taking the phone out of a pocket (or opening a case)... which works when the screen is off and locked. it also has the function to lock the screen when the sensor is covered, but that requires special permissions. your app does this too, what permissions does that require? Edited March 2, 2020 by SaiKo 1 Quote Link to post Share on other sites
Slion 1,201 Posted March 2, 2020 Share Posted March 2, 2020 16 minutes ago, SaiKo said: your app does this too, what permissions does that require? To lock the screen properly an app needs to implement Accessibility Service and the user needs to turn it on. The function is called performGlobalAction I believe. See my code or one of my earlier post on that thread. Quote Link to post Share on other sites
Slion 1,201 Posted March 2, 2020 Share Posted March 2, 2020 Using Sensor Test I could find the hall effect sensor for the keyboard but not the one for the case. I'm guessing we will have to wait for an update on that one. In the meantime I tested WaveUp and that works really well so I'm guessing I should be able to use the proximity sensor to wake the device. @SaiKo Any noticeable impact on battery life when using WaveUp on your Pro1? Quote Link to post Share on other sites
EskeRahn 5,598 Posted March 2, 2020 Share Posted March 2, 2020 42 minutes ago, Slion said: Using Sensor Test I could find the hall effect sensor for the keyboard but not the one for the case. I'm guessing we will have to wait for an update on that one. In the meantime I tested WaveUp and that works really well so I'm guessing I should be able to use the proximity sensor to wake the device. @SaiKo Any noticeable impact on battery life when using WaveUp on your Pro1? It is easy to find, it is near the end of the volume rocker. I have posted stuff showing the whereabouts above. 1 Quote Link to post Share on other sites
Slion 1,201 Posted March 2, 2020 Share Posted March 2, 2020 (edited) 2 minutes ago, EskeRahn said: It is easy to find, it is near the end of the volume rocker. I have posted stuff showing the whereabouts. Physical I know where it is and it's working fine, we sorted that out a few days back. That was about programmatically finding it as the key handler won't work once the screen is off. Edited March 2, 2020 by Slion 1 Quote Link to post Share on other sites
EskeRahn 5,598 Posted March 2, 2020 Share Posted March 2, 2020 1 hour ago, Slion said: Physical I know where it is and it's working fine, we sorted that out a few days back. That was about programmatically finding it as the key handler won't work once the screen is off. Ah, that made more sense.... Most likely it is handled as a proximity sensor, And if we are unlucky it might not be marked for wake up. https://developer.android.com/reference/android/hardware/Sensor#TYPE_PROXIMITY https://developer.android.com/reference/android/hardware/Sensor#isWakeUpSensor() But as the other Hall sensor IS clearly able to wake up the device, it seems unlikely that they are not both. 1 Quote Link to post Share on other sites
Slion 1,201 Posted March 2, 2020 Share Posted March 2, 2020 13 minutes ago, EskeRahn said: Most likely it is handled as a proximity sensor, Nope the proximity sensor is something else, it's the guy turning off the screen when you put the phone to your ear. Thanks to @SaiKo I was able to get the wake up logic to work nicely with the proximity sensor. Still it would be nice if they made that missing Hall Effect sensor available at some point. I'll probably publish that app tomorrow. Quote Link to post Share on other sites
EskeRahn 5,598 Posted March 2, 2020 Share Posted March 2, 2020 14 minutes ago, Slion said: Nope the proximity sensor is something else, it's the guy turning off the screen when you put the phone to your ear. Thanks to @SaiKo I was able to get the wake up logic to work nicely with the proximity sensor. Still it would be nice if they made that missing Hall Effect sensor available at some point. I'll probably publish that app tomorrow. I know what the proximity sensor is ... BUT they just MIGHT be exposing these two Hall sensors as "TYPE_PROXIMITY" (Note: TYPE), The reason to believe so is the binary type output we see in the FactoryKit test-program. And if you are looking for it as a TYPE_MAGNETIC_FIELD sensor, no wonder you can not find it. 1 Quote Link to post Share on other sites
