ToniCipriani 194 Posted June 10, 2020 Share Posted June 10, 2020 So regarding the known bug where audio playback is crackling, should I actually report this to the app developer (in this case Nintendo)? So far this seems to be the only app that I have the issue with. Or this is still on FXtec to fix? Quote Link to post Share on other sites
VaZso 1,999 Posted June 11, 2020 Share Posted June 11, 2020 20 minutes ago, ToniCipriani said: Or this is still on FXtec to fix? As far as I know, it has been already resolved in LineageOS and maybe the actual (unreleased) version of stock firmware has related bugfix. So yes, it is up to F(x)tec (their partner) but they will definitively solve it sooner or later as the cause should has been already known. 1 Quote Link to post Share on other sites
DieBruine 397 Posted June 12, 2020 Share Posted June 12, 2020 I forgot to mention that after my reset a couple of months back, my fingerprints are gone after a reboot. After every reboot I have to re-register my fingerprints. Anyone any ideas how to resolve this without another hard-reset? Quote Link to post Share on other sites
Jordi 72 Posted June 12, 2020 Share Posted June 12, 2020 3 hours ago, DieBruine said: I forgot to mention that after my reset a couple of months back, my fingerprints are gone after a reboot. After every reboot I have to re-register my fingerprints. Anyone any ideas how to resolve this without another hard-reset? tdm has the answer: On 3/5/2020 at 6:06 AM, tdm said: You most likely have a full fingerprint set in /persist. Delete everything under /persist/data/fingerprint and reboot. That should fix it. I had this once and that did the trick. 1 Quote Link to post Share on other sites
VaZso 1,999 Posted June 12, 2020 Share Posted June 12, 2020 4 hours ago, DieBruine said: I forgot to mention that after my reset a couple of months back, my fingerprints are gone after a reboot. After every reboot I have to re-register my fingerprints. Anyone any ideas how to resolve this without another hard-reset? I have the same problem with my Pro1. Usually my fingerprints are lost during reboot - but sometimes it survives reboot... 44 minutes ago, Jordi said: I had this once and that did the trick. Unfortunately, I don't have permission to reach this directory without root. (That is one reason I hate Android and its scheme of you device is not yours. I HATE IT!) 1 Quote Link to post Share on other sites
ToniCipriani 194 Posted June 14, 2020 Share Posted June 14, 2020 Want to add on about the "launching camera with camera button" bug, not only the Snapdragon Camera doesn't show the preview, it just flat out doesn't work. If you tap any of the menus (e.g. 3 dot for selecting camera mode), it just quits to the home screen. Quote Link to post Share on other sites
Hook 3,315 Posted June 14, 2020 Share Posted June 14, 2020 36 minutes ago, ToniCipriani said: Want to add on about the "launching camera with camera button" bug, not only the Snapdragon Camera doesn't show the preview, it just flat out doesn't work. If you tap any of the menus (e.g. 3 dot for selecting camera mode), it just quits to the home screen. The snapdragon camera does show thumbnails, but only if you have logged in, not if invoked when the phone is locked. With the phone locked, all you can do is shoot a pic. I suspect they did it as a security measure and, yes, it is annoying, but that is how it's supposed to work. 1 Quote Link to post Share on other sites
ToniCipriani 194 Posted June 14, 2020 Share Posted June 14, 2020 (edited) 1 hour ago, Hook said: The snapdragon camera does show thumbnails, but only if you have logged in, not if invoked when the phone is locked. With the phone locked, all you can do is shoot a pic. I suspect they did it as a security measure and, yes, it is annoying, but that is how it's supposed to work. It doesn't if you open it using the camera button, locked or unlocked. Clearly stated on the spreadsheet the only workaround is to open it from the launcher. Edited June 14, 2020 by ToniCipriani 2 Quote Link to post Share on other sites
Adrienspawn 126 Posted June 28, 2020 Share Posted June 28, 2020 There's still a wifi issue that causes rebooting and it has happened while I sleep. Less these days because I set it to only use the 5ghz band. But if you alternate with 2.4 try using only 5? 1 Quote Link to post Share on other sites
Slion 1,201 Posted October 8, 2020 Share Posted October 8, 2020 @Waxberry @Erik I eventually managed to find time to report firmware issues I'm having as a user and a developer. Hopefully you guys at FxTec can find the resources to tackle some of them. 2 1 Quote Link to post Share on other sites
DynaSmart 0 Posted October 10, 2021 Share Posted October 10, 2021 After replacing the cracked screen, the displa's touch function is not working at all (even after repeated re-booting). Is there a solution to this bug? 2 Quote Link to post Share on other sites
Rob. S. 1,667 Posted October 10, 2021 Share Posted October 10, 2021 42 minutes ago, DynaSmart said: After replacing the cracked screen, the displa's touch function is not working at all (even after repeated re-booting). Is there a solution to this bug? Did you or Fxtec do the repair? If you did the repair, was it Fxtec's replacement kit or the naked display from another, probably Chinese source? Anyway, I fear that sounds like either the replacement screen is somehow defective, or maybe something went wrong during the replacement, like a connector not properly connected or maybe even a wire damaged... 2 Quote Link to post Share on other sites
claude0001 1,424 Posted October 11, 2021 Share Posted October 11, 2021 8 hours ago, DynaSmart said: After replacing the cracked screen, the displa's touch function is not working at all (even after repeated re-booting). Is there a solution to this bug? In case you replaced yourself: most spare parts now seem to require a firmware update for the touch function to work correctly. See this thread and the possible solutions discussed therein. 1 Quote Link to post Share on other sites
EskeRahn 5,598 Posted October 11, 2021 Share Posted October 11, 2021 12 hours ago, claude0001 said: In case you replaced yourself: most spare parts now seem to require a firmware update for the touch function to work correctly. See this thread and the possible solutions discussed therein. If I don not remember wrong, the issue there is the margins, not that it does not react at all. So I think @Rob. S. is on the right track with something not connected, either the connector or a cable issue, Quote Link to post Share on other sites
claude0001 1,424 Posted October 12, 2021 Share Posted October 12, 2021 (edited) 12 hours ago, EskeRahn said: If I don not remember wrong, the issue there is the margins, not that it does not react at all You are right. But @Dyna Smart do not provide much details in their report: Replaced themselves or by FxTec? Source of the replacement screen? Installed OS? My experience is that, in lack of more information, you never know what people understand by "not working at all", especially when they are at a certain level of frustration. Hell: I myself have sometimes said my Pro1's camera was "not f**ing working at all!", although this is objectively far from true ... 😉 Edited October 12, 2021 by claude0001 2 Quote Link to post Share on other sites
spam71 55 Posted July 14, 2022 Share Posted July 14, 2022 Hello. It's like threads gravedigging, but just a week ago I finally brought my pro1 to life by replacing a broken display with Ulephone U one bought on ali (and it didn't require any "firmware update for the touch function to work correctly"). But the point is that just a few moments ago I think I managed to solve problems with too loud handset sound volume and distortion. I replaced "/system/vendor/etc/mixer_paths_tavil.xml" with a file from latest Google Pixel 2 LineageOS (it shares the same MSM8998 CPU). I didn't have much time to test it thoroughly, but sound seems to be much better. If someone's interested, I attach a Magisk module with this tweak. fxtec_pro1_sound_volume (pixel 2).zip 2 3 Quote Link to post Share on other sites
PokeParadox 62 Posted July 29, 2022 Share Posted July 29, 2022 Which version of Lineage are you running, I don't appear to have that file? There's one similarly named (IIRC "/system/vendor/etc/mixer_paths_skul.xml" ). Quote Link to post Share on other sites
