Raksura 270 Posted January 30, 2020 Share Posted January 30, 2020 3 hours ago, lameboyadvance said: ...Still haven't found a local/China version of EskeRahn's dual half clip case though... For Australia, right? Here it is. 2 Quote Link to post Share on other sites
lameboyadvance 98 Posted January 30, 2020 Share Posted January 30, 2020 (edited) 4 minutes ago, Raksura said: For Australia, right? Here it is. Thanks, that certainly looks like it. All the ones I've seen up until now have had embossed designs or a metal badge in the corner. Tempted to try that triple layer removable one I found, if not for the fact the outer case is huge compared to the P20 Pro holder. Also wondering how well the purse could be cut out from that other one I found, but then again its another magnet case which probably has a weak magnet... Edited January 30, 2020 by lameboyadvance 1 Quote Link to post Share on other sites
VaZso 1,999 Posted January 30, 2020 Share Posted January 30, 2020 (edited) For me, this one (simple case made for P20 Pro) seems to be very good. It is not as rubberized anyway, but it clips slightly in at the top side of the lower part - so it holds perfectly. Especially as I have a SIM adapter on the back and some rubber pads to not sit on SIM holder while it is laying on a table - that is why it seems to be uneven at its back. However, seller sent me two types of this case (I have received two of one type and two of the other). This type has one oval hole at back, the other has three separate ones - I like this much better as I need to cut less to be suitable for Pro1. Sorry for the quality of photos, they were made by Moto G6 in a darker environment... Edited January 30, 2020 by VaZso 3 Quote Link to post Share on other sites
lameboyadvance 98 Posted January 30, 2020 Share Posted January 30, 2020 (edited) ...And I just found the case type I was looking for on AliExpress, for $4.07 (cheaper than eBay, as usual). https://www.aliexpress.com/item/4000114115816.htm ...If only they made this version with a fold out card section like the earlier case, then removing it to add depth for the Pro1 would be a lot easier/neater. Edited January 30, 2020 by lameboyadvance 2 Quote Link to post Share on other sites
PC_ 61 Posted January 30, 2020 Share Posted January 30, 2020 (edited) I recall a previous forum member said they purchased this leather sleave https://www.etsy.com/listing/719311781/leather-sleeve-for-galaxy-s10-full-grain?ref=landingpage_similar_listing_top-3&frs=1 after providing the dimensions of the Pro1 but this was before they had recieved their phone. I can't remember who it was but I would love to hear their review on the fit and quality. It's seems a bit steep at £46 though. (I wouldn't have been able to type this on the Pro1 keyboard as I can't figure out how to type the £ sign). Edited January 30, 2020 by PC_ Typo Quote Link to post Share on other sites
_DW_ 628 Posted January 30, 2020 Share Posted January 30, 2020 2 hours ago, EskeRahn said: Searched a bit on aliexpress, and this is a candidate, allegedly in leather. Ordered one.... Looks alright. See how it goes 🙂 Quote Link to post Share on other sites
sequestris 710 Posted January 30, 2020 Share Posted January 30, 2020 So this is a bit of a "Huh" moment.@david recommended this clear bumper to me.https://www.amazon.com/gp/product/B07L2SQLRC?ref=ppx_pt2_dt_b_prod_image I just got it today and put it on. He had told me that some mods need to be done to get the buttons to align and the ports to be easy access. I was trying to upload some pics to my PC and pried it off and stuck it on the front. You know what?YOU CAN TYPE THROUGH IT! YOU CAN TOUCH THE SCREEN! You know what? I can flip open the phone - with ease - and the entire screen is protected. Sure there is a cut out for where the camera and flash holes are, but whatever! I have a screen protector that arrived in 2 days and cost $7.39! 3 2 5 1 Quote Link to post Share on other sites
sequestris 710 Posted January 30, 2020 Share Posted January 30, 2020 @EskeRahn Quote Link to post Share on other sites
sequestris 710 Posted January 30, 2020 Share Posted January 30, 2020 Who can we contact to see if they can make one with no holes? Quote Link to post Share on other sites
EskeRahn 5,596 Posted January 30, 2020 Share Posted January 30, 2020 I posted this idea already in another thread, and yes it works surprisingly well. Of course it needs to be for a thinner device and with no holes, but what is worse is that it would be conflicting with the lip of a shell grabbing the lower part. I think we would need some clever stuff where one part grabs the ends, and the other the long edges. Quote Link to post Share on other sites
_DW_ 628 Posted January 30, 2020 Share Posted January 30, 2020 Nice! haha 🙂 Quote Link to post Share on other sites
D1ggs 141 Posted January 30, 2020 Share Posted January 30, 2020 Does this fit on the bottom "keyboard" part? Quote Link to post Share on other sites
_DW_ 628 Posted January 30, 2020 Share Posted January 30, 2020 19 hours ago, sequestris said: I am trying to decidePretty Cases They will all protect the phone completely. Been trying to find these in UK just plain version of the case can't find anywhere and they come from china! Not even checked if any have the correct dimensions yet 🙂 1 Quote Link to post Share on other sites
EskeRahn 5,596 Posted January 30, 2020 Share Posted January 30, 2020 9 minutes ago, _DW_ said: Been trying to find these in UK just plain version of the case can't find anywhere and they come from china! Not even checked if any have the correct dimensions yet 🙂 Yes please anyone, tell if you see them sans motive.. Quote Link to post Share on other sites
sequestris 710 Posted January 30, 2020 Share Posted January 30, 2020 15 minutes ago, _DW_ said: Been trying to find these in UK just plain version of the case can't find anywhere and they come from china! Not even checked if any have the correct dimensions yet 🙂 If you do not select a design then you get the all black one. At least that's what the seller said. And it's $10.00 cheaper. Dimensions are spot for the Note 7. 's Quote Link to post Share on other sites
jjarmasz 81 Posted January 30, 2020 Share Posted January 30, 2020 (edited) 2 hours ago, sequestris said: So this is a bit of a "Huh" moment.@david recommended this clear bumper to me.https://www.amazon.com/gp/product/B07L2SQLRC?ref=ppx_pt2_dt_b_prod_image I just got it today and put it on. He had told me that some mods need to be done to get the buttons to align and the ports to be easy access. I was trying to upload some pics to my PC and pried it off and stuck it on the front. You know what?YOU CAN TYPE THROUGH IT! YOU CAN TOUCH THE SCREEN! You know what? I can flip open the phone - with ease - and the entire screen is protected. Sure there is a cut out for where the camera and flash holes are, but whatever! I have a screen protector that arrived in 2 days and cost $7.39! Seriously, you can flip it open with the protector on top? That's amazing. Edited January 30, 2020 by jjarmasz 1 Quote Link to post Share on other sites
sequestris 710 Posted January 30, 2020 Share Posted January 30, 2020 56 minutes ago, EskeRahn said: I posted this idea already in another thread, and yes it works surprisingly well. Of course it needs to be for a thinner device and with no holes, but what is worse is that it would be conflicting with the lip of a shell grabbing the lower part. I think we would need some clever stuff where one part grabs the ends, and the other the long edges. Actually, there is no interference. It makes opening and closing easier. Quote Link to post Share on other sites
sequestris 710 Posted January 30, 2020 Share Posted January 30, 2020 1 minute ago, jjarmasz said: Seriously, you can flip it open with the protector on top? That's amazing. Yes. I was surprised too. 1 Quote Link to post Share on other sites
jjarmasz 81 Posted January 30, 2020 Share Posted January 30, 2020 4 minutes ago, sequestris said: Yes. I was surprised too. Brilliant. Gonna have to try it out... Quote Link to post Share on other sites
EskeRahn 5,596 Posted January 30, 2020 Share Posted January 30, 2020 8 minutes ago, sequestris said: Actually, there is no interference. It makes opening and closing easier. But currently its lower part is without a shell, right? I meant that the lips of the the two shells will fight locking in the same "v" shaped space between the two parts. 1 Quote Link to post Share on other sites
EskeRahn 5,596 Posted January 30, 2020 Share Posted January 30, 2020 50 minutes ago, sequestris said: If you do not select a design then you get the all black one. At least that's what the seller said. And it's $10.00 cheaper. Dimensions are spot for the Note 7. 's Ebay won't let you Quote Link to post Share on other sites
sequestris 710 Posted January 30, 2020 Share Posted January 30, 2020 3 minutes ago, EskeRahn said: Ebay won't let you I'll see if I can find another without any design. 1 Quote Link to post Share on other sites
sequestris 710 Posted January 30, 2020 Share Posted January 30, 2020 (edited) 1 hour ago, EskeRahn said: But currently its lower part is without a shell, right? I meant that the lips of the the two shells will fight locking in the same "v" shaped space between the two parts. Ah yes. I only have one though. Edited January 30, 2020 by sequestris Quote Link to post Share on other sites
D1ggs 141 Posted January 30, 2020 Share Posted January 30, 2020 I like how you time your melatonin. I'm guessing bedtime is 10pm 😂? That's when I totally take mine too! 1 Quote Link to post Share on other sites
netman 1,424 Posted January 30, 2020 Share Posted January 30, 2020 This is amazing :). 1 Quote Link to post Share on other sites
