Wheeljack 212 Posted August 13, 2020 Share Posted August 13, 2020 (edited) I now have cut away almost the entire right side of my P20 silicon case. I believe the small cutout for the power button was shifting around in tight pockets activating the screen by accident. When I took out my phone with an active flashlight this morning, i finally had enough. Been running around without any fingerprints set up the last two days. Slider also works better now. Still, this opens up new ways for dust and lint to sneak into the back of the case. Edit: and it was this issue all along. Edited August 15, 2020 by Wheeljack 1 Quote Link to post Share on other sites
fire 14 Posted August 13, 2020 Share Posted August 13, 2020 This is my suggestion, like my old Samsung Relay... https://drive.google.com/file/d/13Ana1Qlxyfm1NtVNbyXWPbe1jq3KJHyk/view?usp=sharing And if you want, have a choice of color, for the Relay we still have choices; https://www.ebay.com/itm/Hard-Cover-Phone-Case-for-Samsung-Galaxy-S-Relay-4G-T699-SGH-T699-Blaze-Q/390644533829?hash=item5af43a8a45:g:szQAAOxyaTxTQInS I'm sure there's a way to manufacture something like this... 1 Quote Link to post Share on other sites
lmckenna 26 Posted August 14, 2020 Share Posted August 14, 2020 Ended up going the same route as @Hook and it makes the phone way less slippery and looks pretty good IMO. Ordered this skin for the Note 10. https://www.amazon.com/dp/B07Z7CGZ87?ref=ppx_pop_mob_ap_share Had to trim off a little on the right edge and connect the mic hole to the camera hole. 5 Quote Link to post Share on other sites
CornholioGSM 370 Posted August 14, 2020 Share Posted August 14, 2020 (edited) 1 hour ago, lmckenna said: Ended up going the same route as @Hook and it makes the phone way less slippery...... This skin is nothing else than piece of car vinyl wrap. Soo you can go to any car wrap company and ask for small piece in any color (transparent too) 🙂 ...and good is that car wrap is good formable after preheating . Best are from 3M or Oracal i mean Edited August 14, 2020 by CornholioGSM 3 Quote Link to post Share on other sites
MickH 212 Posted August 15, 2020 Share Posted August 15, 2020 Just awaiting another freebie to arrive from Wish 😁. Will post pics when it arrives, depending whether the Pro1 fits. 1 Quote Link to post Share on other sites
Bruce Wayne 65 Posted August 21, 2020 Share Posted August 21, 2020 https://www.aliexpress.com/item/4000419201477.html?spm=a2g0o.productlist.0.0.410b4541N2cH0U&algo_pvid=a95b10b0-9d22-4dc9-b47c-5de5dab0f10d&algo_expid=a95b10b0-9d22-4dc9-b47c-5de5dab0f10d-27&btsid=0ab6d69515979734164406840e6c58&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_ Try This Frame less case .. at least it will reduce your work to cutout notches for Side. you only have to work for Top and bottom notch.. although it looks cool... 2 Quote Link to post Share on other sites
EskeRahn 5,598 Posted August 21, 2020 Share Posted August 21, 2020 4 hours ago, Bruce Wayne said: Try This Frame less case .. at least it will reduce your work to cutout notches for Side. you only have to work for Top and bottom notch.. although it looks cool... Interesting. Though my experience with the stiff types are a poor fit. The reason is that the back of the Pro1 is not just flat but slanted towards the sides. 1 Quote Link to post Share on other sites
Tsunero 215 Posted August 21, 2020 Share Posted August 21, 2020 13 hours ago, Bruce Wayne said: it will reduce your work to cutout notches Easiest I found to work with regarding cutting is getting a 0.5mm soft silicone case (P20 Pro). If you have a bench press and some hard (or sharpened) shapes for the holes then you can do a very clean work. 2 Quote Link to post Share on other sites
CornholioGSM 370 Posted August 26, 2020 Share Posted August 26, 2020 ...this method looks really coool 🙂 3 Quote Link to post Share on other sites
agent008 248 Posted August 28, 2020 Share Posted August 28, 2020 (edited) (Posting this on the screen protector thread and also the case thread because relevant for both). The quote below is from the screen protector thread: On 8/7/2020 at 1:16 PM, AnyDevil said: A few years back when we didn't do in-house screen protector manufacturing, we were getting bugged daily to make screen protectors for one of the early OnePlus devices (OnePlus being an early-adopter brand like Fxtec is now). We did a production run, and we didn't sell any! Can't make that mistake again 🙂 Callum Here's a crazy idea. Maybe you could modify some existing cases for a fee? In my area (Brazil) the best fit I could find are cases for the MotorolaOne Vision (XT1970 is moto's code for this device). The back openings for the Moto One Vision case are a match for the Pro1 (even the Fxtec logo is visible as it is in the exact same place as the fingerprint reader on the Moto). What isn't right are the openings on the sides (earphone plug, speakers, USB/charger port, volume, power, camera buttons and fingerprint sensor). Check photos below of an "El Cheapo" chinese "folio-style" case. I also got a TPU case but that one's at home as I felt the folio case is a bit safer (protects screen too). Some other people here at the forum found the Huawei P20 to be a good fit as well. Either one of these cases could be a starting point from where you could professionally cut openings in the right places maybe? If modding is not your cup of tea or against your business model maybe you could direct us towards some other shop that could do that. Thanks! EDIT: By having a TPU case correctly modded, the folio case could kind of be a consequence. Since it really is a TPU case holding the phone to the folio. Edited August 28, 2020 by agent008 Quote Link to post Share on other sites
atfrase 10 Posted August 28, 2020 Share Posted August 28, 2020 I got a "GVTECH Case for Huawei P20 Pro TPU Cover" (https://www.amazon.com/gp/product/B07RSQF772) which fits pretty nicely on the lower (keyboard) half of the unit, though of course I had to poke holes for the rear mic, top/bottom speakers, USB socket, headphone socket, and power and volume keys. I dislike having no protection on the top (screen) half though, and indeed have already gotten a subtle crack on the screen because it was slippery enough to slide out of my pocket sitting down and land on its corner. Any better suggestions? Ideally, any suggestions for adding a silicone bumper around the edges of the screen to cushion those corners (and avoid it resting on the screen surface when placed face-down)? Quote Link to post Share on other sites
EskeRahn 5,598 Posted August 29, 2020 Share Posted August 29, 2020 20 hours ago, atfrase said: any suggestions for adding a silicone bumper around the edges of the screen to cushion those corners (and avoid it resting on the screen surface when placed face-down)? See this 1 Quote Link to post Share on other sites
atfrase 10 Posted September 1, 2020 Share Posted September 1, 2020 On 8/29/2020 at 9:06 AM, EskeRahn said: See this Thanks for that! Sadly it's too late for me, this heavy slippery phone already slid out of my pocket once and landed on a front corner of the screen rather than a rear corner in the nice soft silicone case, so now I've got a crack and an intermittent solid magenta line through the display. 😕 3 Quote Link to post Share on other sites
benoitjeffrey 66 Posted September 3, 2020 Share Posted September 3, 2020 Even protected in a p20 pro flip case , it lasted 2 weeks before shattering the whole display on the first drop.... We really do need a proper case that wouldn't take 2 months to get to our door and that is made for our device 1 2 Quote Link to post Share on other sites
EskeRahn 5,598 Posted September 4, 2020 Share Posted September 4, 2020 7 hours ago, benoitjeffrey said: Even protected in a p20 pro flip case , it lasted 2 weeks before shattering the whole display on the first drop.... We really do need a proper case that wouldn't take 2 months to get to our door and that is made for our device How sad... I have dropped a Pro1 in a flip case a couple of times - and even without (see this) - but so far have been lucky that only cosmetic damage has been done. But that said a dedicated case would certainly be good. Though it is hard to imagine one that both gives it good protection and does not limit the usability. IMHO The least bad compromise here is a flip case or a double bumper (here), but unfortunately the flip case did not do the trick for your drop. Quote Link to post Share on other sites
belletrist 63 Posted October 3, 2020 Share Posted October 3, 2020 (edited) I've been using the flip case from Snakehive for awhile now and just wanted to update on the TPU case within it. I have only made one cut out for the finger print reader. For the other buttons I've only sliced the plastic to weaken it. That does allow the buttons to be pressed, even the camera button can be used this way. The case doesn't appear to be as flimsy as others have suggested, with the extra button cutouts. It does survive an upside down shake test without coming loose. Edited October 3, 2020 by belletrist updated info for clarification 1 Quote Link to post Share on other sites
Slion 1,201 Posted October 3, 2020 Share Posted October 3, 2020 8 hours ago, belletrist said: The case doesn't appear to be as flimsy as others have suggested, with the extra button cutouts. It does survive an upside down shake test without coming loose. I used it for months and it is alright but it does not compare to higher quality ones: Quote Link to post Share on other sites
a123qwertz567 5 Posted October 15, 2020 Share Posted October 15, 2020 (edited) Because the fits of most "shell" cases were not as good as I want (mostly the display part laying on the edges so it does not fully close), I tried some "sleeve" cases and wanted to share the Info with you. WARING: I think the Pro 1 is very slippery so getting it out of the sleeves is a bit fiddly and it might slip out of your hands! Case #1: +Tight fit on the beginning. It get wider after some days. +Has a belt loop for those who are in to this style of carrying it around. - Could be a little bit deeper, so the corner protection is better in case of a drop. - Pull out strip was ripped out after one week. I got a replacement for free from seller. https://www.ebay.de/itm/Forcell-Deko-Etui-für-HUAWEI-Schutzhülle-Handytasche-Case-Klett-Zugband/232712429540?ssPageName=STRK%3AMEBIDX%3AIT&var=532331998553&_trksid=p2057872.m2749.l2649 Case #2: + Good fit on first day. + Pull out it bigger then on case #1 so it easier to get out. - deeper then the other case but corner have a cut out, so protection not as good as it can be. https://www.ebay.de/itm/Handy-Tasche-Etui-Schutz-Hülle-Slim-Case-schwarz-rot-für-Motorola-Moto-G8-Power/402239498946?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649 If someone wants so have some pictures let me know. EDIT: Typos Edited October 15, 2020 by a123qwertz567 1 1 Quote Link to post Share on other sites
sequestris 710 Posted October 19, 2020 Share Posted October 19, 2020 Still my fave. Been using the same one since February. I have 2 spares that are still sealed. If you don't like the designs, maybe you can skin it.https://www.ebay.com/itm/153051236557 2 2 Quote Link to post Share on other sites
CornholioGSM 370 Posted October 21, 2020 Share Posted October 21, 2020 ...today playing with back cover wrapping 😄 4 Quote Link to post Share on other sites
netman 1,424 Posted October 22, 2020 Share Posted October 22, 2020 9 hours ago, CornholioGSM said: ...today playing with back cover wrapping 😄 I am confused but intrigued, please tell more! :) 2 Quote Link to post Share on other sites
CornholioGSM 370 Posted October 22, 2020 Share Posted October 22, 2020 6 minutes ago, netman said: I am confused but intrigued, please tell more! 🙂 it is vacuum wrapped like on this video but with "homemade machine" 😄 I have used semi semitransparent matte black foil for car lights...color is good, but glue on it is bad....it was too cheap. 2 1 1 Quote Link to post Share on other sites
TeZtdevice 368 Posted November 3, 2020 Share Posted November 3, 2020 Hmm...interessting 🙂 2 Quote Link to post Share on other sites
EskeRahn 5,598 Posted November 3, 2020 Share Posted November 3, 2020 38 minutes ago, TeZtdevice said: Hmm...interessting 🙂 Maybe this 36 pages long thread have finally been seen as an indication of some users being interested in protecting the Pro1(x)... 😇 7 Quote Link to post Share on other sites
TeZtdevice 368 Posted November 4, 2020 Share Posted November 4, 2020 (edited) New update on the IGG-Page: 2) We have been looking into dbrand for Pro1-X skins, as well as an alternative protective casing to the leather pouch that already comes with the phone. There have been a huge number of requests for a protective case & we want to make sure your Pro1-X stays safe! I personally like dbrand 🙂(But a real case would be so much better as a skin) Edited November 4, 2020 by TeZtdevice 3 1 Quote Link to post Share on other sites
